[PATCH 5/5] shell/main_edit.c: Fix string truncation warning
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Tue Oct 13 13:48:59 UTC 2020
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
Using strlcpy() instead of strncpy():
1) Prevents the compiler warnings
2) Ensures, the string is NUL terminated.
3) Avoids that strncpy() unnecessary fills the unused part of the buffer with
0 bytes.
(Note that realpath() also returns NULL if the file does not exist - that
happens always if someone creates a new file with the editor of the shell.)
cpukit/libmisc/shell/main_edit.c | 12 +++++++-----
1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
index 02214bd942..a0110495e8 100644
--- a/cpukit/libmisc/shell/main_edit.c
+++ b/cpukit/libmisc/shell/main_edit.c
@@ -283,11 +283,13 @@ static void delete_editor(struct editor *ed) {
static struct editor *find_editor(struct env *env, char *filename) {
- char fn[PATH_MAX];
+ char fnbuf[PATH_MAX];
+ char *fn = fnbuf;
struct editor *ed = env->current;
struct editor *start = ed;
- if (!realpath(filename, fn)) strncpy(fn, filename, FILENAME_MAX);
+ /* Note: When realpath() == NULL, usually the file doesn't exist */
+ if (!realpath(filename, fn)) { fn = filename; }
do {
if (strcmp(fn, ed->filename) == 0) return ed;
@@ -298,7 +300,7 @@ static struct editor *find_editor(struct env *env, char *filename) {
static int new_file(struct editor *ed, char *filename) {
if (*filename) {
- strncpy(ed->filename, filename, FILENAME_MAX);
+ strlcpy(ed->filename, filename, sizeof(ed->filename));
} else {
sprintf(ed->filename, "Untitled-%d", ++ed->env->untitled);
ed->newfile = 1;
@@ -1776,8 +1778,8 @@ static void save_editor(struct editor *ed) {
return;
- strncpy(
- ed->filename, (const char*) ed->env->linebuf, FILENAME_MAX);
+ strlcpy(
+ ed->filename, (const char*) ed->env->linebuf, sizeof(ed->filename));
ed->newfile = 0;
2.26.2
