Build fail on debian - Toolset build error
Andrew Butterfield Andrew.Butterfield at scss.tcd.ie
Mon Oct 12 12:27:19 UTC 2020
Hi Karel,
 I have no idea what's wrong.
If I ask nicely:
:- which python2
/Library/Frameworks/Python.framework/Versions/2.7/bin/python2
:- python2 --version
Python 2.7.18
all seems well.
I have has this problem before and usually I just purge all "brew" versions of python,
and perhaps re-install/update the command line tools from x-code - then all works fine.
Right now my Mac reports my X-code and command line tools as up to date.
When it is checking for python - what is the check? How does it determine "usability"? It's not simple presence of the binary.
Currently I have three python2s:
:- type -a python2
python2 is /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
python2 is /usr/local/bin/python2
The first one an the $PATH is the one the tool builder doesn't like.
:- type python2
python2 is hashed (/Library/Frameworks/Python.framework/Versions/2.7/bin/python2)
Thanks,
  Andrew
> On 12 Oct 2020, at 11:21, Karel Gardas <karel.gardas at centrum.cz> wrote:
> On 10/12/20 12:17 PM, Andrew Butterfield wrote:
>> Dear all,
>> I am having a problem building RTEMs master, on OS X Mojave - see below
> checking whether to use python...
> checking for python... no
> configure: error: no usable python found at
> Something wrong with your python2 install? E.g. gdb needs python2 and if
> you don't have it, it'll fail which will fail tools compile which will
> fail whole rtems compile...
> Cheers,
> Karel
>>> Begin forwarded message:
>>> *From: *Sebastian Huber <sebastian.huber at embedded-brains.de
>>> <mailto:sebastian.huber at embedded-brains.de>>
>>> *Subject: **Re: Build fail on debian - Toolset build error*
>>> *Date: *12 October 2020 at 10:48:17 IST
>>> *To: *Andrew Butterfield <Andrew.Butterfield at scss.tcd.ie
>>> <mailto:Andrew.Butterfield at scss.tcd.ie>>
>>> Hello Andrew,
>>> could you please forward this e-mail to devel at rtems.org
>>> <mailto:devel at rtems.org>.
>>> On 12/10/2020 11:45, Andrew Butterfield wrote:
>>>> Hi Sebastian,
>>>>  I get a python error - despite using the virtual environment,
>>>> which maps `python` to the OS X \System installation of python 3.8
>>>> It complains about python2 being unusable - see tail of report below...
>>>> My command-line tools and Xcode are up-to-date. Now this is on a
>>>> Mojave machine, which is
>>>> one that is not listed in the User Manual where OS X is discussed.
>>>> I'll try to do this on my laptop which is now Catalina
>>>> Regards, Andrew
>>>> tail of error report follows:
>>>> checking for library containing socketpair... none required
>>>> checking for ld used by GCC...
>>>> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld
>>>> checking if the linker
>>>> (/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld)
>>>> is GNU ld... no
>>>> checking for shared library run path origin... done
>>>> checking for iconv... yes
>>>> checking how to link with libiconv... -liconv
>>>> checking for iconv declaration...
>>>>          extern size_t iconv (iconv_t cd, char * *inbuf, size_t
>>>> *inbytesleft, char * *outbuf, size_t *outbytesleft);
>>>> checking for library containing waddstr... -lncurses
>>>> checking for library containing tgetent... none required
>>>> checking size of unsigned long long... 8
>>>> checking size of unsigned long... 8
>>>> checking size of unsigned __int128... 16
>>>> checking for library containing dlopen... none required
>>>> checking whether to use expat... yes
>>>> checking for libexpat... yes
>>>> checking how to link with libexpat... -lexpat
>>>> checking for XML_StopParser... yes
>>>> checking whether to use MPFR... auto
>>>> checking for libmpfr... no
>>>> configure: WARNING: MPFR is missing or unusable; some features may be
>>>> unavailable.
>>>> make[1]: *** [configure-gdb] Error 1
>>>> make: *** [all] Error 2
>>>> shell cmd failed: /bin/sh -ex
>>>>  /Users/butrfeld/REPOS/rtems-smp-qualification-qual/modules/rsb/rtems/build/sparc-rtems6-gdb-0295dde-x86_64-apple-darwin18.7.0-1/do-build
>>>> error: building sparc-rtems6-gdb-0295dde-x86_64-apple-darwin18.7.0-1
>>>>> On 12 Oct 2020, at 09:19, Sebastian Huber
>>>>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>>> On 12/10/2020 10:14, Andrew Butterfield wrote:
>>>>>> Is there any point me trying to build on my OS X machine, or will I
>>>>>> just get the same error?
>>>>> It is unlikely that you get the same error. This seems to be a
>>>>> Debian specific issue.
>>>> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
>>>> Lero at TCD, Head of Software Foundations & Verification Research Group
>>>> School of Computer Science and Statistics,
>>>> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>>>> http://www.scss.tcd.ie/Andrew.Butterfield/
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201012/40ad0734/attachment.html>
