[PATCH v2] rtems: Generate <rtems/io.h>
Gedare Bloom
gedare at rtems.org
Tue Oct 13 17:29:05 UTC 2020
On Sun, Oct 11, 2020 at 4:31 PM Chris Johns <chrisj at rtems.org> wrote:
> On 12/10/20 1:16 am, Sebastian Huber wrote:
> > On 08/10/2020 08:18, Sebastian Huber wrote:
> >> On 07/10/2020 21:12, Gedare Bloom wrote:
> >>> On Wed, Oct 7, 2020 at 11:40 AM Sebastian Huber
> >>> <sebastian.huber at embedded-brains.de> wrote:
> >>>> On 07/10/2020 17:26, Gedare Bloom wrote:
> >>>>> Thinking about the discussion about ordering directives in the docs,
> >>>>> the generated header reorders directives also. Is it also doing
> >>>>> generation by alphabetical order?
> >>>>> Should we consider using the same order as defined for the API
> >>>>> documentation? I guess this would make the Doxygen consistently
> >>>>> ordered wrt the docs.
> >>>> This would make things a lot more complicated. For the Doxygen we have
> >>>> to take also the C language into account. For example before you use a
> >>>> type, it must be declared. This is done through automatic dependency
> >>>> tracking and a topological sorting. Adding a manual order into this
> >>>> stuff would be difficult.
> >>> Yeah, maybe. The value of ordering in the headers and doxygen is
> >>> probably less than in a manual. We can revisit later if we like. It
> >>> shouldn't be too hard in an API header (as opposed to an
> >>> implementation header with inlines) to group first the typedefs and
> >>> then the function declarations. But I have no real concern about the
> >>> ordering here, it was just a thought.
> >> Good, I added a ticket for this:
> >> https://devel.rtems.org/ticket/4134#ticket
> >> It is not on my high priority list.
> > It turned out to be pretty easy to fix with a bubble sort:
> > https://git.rtems.org/rtems-central/commit/?id=3f3e088740abc2d00cf9986452bef81eae83260e
> Nice. The contextlib has changed since python 2, the redirect looks interesting.
> > Generated <rtems/io.h>:
> > https://git.rtems.org/rtems/tree/cpukit/include/rtems/io.h
This is much more readable. Thank you for figuring this out!
> Thank you.
> Chris
