[PATCH 5] libfs/rfs: Check search bit map end on last bit
chrisj at rtems.org chrisj at rtems.org
Thu Oct 15 06:40:32 UTC 2020
- Do not write past the last location of the search bit map
  whe nit is being created.
Closes #4149
 cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c | 17 +++++++++++++++--
 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
index 7973e85083..6da555d50e 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
@@ -34,6 +34,12 @@
 #include <rtems/rfs/rtems-rfs-bitmaps.h>
+#define rtems_rfs_bitmap_check(_c, _sm) \
+   _Assert(_sm >= _c->search_bits && \
+           _sm < (_c->search_bits + \
+             rtems_rfs_bitmap_elements(rtems_rfs_bitmap_elements(_c->size))))
  * Test a bit in an element. If set return true else return false.
@@ -220,6 +226,7 @@ rtems_rfs_bitmap_map_set (rtems_rfs_bitmap_control* control,
     index  = rtems_rfs_bitmap_map_index (bit);
     offset = rtems_rfs_bitmap_map_offset (bit);
     search_map[index] = rtems_rfs_bitmap_set (search_map[index], 1 << offset);
+    rtems_rfs_bitmap_check(control, &search_map[index]);
   return 0;
@@ -260,6 +267,7 @@ rtems_rfs_bitmap_map_clear (rtems_rfs_bitmap_control* control,
   offset            = rtems_rfs_bitmap_map_offset(bit);
   search_map[index] = rtems_rfs_bitmap_clear (search_map[index], 1 << offset);
   rtems_rfs_buffer_mark_dirty (control->buffer);
   control->free++;
@@ -599,6 +607,7 @@ rtems_rfs_bitmap_create_search (rtems_rfs_bitmap_control* control)
   size = control->size;
   bit = 0;
+  rtems_rfs_bitmap_check(control, search_map);
   *search_map = RTEMS_RFS_BITMAP_ELEMENT_CLEAR;
   while (size)
@@ -633,8 +642,12 @@ rtems_rfs_bitmap_create_search (rtems_rfs_bitmap_control* control)
     if (bit == (rtems_rfs_bitmap_element_bits () - 1))
       bit = 0;
-      search_map++;
-      *search_map = RTEMS_RFS_BITMAP_ELEMENT_CLEAR;
+      if (size > 0)
+        search_map++;
+        *search_map = RTEMS_RFS_BITMAP_ELEMENT_CLEAR;
     else
       bit++;
2.24.1
