[PATCH] c-user: Add "Generated from ..." comments
Sebastian Huber
Mon Oct 12 13:51:55 UTC 2020
c-user/config/bdbuf.rst | 28 +++++++++++++++
c-user/config/bsp-related.rst | 16 +++++++++
c-user/config/classic-api.rst | 26 ++++++++++++++
c-user/config/classic-init-task.rst | 18 ++++++++++
c-user/config/device-driver.rst | 38 ++++++++++++++++++++
c-user/config/event-record.rst | 10 ++++++
c-user/config/filesystem.rst | 56 +++++++++++++++++++++++++++++
c-user/config/general.rst | 44 +++++++++++++++++++++++
c-user/config/idle-task.rst | 8 +++++
c-user/config/mpci.rst | 16 +++++++++
c-user/config/posix-api.rst | 20 +++++++++++
c-user/config/posix-init-thread.rst | 8 +++++
c-user/config/scheduler-general.rst | 30 ++++++++++++++++
c-user/config/task-stack-alloc.rst | 12 +++++++
14 files changed, 330 insertions(+)
diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
index 1a0d393..e981f54 100644
--- a/c-user/config/bdbuf.rst
+++ b/c-user/config/bdbuf.rst
@@ -15,12 +15,16 @@
.. https://docs.rtems.org/branches/master/eng/req/howto.html
+.. Generated from spec:/acfg/if/group-bdbuf
Block Device Cache Configuration
This section describes configuration options related to the Block Device Cache
(bdbuf).
+.. Generated from spec:/acfg/if/appl-needs-libblock
.. index:: CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
.. _CONFIGURE_APPLICATION_NEEDS_LIBBLOCK:
@@ -47,6 +51,8 @@ NOTES:
set by the user with the configuration options below. The Block Device Cache
is used for example by the RFS and DOSFS filesystems.
+.. Generated from spec:/acfg/if/bdbuf-buffer-max-size
.. index:: CONFIGURE_BDBUF_BUFFER_MAX_SIZE
.. _CONFIGURE_BDBUF_BUFFER_MAX_SIZE:
@@ -78,6 +84,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-buffer-min-size
.. index:: CONFIGURE_BDBUF_BUFFER_MIN_SIZE
.. _CONFIGURE_BDBUF_BUFFER_MIN_SIZE:
@@ -105,6 +113,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-cache-memory-size
.. index:: CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
.. _CONFIGURE_BDBUF_CACHE_MEMORY_SIZE:
@@ -132,6 +142,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-max-read-ahead-blocks
.. index:: CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
.. _CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS:
@@ -161,6 +173,8 @@ NOTES:
will issue speculative read transfers if a sequential access pattern is
detected. This can improve the performance on some systems.
+.. Generated from spec:/acfg/if/bdbuf-max-write-blocks
.. index:: CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
.. _CONFIGURE_BDBUF_MAX_WRITE_BLOCKS:
@@ -188,6 +202,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-read-ahead-task-priority
.. index:: CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
.. _CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY:
@@ -214,6 +230,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-task-stack-size
.. index:: CONFIGURE_BDBUF_TASK_STACK_SIZE
.. _CONFIGURE_BDBUF_TASK_STACK_SIZE:
@@ -251,6 +269,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-swapout-block-hold
.. index:: CONFIGURE_SWAPOUT_BLOCK_HOLD
.. _CONFIGURE_SWAPOUT_BLOCK_HOLD:
@@ -278,6 +298,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-swapout-swap-period
.. index:: CONFIGURE_SWAPOUT_SWAP_PERIOD
.. _CONFIGURE_SWAPOUT_SWAP_PERIOD:
@@ -305,6 +327,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-swapout-task-priority
.. index:: CONFIGURE_SWAPOUT_TASK_PRIORITY
.. _CONFIGURE_SWAPOUT_TASK_PRIORITY:
@@ -331,6 +355,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-swapout-worker-tasks
.. index:: CONFIGURE_SWAPOUT_WORKER_TASKS
.. _CONFIGURE_SWAPOUT_WORKER_TASKS:
@@ -357,6 +383,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bdbuf-swapout-worker-taskp-riority
.. index:: CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
.. _CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY:
diff --git a/c-user/config/bsp-related.rst b/c-user/config/bsp-related.rst
index 8ed34cf..71bcd58 100644
--- a/c-user/config/bsp-related.rst
+++ b/c-user/config/bsp-related.rst
@@ -15,6 +15,8 @@
+.. Generated from spec:/acfg/if/group-bsp
BSP Related Configuration Options
@@ -23,6 +25,8 @@ configuration options may have a BSP-specific setting which is defined by
``<bsp.h>``. The BSP-specific settings can be disabled by the
:ref:`CONFIGURE_DISABLE_BSP_SETTINGS` configuration option.
+.. Generated from spec:/acfg/if/bsp-idle-task-body
.. index:: BSP_IDLE_TASK_BODY
.. _BSP_IDLE_TASK_BODY:
@@ -58,6 +62,8 @@ NOTES:
peripheral buses, a BSP-specific IDLE task may be capable of turning
components off to save power during extended periods of no task activity.
+.. Generated from spec:/acfg/if/bsp-idle-task-stack-size
.. index:: BSP_IDLE_TASK_STACK_SIZE
.. _BSP_IDLE_TASK_STACK_SIZE:
@@ -98,6 +104,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bsp-initial-extension
.. index:: BSP_INITIAL_EXTENSION
.. _BSP_INITIAL_EXTENSION:
@@ -132,6 +140,8 @@ NOTES:
The value of this configuration option is placed after the entries of all
other initial user extensions.
+.. Generated from spec:/acfg/if/bsp-interrupt-stack-size
.. index:: BSP_INTERRUPT_STACK_SIZE
.. _BSP_INTERRUPT_STACK_SIZE:
@@ -175,6 +185,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/bsp-prerequisite-drivers
.. index:: CONFIGURE_BSP_PREREQUISITE_DRIVERS
.. _CONFIGURE_BSP_PREREQUISITE_DRIVERS:
@@ -210,6 +222,8 @@ NOTES:
other initial user extensions (including
:ref:`CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS`).
+.. Generated from spec:/acfg/if/disable-bsp-settings
.. index:: CONFIGURE_DISABLE_BSP_SETTINGS
.. _CONFIGURE_DISABLE_BSP_SETTINGS:
@@ -246,6 +260,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/malloc-bsp-supports-sbrk
.. index:: CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
.. _CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK:
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index d1e197b..90aec72 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -15,11 +15,15 @@
+.. Generated from spec:/acfg/if/group-classic
Classic API Configuration
This section describes configuration options related to the Classic API.
+.. Generated from spec:/acfg/if/max-barriers
.. index:: CONFIGURE_MAXIMUM_BARRIERS
.. _CONFIGURE_MAXIMUM_BARRIERS:
@@ -61,6 +65,8 @@ NOTES:
This object class can be configured in unlimited allocation mode, see
:ref:`ConfigUnlimitedObjects`.
+.. Generated from spec:/acfg/if/max-message-queues
.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
@@ -104,6 +110,8 @@ NOTES:
store the messages of each message queue, see
:ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
+.. Generated from spec:/acfg/if/max-partitions
.. index:: CONFIGURE_MAXIMUM_PARTITIONS
.. _CONFIGURE_MAXIMUM_PARTITIONS:
@@ -145,6 +153,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-periods
.. index:: CONFIGURE_MAXIMUM_PERIODS
.. _CONFIGURE_MAXIMUM_PERIODS:
@@ -186,6 +196,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-ports
.. index:: CONFIGURE_MAXIMUM_PORTS
.. _CONFIGURE_MAXIMUM_PORTS:
@@ -227,6 +239,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-regions
.. index:: CONFIGURE_MAXIMUM_REGIONS
.. _CONFIGURE_MAXIMUM_REGIONS:
@@ -268,6 +282,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-semaphores
.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
.. _CONFIGURE_MAXIMUM_SEMAPHORES:
@@ -313,6 +329,8 @@ NOTES:
scheduler count (see :ref:`ConfigurationSchedulerTable`). The semaphores
using the :ref:`MrsP` need a ceiling priority per scheduler.
+.. Generated from spec:/acfg/if/max-tasks
.. index:: CONFIGURE_MAXIMUM_TASKS
.. _CONFIGURE_MAXIMUM_TASKS:
@@ -371,6 +389,8 @@ NOTES:
the addition of a new configuration parameter to specify the number of
tasks which enable floating point support.
+.. Generated from spec:/acfg/if/max-thread-local-storage-size
.. index:: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
.. _CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE:
@@ -415,6 +435,8 @@ NOTES:
the RTEMS Tools can be used to obtain the thread-local storage size and
alignment of an application executable.
+.. Generated from spec:/acfg/if/max-timers
.. index:: CONFIGURE_MAXIMUM_TIMERS
.. _CONFIGURE_MAXIMUM_TIMERS:
@@ -456,6 +478,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-user-extensions
.. index:: CONFIGURE_MAXIMUM_USER_EXTENSIONS
.. _CONFIGURE_MAXIMUM_USER_EXTENSIONS:
@@ -491,6 +515,8 @@ DESCRIPTION:
NOTES:
This object class cannot be configured in unlimited allocation mode.
+.. Generated from spec:/acfg/if/min-tasks-with-user-provided-storage
.. index:: CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
.. _CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE:
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 8430757..64a8f9f 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -15,12 +15,16 @@
+.. Generated from spec:/acfg/if/group-classicinit
Classic API Initialization Task Configuration
initialization task.
+.. Generated from spec:/acfg/if/init-task-arguments
.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
.. _CONFIGURE_INIT_TASK_ARGUMENTS:
@@ -48,6 +52,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/init-task-attributes
.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
@@ -74,6 +80,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/init-task-entrypoint
.. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
.. _CONFIGURE_INIT_TASK_ENTRY_POINT:
@@ -102,6 +110,8 @@ NOTES:
The application shall provide the function referenced by this configuration
option.
+.. Generated from spec:/acfg/if/init-task-initial-modes
.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
@@ -129,6 +139,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/init-task-name
.. index:: CONFIGURE_INIT_TASK_NAME
.. _CONFIGURE_INIT_TASK_NAME:
@@ -156,6 +168,8 @@ DESCRIPTION:
NOTES:
Use :c:func:`rtems_build_name` to define the task name.
+.. Generated from spec:/acfg/if/init-task-priority
.. index:: CONFIGURE_INIT_TASK_PRIORITY
.. _CONFIGURE_INIT_TASK_PRIORITY:
@@ -183,6 +197,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/init-task-stack-size
.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
.. _CONFIGURE_INIT_TASK_STACK_SIZE:
@@ -216,6 +232,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/rtems-init-tasks-table
.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
diff --git a/c-user/config/device-driver.rst b/c-user/config/device-driver.rst
index 25f15d1..8915b0b 100644
--- a/c-user/config/device-driver.rst
+++ b/c-user/config/device-driver.rst
@@ -15,12 +15,16 @@
+.. Generated from spec:/acfg/if/group-devdrv
Device Driver Configuration
This section describes configuration options related to the device drivers.
Note that network device drivers are not covered by the following options.
+.. Generated from spec:/acfg/if/appl-does-not-need-clock-driver
.. index:: CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
.. _CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER:
@@ -57,6 +61,8 @@ NOTES:
otherwise a compile time error in the configuration file will occur.
+.. Generated from spec:/acfg/if/appl-extra-drivers
.. index:: CONFIGURE_APPLICATION_EXTRA_DRIVERS
.. _CONFIGURE_APPLICATION_EXTRA_DRIVERS:
@@ -88,6 +94,8 @@ NOTES:
See :ref:`CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS` for an alternative
placement of application device driver initializers.
+.. Generated from spec:/acfg/if/appl-needs-ata-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER:
@@ -115,6 +123,8 @@ NOTES:
If this option is defined and the BSP does not have this device driver, then
the user will get a link time error for an undefined symbol.
+.. Generated from spec:/acfg/if/appl-needs-clock-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER:
@@ -150,6 +160,8 @@ NOTES:
+.. Generated from spec:/acfg/if/appl-needs-console-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER:
@@ -189,6 +201,8 @@ NOTES:
configuration options are mutually exclusive.
+.. Generated from spec:/acfg/if/appl-needs-framebuffer-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER:
@@ -217,6 +231,8 @@ NOTES:
+.. Generated from spec:/acfg/if/appl-needs-ide-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER:
@@ -244,6 +260,8 @@ NOTES:
+.. Generated from spec:/acfg/if/appl-needs-null-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
.. index:: /dev/null
@@ -269,6 +287,8 @@ DESCRIPTION:
NOTES:
This device driver is supported by all BSPs.
+.. Generated from spec:/acfg/if/appl-needs-rtc-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER:
@@ -297,6 +317,8 @@ NOTES:
If this is defined and the BSP does not have this device driver, then the
+.. Generated from spec:/acfg/if/appl-needs-simple-console-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER:
@@ -340,6 +362,8 @@ NOTES:
+.. Generated from spec:/acfg/if/appl-needs-simple-task-console-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER:
@@ -392,6 +416,8 @@ NOTES:
+.. Generated from spec:/acfg/if/appl-needs-stub-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER:
@@ -417,6 +443,8 @@ NOTES:
This device driver simply provides entry points that return successful and
is primarily a test fixture. It is supported by all BSPs.
+.. Generated from spec:/acfg/if/appl-needs-timer-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER:
@@ -452,6 +480,8 @@ NOTES:
otherwise a compile time error will occur.
+.. Generated from spec:/acfg/if/appl-needs-watchdog-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
.. _CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER:
@@ -480,6 +510,8 @@ NOTES:
+.. Generated from spec:/acfg/if/appl-needs-zero-driver
.. index:: CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
.. index:: /dev/zero
@@ -505,6 +537,8 @@ DESCRIPTION:
NOTES:
+.. Generated from spec:/acfg/if/appl-prerequisite-drivers
.. index:: CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
.. _CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS:
@@ -537,6 +571,8 @@ NOTES:
See :ref:`CONFIGURE_APPLICATION_EXTRA_DRIVERS` for an alternative placement
+.. Generated from spec:/acfg/if/ata-driver-task-priority
.. index:: CONFIGURE_ATA_DRIVER_TASK_PRIORITY
.. _CONFIGURE_ATA_DRIVER_TASK_PRIORITY:
@@ -564,6 +600,8 @@ NOTES:
This configuration option is only evaluated if the configuration option
:ref:`CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER` is defined.
+.. Generated from spec:/acfg/if/max-drivers
.. index:: CONFIGURE_MAXIMUM_DRIVERS
.. _CONFIGURE_MAXIMUM_DRIVERS:
diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
index 462f9e2..6373e04 100644
--- a/c-user/config/event-record.rst
+++ b/c-user/config/event-record.rst
@@ -14,11 +14,15 @@
+.. Generated from spec:/acfg/if/group-eventrecord
Event Recording Configuration
This section describes configuration options related to the event recording.
+.. Generated from spec:/acfg/if/record-extensions-enabled
.. index:: CONFIGURE_RECORD_EXTENSIONS_ENABLED
.. _CONFIGURE_RECORD_EXTENSIONS_ENABLED:
@@ -49,6 +53,8 @@ NOTES:
The record extensions capture thread create, start, restart, delete, switch,
begin, exitted and terminate events.
+.. Generated from spec:/acfg/if/record-fatal-dump-base64
.. index:: CONFIGURE_RECORD_FATAL_DUMP_BASE64
.. _CONFIGURE_RECORD_FATAL_DUMP_BASE64:
@@ -81,6 +87,8 @@ DESCRIPTION:
NOTES:
This extension can be used to produce crash dumps.
+.. Generated from spec:/acfg/if/record-fatal-dump-base64-zlib
.. index:: CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
.. _CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB:
@@ -112,6 +120,8 @@ NOTES:
The zlib compression needs about 512KiB of RAM. This extension can be used
+.. Generated from spec:/acfg/if/record-per-processor-items
.. index:: CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
.. _CONFIGURE_RECORD_PER_PROCESSOR_ITEMS:
diff --git a/c-user/config/filesystem.rst b/c-user/config/filesystem.rst
index 9269236..8ad9085 100644
--- a/c-user/config/filesystem.rst
+++ b/c-user/config/filesystem.rst
@@ -15,6 +15,8 @@
+.. Generated from spec:/acfg/if/group-filesystem
Filesystem Configuration
@@ -60,6 +62,8 @@ configuration options:
* :ref:`CONFIGURE_IMFS_ENABLE_MKFIFO`
+.. Generated from spec:/acfg/if/appl-disable-filesystem
.. index:: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
.. _CONFIGURE_APPLICATION_DISABLE_FILESYSTEM:
@@ -87,6 +91,8 @@ NOTES:
drivers and basic input/output functions such as :c:func:`printf`.
Filesystems can be disabled to reduce the memory footprint of an application.
+.. Generated from spec:/acfg/if/filesystem-all
.. index:: CONFIGURE_FILESYSTEM_ALL
.. _CONFIGURE_FILESYSTEM_ALL:
@@ -125,6 +131,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/filesystem-dosfs
.. index:: CONFIGURE_FILESYSTEM_DOSFS
.. _CONFIGURE_FILESYSTEM_DOSFS:
@@ -151,6 +159,8 @@ NOTES:
This filesystem requires a Block Device Cache configuration, see
:ref:`CONFIGURE_APPLICATION_NEEDS_LIBBLOCK`.
+.. Generated from spec:/acfg/if/filesystem-ftpfs
.. index:: CONFIGURE_FILESYSTEM_FTPFS
.. _CONFIGURE_FILESYSTEM_FTPFS:
@@ -176,6 +186,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/filesystem-imfs
.. index:: CONFIGURE_FILESYSTEM_IMFS
.. _CONFIGURE_FILESYSTEM_IMFS:
@@ -203,6 +215,8 @@ NOTES:
option is intended for test programs. You do not need to define this
configuration option for the base filesystem (also known as root filesystem).
+.. Generated from spec:/acfg/if/filesystem-jffs2
.. index:: CONFIGURE_FILESYSTEM_JFFS2
.. _CONFIGURE_FILESYSTEM_JFFS2:
@@ -228,6 +242,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/filesystem-nfs
.. index:: CONFIGURE_FILESYSTEM_NFS
.. _CONFIGURE_FILESYSTEM_NFS:
@@ -253,6 +269,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/filesystem-rfs
.. index:: CONFIGURE_FILESYSTEM_RFS
.. _CONFIGURE_FILESYSTEM_RFS:
@@ -279,6 +297,8 @@ NOTES:
+.. Generated from spec:/acfg/if/filesystem-tftpfs
.. index:: CONFIGURE_FILESYSTEM_TFTPFS
.. _CONFIGURE_FILESYSTEM_TFTPFS:
@@ -304,6 +324,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-chmod
.. index:: CONFIGURE_IMFS_DISABLE_CHMOD
.. _CONFIGURE_IMFS_DISABLE_CHMOD:
@@ -328,6 +350,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-chown
.. index:: CONFIGURE_IMFS_DISABLE_CHOWN
.. _CONFIGURE_IMFS_DISABLE_CHOWN:
@@ -352,6 +376,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-link
.. index:: CONFIGURE_IMFS_DISABLE_LINK
.. _CONFIGURE_IMFS_DISABLE_LINK:
@@ -376,6 +402,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-mknod
.. index:: CONFIGURE_IMFS_DISABLE_MKNOD
.. _CONFIGURE_IMFS_DISABLE_MKNOD:
@@ -400,6 +428,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-mknod-device
.. index:: CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
.. _CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE:
@@ -424,6 +454,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-mknod-file
.. index:: CONFIGURE_IMFS_DISABLE_MKNOD_FILE
.. _CONFIGURE_IMFS_DISABLE_MKNOD_FILE:
@@ -448,6 +480,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-mount
.. index:: CONFIGURE_IMFS_DISABLE_MOUNT
.. _CONFIGURE_IMFS_DISABLE_MOUNT:
@@ -473,6 +507,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-readdir
.. index:: CONFIGURE_IMFS_DISABLE_READDIR
.. _CONFIGURE_IMFS_DISABLE_READDIR:
@@ -498,6 +534,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-readlink
.. index:: CONFIGURE_IMFS_DISABLE_READLINK
.. _CONFIGURE_IMFS_DISABLE_READLINK:
@@ -522,6 +560,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-rename
.. index:: CONFIGURE_IMFS_DISABLE_RENAME
.. _CONFIGURE_IMFS_DISABLE_RENAME:
@@ -546,6 +586,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-rmnod
.. index:: CONFIGURE_IMFS_DISABLE_RMNOD
.. _CONFIGURE_IMFS_DISABLE_RMNOD:
@@ -570,6 +612,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-symlink
.. index:: CONFIGURE_IMFS_DISABLE_SYMLINK
.. _CONFIGURE_IMFS_DISABLE_SYMLINK:
@@ -594,6 +638,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-unmount
.. index:: CONFIGURE_IMFS_DISABLE_UNMOUNT
.. _CONFIGURE_IMFS_DISABLE_UNMOUNT:
@@ -619,6 +665,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-disable-utime
.. index:: CONFIGURE_IMFS_DISABLE_UTIME
.. _CONFIGURE_IMFS_DISABLE_UTIME:
@@ -643,6 +691,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-enable-mkfifo
.. index:: CONFIGURE_IMFS_ENABLE_MKFIFO
.. _CONFIGURE_IMFS_ENABLE_MKFIFO:
@@ -667,6 +717,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/imfs-memfile-bytes-per-block
.. index:: CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
.. _CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK:
@@ -718,6 +770,8 @@ NOTES:
* when the block size is 512 bytes, the maximum file size is 1,082,195,456
bytes.
+.. Generated from spec:/acfg/if/use-devfs-as-base-filesystem
.. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
.. _CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM:
@@ -774,6 +828,8 @@ NOTES:
comparable in functionality to the pseudo-filesystem name space provided
before RTEMS release 4.5.0.
+.. Generated from spec:/acfg/if/use-miniimfs-as-base-filesystem
.. index:: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
.. _CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM:
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index b78a81c..9662506 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -15,11 +15,15 @@
+.. Generated from spec:/acfg/if/group-general
General System Configuration
This section describes general system configuration options.
+.. Generated from spec:/acfg/if/dirty-memory
.. index:: CONFIGURE_DIRTY_MEMORY
.. _CONFIGURE_DIRTY_MEMORY:
@@ -51,6 +55,8 @@ NOTES:
See also :ref:`CONFIGURE_MALLOC_DIRTY`.
+.. Generated from spec:/acfg/if/disable-newlib-reentrancy
.. index:: CONFIGURE_DISABLE_NEWLIB_REENTRANCY
.. _CONFIGURE_DISABLE_NEWLIB_REENTRANCY:
@@ -78,6 +84,8 @@ NOTES:
behaviour. For example, :c:macro:`errno` is no longer a thread-local
variable if this option is enabled.
+.. Generated from spec:/acfg/if/executive-ram-size
.. index:: CONFIGURE_EXECUTIVE_RAM_SIZE
.. _CONFIGURE_EXECUTIVE_RAM_SIZE:
@@ -116,6 +124,8 @@ NOTES:
This is an advanced configuration option. Use it only if you know exactly
what you are doing.
+.. Generated from spec:/acfg/if/extra-task-stacks
.. index:: CONFIGURE_EXTRA_TASK_STACKS
.. index:: memory for task tasks
@@ -153,6 +163,8 @@ NOTES:
stacks larger then the minimum, then that memory is **not** accounted for by
``<rtems/confdefs.h>``.
+.. Generated from spec:/acfg/if/initial-extensions
.. index:: CONFIGURE_INITIAL_EXTENSIONS
.. _CONFIGURE_INITIAL_EXTENSIONS:
@@ -182,6 +194,8 @@ NOTES:
:ref:`BSP_INITIAL_EXTENSION` and after the entries of all other initial
user extensions.
+.. Generated from spec:/acfg/if/interrupt-stack-size
.. index:: CONFIGURE_INTERRUPT_STACK_SIZE
.. index:: interrupt stack size
@@ -236,6 +250,8 @@ NOTES:
:ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE` instead of
:c:macro:`CPU_STACK_MINIMUM_SIZE`.
+.. Generated from spec:/acfg/if/malloc-dirty
.. index:: CONFIGURE_MALLOC_DIRTY
.. _CONFIGURE_MALLOC_DIRTY:
@@ -264,6 +280,8 @@ NOTES:
:ref:`CONFIGURE_DIRTY_MEMORY` which dirties the memory only once during the
system initialization.
+.. Generated from spec:/acfg/if/max-file-descriptors
.. index:: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
.. index:: maximum file descriptors
@@ -301,6 +319,8 @@ NOTES:
The default value of three file descriptors allows RTEMS to support standard
input, output, and error I/O streams on :file:`/dev/console`.
+.. Generated from spec:/acfg/if/max-processors
.. index:: CONFIGURE_MAXIMUM_PROCESSORS
.. _CONFIGURE_MAXIMUM_PROCESSORS:
@@ -336,6 +356,8 @@ NOTES:
was built with the ``--enable-smp`` build configuration option). In all
other configurations it has no effect.
+.. Generated from spec:/acfg/if/max-thread-name-size
.. index:: CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
.. index:: maximum thread name size
@@ -378,6 +400,8 @@ NOTES:
This configuration option is available since RTEMS 5.1.
+.. Generated from spec:/acfg/if/memory-overhead
.. index:: CONFIGURE_MEMORY_OVERHEAD
.. _CONFIGURE_MEMORY_OVERHEAD:
@@ -420,6 +444,8 @@ NOTES:
all message queue buffers or task stacks, see
+.. Generated from spec:/acfg/if/message-buffer-memory
.. index:: CONFIGURE_MESSAGE_BUFFER_MEMORY
.. index:: configure message queue buffer memory
.. index:: CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
@@ -504,6 +530,8 @@ NOTES:
+.. Generated from spec:/acfg/if/microseconds-per-tick
.. index:: CONFIGURE_MICROSECONDS_PER_TICK
.. index:: clock tick quantum
.. index:: tick quantum
@@ -558,6 +586,8 @@ NOTES:
There may be Clock Driver specific limits on the resolution or maximum value
of a clock tick quantum.
+.. Generated from spec:/acfg/if/min-task-stack-size
.. index:: CONFIGURE_MINIMUM_TASK_STACK_SIZE
.. index:: minimum task stack size
@@ -612,6 +642,8 @@ NOTES:
In releases before RTEMS 5.1 the ``CONFIGURE_MINIMUM_TASK_STACK_SIZE`` was
used to define the default value of :ref:`CONFIGURE_INTERRUPT_STACK_SIZE`.
+.. Generated from spec:/acfg/if/stack-checker-enabled
.. index:: CONFIGURE_STACK_CHECKER_ENABLED
.. _CONFIGURE_STACK_CHECKER_ENABLED:
@@ -640,6 +672,8 @@ NOTES:
In 4.9 and older, this configuration option was named ``STACK_CHECKER_ON``.
+.. Generated from spec:/acfg/if/ticks-per-time-slice
.. index:: CONFIGURE_TICKS_PER_TIMESLICE
.. index:: ticks per timeslice
@@ -669,6 +703,8 @@ NOTES:
This configuration option has no impact if the Clock Driver is not
configured, see :ref:`CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`.
+.. Generated from spec:/acfg/if/unified-work-areas
.. index:: CONFIGURE_UNIFIED_WORK_AREAS
.. index:: unified work areas
.. index:: separate work areas
@@ -705,6 +741,8 @@ NOTES:
until you run out of all available memory rather then just until you run out
of RTEMS Workspace.
+.. Generated from spec:/acfg/if/unlimited-allocation-size
.. index:: CONFIGURE_UNLIMITED_ALLOCATION_SIZE
.. _CONFIGURE_UNLIMITED_ALLOCATION_SIZE:
@@ -738,6 +776,8 @@ NOTES:
The object maximum of each class can be configured also individually using
the :c:func:`rtems_resource_unlimited` macro.
+.. Generated from spec:/acfg/if/unlimited-objects
.. index:: CONFIGURE_UNLIMITED_OBJECTS
.. _CONFIGURE_UNLIMITED_OBJECTS:
@@ -769,6 +809,8 @@ NOTES:
See also :ref:`CONFIGURE_UNLIMITED_ALLOCATION_SIZE`.
+.. Generated from spec:/acfg/if/verbose-system-init
.. index:: CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
.. _CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION:
@@ -794,6 +836,8 @@ NOTES:
You may use this feature to debug system initialization issues. The
:c:func:`printk` function is used to print the information.
+.. Generated from spec:/acfg/if/zero-workspace-automatically
.. index:: CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
.. index:: clear C Program Heap
.. index:: clear RTEMS Workspace
diff --git a/c-user/config/idle-task.rst b/c-user/config/idle-task.rst
index 8210da1..64a596f 100644
--- a/c-user/config/idle-task.rst
+++ b/c-user/config/idle-task.rst
@@ -15,11 +15,15 @@
+.. Generated from spec:/acfg/if/group-idle
Idle Task Configuration
This section describes configuration options related to the idle tasks.
+.. Generated from spec:/acfg/if/idle-task-body
.. index:: CONFIGURE_IDLE_TASK_BODY
.. _CONFIGURE_IDLE_TASK_BODY:
@@ -52,6 +56,8 @@ NOTES:
IDLE threads can be used to initialize the application, see configuration
option :ref:`CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION`.
+.. Generated from spec:/acfg/if/idle-task-init-appl
.. index:: CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
.. _CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION:
@@ -98,6 +104,8 @@ NOTES:
+.. Generated from spec:/acfg/if/idle-task-stack-size
.. index:: CONFIGURE_IDLE_TASK_STACK_SIZE
.. _CONFIGURE_IDLE_TASK_STACK_SIZE:
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index aa35b1e..dac5cad 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -15,6 +15,8 @@
+.. Generated from spec:/acfg/if/group-mpci
Multiprocessing Configuration
@@ -25,6 +27,8 @@ are only applicable if the configuration option :ref:`CONFIGURE_MP_APPLICATION`
is defined. The multiprocessing (MPCI) support must not be confused with the
SMP support.
+.. Generated from spec:/acfg/if/mp-extra-server-stack
.. index:: CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
.. _CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK:
@@ -63,6 +67,8 @@ NOTES:
:ref:`CONFIGURE_MP_APPLICATION` is defined.
+.. Generated from spec:/acfg/if/mp-appl
.. index:: CONFIGURE_MP_APPLICATION
.. _CONFIGURE_MP_APPLICATION:
@@ -91,6 +97,8 @@ NOTES:
build configuration option). Otherwise a compile time error in the
+.. Generated from spec:/acfg/if/mp-max-global-objects
.. index:: CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
.. _CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS:
@@ -122,6 +130,8 @@ NOTES:
+.. Generated from spec:/acfg/if/mp-max-nodes
.. index:: CONFIGURE_MP_MAXIMUM_NODES
.. _CONFIGURE_MP_MAXIMUM_NODES:
+.. Generated from spec:/acfg/if/mp-max-proxies
.. index:: CONFIGURE_MP_MAXIMUM_PROXIES
.. _CONFIGURE_MP_MAXIMUM_PROXIES:
@@ -184,6 +196,8 @@ NOTES:
+.. Generated from spec:/acfg/if/mp-mpci-table-pointer
.. index:: CONFIGURE_MP_MPCI_TABLE_POINTER
.. _CONFIGURE_MP_MPCI_TABLE_POINTER:
@@ -216,6 +230,8 @@ NOTES:
+.. Generated from spec:/acfg/if/mp-node-number
.. index:: CONFIGURE_MP_NODE_NUMBER
.. _CONFIGURE_MP_NODE_NUMBER:
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index 6e91205..886f1e6 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -15,6 +15,8 @@
+.. Generated from spec:/acfg/if/group-posix
POSIX API Configuration
@@ -23,6 +25,8 @@ POSIX API objects are available by default since RTEMS 5.1. The queued signals
and timers are only available if RTEMS was built with the ``--enable-posix``
build configuration option.
+.. Generated from spec:/acfg/if/max-posix-keys
.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
@@ -64,6 +68,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-posix-key-value-pairs
.. index:: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
.. _CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS:
@@ -111,6 +117,8 @@ NOTES:
A key value pair is created by :c:func:`pthread_setspecific` if the value
is not `NULL <https://en.cppreference.com/w/c/types/NULL>`_, otherwise it is deleted.
+.. Generated from spec:/acfg/if/max-posix-message-queues
.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
@@ -158,6 +166,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-posix-queued-signals
.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
@@ -203,6 +213,8 @@ NOTES:
Queued signals are only available if RTEMS was built with the
``--enable-posix`` build configuration option.
+.. Generated from spec:/acfg/if/max-posix-semaphores
.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
@@ -253,6 +265,8 @@ NOTES:
configuration option since the storage space for these semaphores is
user-provided.
+.. Generated from spec:/acfg/if/max-posix-shms
.. index:: CONFIGURE_MAXIMUM_POSIX_SHMS
.. _CONFIGURE_MAXIMUM_POSIX_SHMS:
@@ -298,6 +312,8 @@ NOTES:
+.. Generated from spec:/acfg/if/max-posix-threads
.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
@@ -348,6 +364,8 @@ NOTES:
All POSIX threads have floating point enabled.
+.. Generated from spec:/acfg/if/max-posix-timers
.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
@@ -397,6 +415,8 @@ NOTES:
Timers are only available if RTEMS was built with the
+.. Generated from spec:/acfg/if/min-posix-thread-stack-size
.. index:: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
.. index:: minimum POSIX thread stack size
diff --git a/c-user/config/posix-init-thread.rst b/c-user/config/posix-init-thread.rst
index deadbc6..08215e6 100644
--- a/c-user/config/posix-init-thread.rst
+++ b/c-user/config/posix-init-thread.rst
@@ -15,12 +15,16 @@
+.. Generated from spec:/acfg/if/group-posixinit
POSIX Initialization Thread Configuration
This section describes configuration options related to the POSIX
initialization thread.
+.. Generated from spec:/acfg/if/posix-init-thread-entry-point
.. index:: CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
.. _CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT:
option.
+.. Generated from spec:/acfg/if/posix-init-thread-stack-size
.. index:: CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
.. _CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE:
@@ -82,6 +88,8 @@ DESCRIPTION:
NOTES:
None.
+.. Generated from spec:/acfg/if/posix-init-thread-table
.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 8c60a96..2916cf7 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -16,6 +16,8 @@
+.. Generated from spec:/acfg/if/group-schedgeneral
General Scheduler Configuration
@@ -42,6 +44,8 @@ The pluggable scheduler interface also enables the user to provide their own
scheduling algorithm. If you choose to do this, you must define multiple
+.. Generated from spec:/acfg/if/cbs-max-servers
.. index:: CONFIGURE_CBS_MAXIMUM_SERVERS
.. _CONFIGURE_CBS_MAXIMUM_SERVERS:
@@ -78,6 +82,8 @@ NOTES:
:ref:`CONFIGURE_SCHEDULER_CBS` is defined.
+.. Generated from spec:/acfg/if/max-priority
.. index:: CONFIGURE_MAXIMUM_PRIORITY
.. index:: maximum priority
.. index:: number of priority levels
@@ -136,6 +142,8 @@ NOTES:
The default value is 255, because RTEMS shall support 256 priority levels to
be compliant with various standards. These priorities range from 0 to 255.
+.. Generated from spec:/acfg/if/scheduler-assignments
.. index:: CONFIGURE_SCHEDULER_ASSIGNMENTS
.. _CONFIGURE_SCHEDULER_ASSIGNMENTS:
@@ -177,6 +185,8 @@ NOTES:
This is an advanced configuration option, see
:ref:`ConfigurationSchedulersClustered`.
+.. Generated from spec:/acfg/if/scheduler-cbs
.. index:: CONFIGURE_SCHEDULER_CBS
.. _CONFIGURE_SCHEDULER_CBS:
@@ -206,6 +216,8 @@ NOTES:
In case no explicit :ref:`ConfigurationSchedulersClustered`
is present, then it is used as the scheduler for exactly one processor.
+.. Generated from spec:/acfg/if/scheduler-edf
.. index:: CONFIGURE_SCHEDULER_EDF
.. _CONFIGURE_SCHEDULER_EDF:
@@ -235,6 +247,8 @@ NOTES:
+.. Generated from spec:/acfg/if/scheduler-edf-smp
.. index:: CONFIGURE_SCHEDULER_EDF_SMP
.. _CONFIGURE_SCHEDULER_EDF_SMP:
@@ -271,6 +285,8 @@ NOTES:
:ref:`CONFIGURE_MAXIMUM_PROCESSORS` is
greater than one.
+.. Generated from spec:/acfg/if/scheduler-name
.. index:: CONFIGURE_SCHEDULER_NAME
.. _CONFIGURE_SCHEDULER_NAME:
@@ -319,6 +335,8 @@ NOTES:
Use :c:func:`rtems_build_name` to define the scheduler name.
+.. Generated from spec:/acfg/if/scheduler-priority
.. index:: CONFIGURE_SCHEDULER_PRIORITY
.. _CONFIGURE_SCHEDULER_PRIORITY:
@@ -355,6 +373,8 @@ NOTES:
The memory allocated for this scheduler depends on the
:ref:`CONFIGURE_MAXIMUM_PRIORITY` configuration option.
+.. Generated from spec:/acfg/if/scheduler-priority-affinity-smp
.. index:: CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
.. _CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP:
@@ -390,6 +410,8 @@ NOTES:
+.. Generated from spec:/acfg/if/scheduler-priority-smp
.. index:: CONFIGURE_SCHEDULER_PRIORITY_SMP
.. _CONFIGURE_SCHEDULER_PRIORITY_SMP:
@@ -425,6 +447,8 @@ NOTES:
+.. Generated from spec:/acfg/if/scheduler-simple
.. index:: CONFIGURE_SCHEDULER_SIMPLE
.. _CONFIGURE_SCHEDULER_SIMPLE:
@@ -454,6 +478,8 @@ NOTES:
+.. Generated from spec:/acfg/if/scheduler-simple-smp
.. index:: CONFIGURE_SCHEDULER_SIMPLE_SMP
.. _CONFIGURE_SCHEDULER_SIMPLE_SMP:
@@ -487,6 +513,8 @@ NOTES:
is present, then it is used as the scheduler for up to 32 processors.
+.. Generated from spec:/acfg/if/scheduler-strong-apa
.. index:: CONFIGURE_SCHEDULER_STRONG_APA
.. _CONFIGURE_SCHEDULER_STRONG_APA:
@@ -517,6 +545,8 @@ NOTES:
This scheduler algorithm is not correctly implemented. Do not use it.
+.. Generated from spec:/acfg/if/scheduler-user
.. index:: CONFIGURE_SCHEDULER_USER
.. _CONFIGURE_SCHEDULER_USER:
diff --git a/c-user/config/task-stack-alloc.rst b/c-user/config/task-stack-alloc.rst
index a567477..7dd95bb 100644
--- a/c-user/config/task-stack-alloc.rst
+++ b/c-user/config/task-stack-alloc.rst
@@ -15,6 +15,8 @@
+.. Generated from spec:/acfg/if/group-stackalloc
Task Stack Allocator Configuration
@@ -24,6 +26,8 @@ and deallocation methods for task stacks. This can be used to place task stacks
in special areas of memory or to utilize a Memory Management Unit so that stack
overflows are detected in hardware.
+.. Generated from spec:/acfg/if/task-stack-allocator
.. index:: CONFIGURE_TASK_STACK_ALLOCATOR
.. index:: task stack allocator
@@ -59,6 +63,8 @@ NOTES:
* :ref:`CONFIGURE_TASK_STACK_DEALLOCATOR`
+.. Generated from spec:/acfg/if/task-stack-no-workspace
.. index:: CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
.. _CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE:
@@ -84,6 +90,8 @@ NOTES:
This configuration option may be used if a custom task stack allocator is
configured, see :ref:`CONFIGURE_TASK_STACK_ALLOCATOR`.
+.. Generated from spec:/acfg/if/task-stack-allocator-init
.. index:: CONFIGURE_TASK_STACK_ALLOCATOR_INIT
.. _CONFIGURE_TASK_STACK_ALLOCATOR_INIT:
@@ -118,6 +126,8 @@ NOTES:
+.. Generated from spec:/acfg/if/task-stack-deallocator
.. index:: CONFIGURE_TASK_STACK_DEALLOCATOR
.. index:: task stack deallocator
* ``CONFIGURE_TASK_STACK_DEALLOCATOR``
+.. Generated from spec:/acfg/if/task-stack-from-alloc
.. index:: CONFIGURE_TASK_STACK_FROM_ALLOCATOR
2.26.2
