Need help debugging sp16.exe
Richi Dubey richidubey at gmail.com
Mon Oct 12 15:46:23 UTC 2020
> There are existing checks scattered throughout the source. Do any need to
> be in your scheduler?
I don't understand. If there are already checks scattered through, why do I
need more checks in my scheduler? Are these checks independent from the
checks I might need in the scheduler? Please explain.
+ Looks like the bsp has fast idle on but that should not impact anything.
What's fast idle? I found this
<https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac>.
:p How can time run as fast as possible?
+ Run this with the another scheduler and see if you can identify when that
> scheduler makes the decision you are missing. There has to be one of the
> scheduler hooks that is making a different decision. Run the test side by
> side with two different schedulers. Alternate forward motion in the two and
> compare the behaviour.
This is genius. Thanks a lot. I'm gonna work on this.
+ Adding trading might help but is probably more trouble to set up than
> just comparing good and bad schedulers in parallel.
What's trading?
+ Look at what every failing test is doing. May be a common issue and one
> is easier to debug
Thanks. I'll check this.
On Sun, Oct 11, 2020 at 5:08 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Oct 10, 2020, 10:47 AM Richi Dubey <richidubey at gmail.com> wrote:
>> Hi Mr. Huber,
>> Thanks for checking in.
>> I suggested to enable your new scheduler implementation as the default
>>> to check if it is in line with the standard schedulers. I would first
>>> get some high level data. Select a BSP with good test results on a
>>> simulator (for example sparc/leon3 or arm/realview_pbx_a9_qemu). Run the
>>> tests and record the test data. Then enable the SMP EDF scheduler as the
>>> default, run the tests, record the data. Then enable your scheduler as
>>> the default, run the tests, record the data. Then get all tests which
>>> fail only with your scheduler.
>> Yes, this is something I've already done based on your previous
>> suggestion. I set SCHEDULER_STRONG_APA(the current RTEMS master's version)
>> as the default scheduler for both sp and SMP and ran the test (on both
>> sparc/leon3 and arm/realview_pbx_a9_qemu). Then I set
>> SCHEDULER_STRONG_APA(my version) as the default scheduler for both sp and
>> SMP and ran the test and compared it with the master's strong apa result.
>> The following (extra) tests failed:
>>  sp02.exe
>>  sp16.exe
>>  sp30.exe
>>  sp31.exe
>>  sp37.exe
>>  sp42.exe
>>  spfatal29.exe
>>  tm24.exe
>> Do a high level analysis of all failing
>> tests. Try to figure out a new scenario for the test smpstrongapa01.
>> Okay, I would look into this. This is a great suggestion, thanks!
>> Do all the development with RTEMS_DEBUG enabled!
>>> Add _Assert() stuff to your scheduler. Check pre- and post-conditions of
>>> all operations. Check invariants.
>> How do I check postconditions? Using _Assert() or by manually debugging
>> each function call?
> Random thoughts:
> that scheduler makes the decision you are missing. There has to be one of
> the scheduler hooks that is making a different decision. Run the test side
> by side with two different schedulers. Alternate forward motion in the two
> and compare the behaviour.
> is easier to debug
> --joel
>> On Sat, Oct 10, 2020 at 6:09 PM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hello Richi,
>>> fail only with your scheduler. Do a high level analysis of all failing
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201012/57cb55d5/attachment-0001.html>
