[rtems commit] rtems-fdt / shell - Fix string truncation warning
Chris Johns
chrisj at rtems.org
Fri Oct 16 04:50:30 UTC 2020
On 16/10/20 3:47 pm, Sebastian Huber wrote:
> On 16/10/2020 06:38, Chris Johns wrote:
>>> * has no tests,
>> And all the other commands have tests?
> No, so this is admittedly not a very strong argument.
> It is a general problem that the shell code has little to no test coverage.
> Fixing bugs and warnings in this area is always a bit risky. Most recent
> warnings were in this area.
Yes. I have started to consider some sort of `expect` type support for
rtems-test to handle input side but I have no idea how we could know the output
is OK? A basic compare would make the tests fragile.
