[PATCHv2 01/26] sparc: Remove sequences that the B2BST scan script warns about
Daniel Hellstrom
daniel at gaisler.com
Fri Oct 16 12:01:15 UTC 2020
Update #4154.
cpukit/score/cpu/sparc/cpu_asm.S | 6 ++++--
cpukit/score/cpu/sparc/syscall.S | 3 ++-
2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
index d5afd5f..bfad3fb 100644
--- a/cpukit/score/cpu/sparc/cpu_asm.S
+++ b/cpukit/score/cpu/sparc/cpu_asm.S
@@ -683,11 +683,13 @@ isr_dispatch:
cmp %l6, %l7
bne,a .Ldisable_fp
andn %l0, %l5, %l0
+ st %g0, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
ba .Lthread_dispatch_done
- st %g0, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
+ nop
.Ldisable_fp:
+ st %l0, [%fp + ISF_PSR_OFFSET]
- st %l0, [%fp + ISF_PSR_OFFSET]
+ nop
.Lnon_fp_thread_dispatch:
#elif defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
/* Test if we interrupted a floating point thread (PSR[EF] == 1) */
diff --git a/cpukit/score/cpu/sparc/syscall.S b/cpukit/score/cpu/sparc/syscall.S
index 4f4ef32..737a501 100644
--- a/cpukit/score/cpu/sparc/syscall.S
+++ b/cpukit/score/cpu/sparc/syscall.S
@@ -218,9 +218,10 @@ SYM(syscall_lazy_fp_switch):
.Lfp_save_done:
/* Restore the floating point context if necessary */
+ st %g0, [%l4 + %lo(SPARC_THREAD_CONTROL_REGISTERS_FP_CONTEXT_OFFSET)]
cmp %l6, 0
be .Lfp_restore_done
- st %g0, [%l4 + %lo(SPARC_THREAD_CONTROL_REGISTERS_FP_CONTEXT_OFFSET)]
+ nop
ldd [%l6 + SPARC_FP_CONTEXT_OFFSET_F0_F1], %f0
ldd [%l6 + SPARC_FP_CONTEXT_OFFSET_F2_F3], %f2
ldd [%l6 + SPARC_FP_CONTEXT_OFFSET_F4_F5], %f4
2.7.4
