RTEMS 5.1 pc686 BSP malloc_info problem?
Mon Oct 12 17:13:39 UTC 2020
On Mon, Oct 12, 2020 at 11:15 AM Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> Hi Chris,
> I'm not sure that I can easily create a test to show that this
> condition exists. I think the rtems_rfs_bitmap_create_search function
> works as it is intended to, but during the last iteration of the for
> loop, if 'size' is zero and 'bit' is 31, the 'search_map' variable is
> incremented once more, and the value of RTEMS_RFS_BITMAP_ELEMENT_CLEAR
> (0xFFFFFFFF) is written to that location. This location is one address
> beyond the memory that was allocated for the search_map in
> rtems_rfs_bitmap_open.
> I guess that most of the time this is a silent side effect, but my
> application just happened to have memory lined up such that the extra
> write causes the malloc Allocator mutex to fail, causing the
> malloc_info call to block indefinitely. I would consider this a lucky
> break!
> The exact same example application does not fail on RTEMS 4.11. I
> think the problem still exists, but in that case, the word that gets
> written is different.
> Here are some debug printfs from rtems_rfs_bitmap_open and
> rtems_rfs_bitmap_create_search:
> From rtems_rfs_bitmap_open:
> RFS - rtems_rfs_bitmap_open - search_bits malloced size = 16 bytes
> RFS - rtems_rfs_bitmap_open - addr of search_bits = 0x00C03814
> RFS -> size of search_map = 4
> RFS -> control->size = 4095
> From the subsequent call to rtems_rfs_bitmap_create_search:
> These printfs are in the if clause where bit == 31 (line 633)
> RFS --> search_map before increment addr 00C03814, size = 3071
> RFS --> search_map after increment -> writing
> RTEMS_RFS_BITMAP_ELEMENT_CLEAR (-1) to addr 00C03818
> RFS --> search_map before increment addr 00C03818, size = 2047
> RTEMS_RFS_BITMAP_ELEMENT_CLEAR (-1) to addr 00C0381C
> RFS --> search_map before increment addr 00C0381C, size = 1023
> RTEMS_RFS_BITMAP_ELEMENT_CLEAR (-1) to addr 00C03820
> RFS --> search_map before increment addr 00C03820, size = 0
> RTEMS_RFS_BITMAP_ELEMENT_CLEAR (-1) to addr 00C03824
> It's this last write to 00C03824 that causes the problem. I think the
> fix just involves checking to see if size == 0 before executing the if
> clause. I wanted to be sure that this extra write was not needed.
> If you have an idea for a test case, I can work on it, but if you
> think that this is good enough, I can propose a patch.
> Also, thanks for the idea of using RTEMS_DEBUG Sebastian, I need to
> upgrade my RTEMS toolbox with the latest techniques.
If, while analysing this issues, you came up with any consistency checks
or assertions that can be added to the code when debug is enabled,
those would be welcomed. It is hard to go back and add them without
the analysis like you did hunting this bug.
--joel
> Alan
> On Sun, Oct 11, 2020 at 6:20 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 10/10/20 7:35 am, Alan Cudmore wrote:
> > > After doing a lot of tracing through my application, it looks like
> > > malloc_info works fine before we start our cFS application, but it
> > > blocks after the cFS is initialized. This suggests some sort of memory
> > > corruption.
> > > I started by instrumenting our code to call malloc info during various
> > > stages of application initialization, and finally narrowed it down to
> > > the code where we create a RAM Disk and format it with RFS.
> > > (skipping a bunch of other malloc based troubleshooting.. )
> > > After I followed the issue into the RFS init, I was able to narrow
> > > down the place where malloc_info stopped working to here:
> https://git.rtems.org/rtems/tree/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c?h=5#n637
> > > During the RFS format process.
> > > In this section of the code, the size variable is 0, meaning it will
> > > exit the for loop and then return from the function, but it increments
> > > the "search_map" variable and writes to memory through the pointer one
> > > more time before exiting the loop and function. It's at this point
> > > where malloc_info starts blocking.
> > > It seems to me that this if block should be skipped when size == 0. I
> > > tried that and the malloc_info issue seems to be fixed.
> > Would you be able to create a test case for this? The test is ..
> > https://git.rtems.org/rtems/tree/testsuites/fstests/fsrfsbitmap01/test.c
> > Or if you could please provide the values in `control` I can add the
> test.
> > > Is this an RFS bug writing into other memory, or is this last write
> > > needed before the function updates?
> > It would seem so.
> > > If this looks like a bug, should I write a ticket and provide a patch?
> > Yes please. It would be nice to have a test case that fails so we can
> isolate
> > the cause.
> > Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201012/87cc0782/attachment.html>
