[PATCHv4 08/26] leon, can: introduce common CAN baud-rate calculation function
Daniel Hellstrom
daniel at gaisler.com
Fri Oct 16 12:30:42 UTC 2020
Reimplemented the baud-rate algorithm from scratch to cope with
GRCAN, GRCANFD and OC_CAN devices.
bsps/headers.am | 1 +
bsps/include/grlib/canbtrs.h | 80 ++++++++++++++++++++++
bsps/shared/grlib-sources.am | 1 +
bsps/shared/grlib/can/canbtrs.c | 143 ++++++++++++++++++++++++++++++++++++++++
4 files changed, 225 insertions(+)
create mode 100644 bsps/include/grlib/canbtrs.h
create mode 100644 bsps/shared/grlib/can/canbtrs.c
diff --git a/bsps/headers.am b/bsps/headers.am
index 5af7e43..2c9b31d 100644
--- a/bsps/headers.am
+++ b/bsps/headers.am
@@ -34,6 +34,7 @@ include_grlib_HEADERS += ../../bsps/include/grlib/apbuart_termios.h
include_grlib_HEADERS += ../../bsps/include/grlib/b1553brm.h
include_grlib_HEADERS += ../../bsps/include/grlib/b1553rt.h
include_grlib_HEADERS += ../../bsps/include/grlib/bspcommon.h
+include_grlib_HEADERS += ../../bsps/include/grlib/canbtrs.h
include_grlib_HEADERS += ../../bsps/include/grlib/canmux.h
include_grlib_HEADERS += ../../bsps/include/grlib/cons.h
include_grlib_HEADERS += ../../bsps/include/grlib/debug_defs.h
diff --git a/bsps/include/grlib/canbtrs.h b/bsps/include/grlib/canbtrs.h
new file mode 100644
index 0000000..7bd038b
--- /dev/null
+++ b/bsps/include/grlib/canbtrs.h
@@ -0,0 +1,80 @@
+ * @file
+ * @ingroup can
+ * @brief Common CAN baud-rate routines for OCCAN/GRCAN/GRCANFD controllers
+ * Copyright (C) 2019, 2020 Cobham Gaisler AB
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef __GRLIB_CANBTRS_H__
+#define __GRLIB_CANBTRS_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* CAN Baud-rate parameters, range of valid parameter values */
+struct grlib_canbtrs_ranges {
+ unsigned int max_scaler;
+ char has_bpr;
+ unsigned char divfactor;
+ unsigned char min_tseg1;
+ unsigned char max_tseg1;
+ unsigned char min_tseg2;
+ unsigned char max_tseg2;
+struct grlib_canbtrs_timing {
+ unsigned char scaler;
+ unsigned char ps1;
+ unsigned char ps2;
+ unsigned char rsj;
+ unsigned char bpr;
+/* Calculate CAN baud-rate generation parameters from requested baud-rate
+ * @param baud The CAN baud rate requested
+ * @param core_hz Input clock [Hz] to CAN core
+ * @param sampl_pt CAN sample point in %, 80 means 80%
+ * @param br CAN Baud-rate parameters limitations
+ * @param[out] timing result is placed here
+int grlib_canbtrs_calc_timing(
+ unsigned int baud,
+ unsigned int core_hz,
+ unsigned int sampl_pt,
+ struct grlib_canbtrs_ranges *br,
+ struct grlib_canbtrs_timing *timing
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/shared/grlib-sources.am b/bsps/shared/grlib-sources.am
index 512a48c..f2ad1bf 100644
--- a/bsps/shared/grlib-sources.am
+++ b/bsps/shared/grlib-sources.am
@@ -20,6 +20,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/ascs/grascs.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/btimer/gptimer.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/btimer/tlib.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/btimer/tlib_ckinit.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/canbtrs.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/canmux.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/grcan.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/grlib/can/occan.c
diff --git a/bsps/shared/grlib/can/canbtrs.c b/bsps/shared/grlib/can/canbtrs.c
index 0000000..d28efbc
--- /dev/null
+++ b/bsps/shared/grlib/can/canbtrs.c
@@ -0,0 +1,143 @@
+ * @file
+ * @ingroup can
+ * Implements common routines for calculating CAN baud-rate parameters from
+ * a user provided baud-rate speed.
+ * Copyright (C) 2019, 2020 Cobham Gailer AB
+ * are met:
+#include <grlib/canbtrs.h>
+/*#define GRLIB_CANBTRS_DEBUG*/
+/* Calculate CAN baud-rate generation parameters from requested baud-rate */
+ int best_error = 2000000000, best_tseg=0, best_scaler=0;
+ int tseg=0, tseg1=0, tseg2=0, sc, error;
+ /* Default to 80% sample point */
+ if ((sampl_pt < 50) || (sampl_pt > 99))
+ sampl_pt = 80;
+ /* step though all TSEG1+TSEG2 values possible */
+ for (tseg = (br->min_tseg1 + br->min_tseg2);
+ tseg <= (br->max_tseg1 + br->max_tseg2);
+ tseg++) {
+ /* calculate scaler */
+ sc = core_hz / ((br->divfactor + tseg) * baud);
+ if (sc <= 0 || sc > br->max_scaler)
+ continue;
+ if (br->has_bpr &&
+ (((sc > 256 * 1) && (sc <= 256 * 2) && (sc & 0x1)) ||
+ ((sc > 256 * 2) && (sc <= 256 * 4) && (sc & 0x3)) ||
+ ((sc > 256 * 4) && (sc <= 256 * 8) && (sc & 0x7))))
+ continue;
+ error = baud - core_hz / (sc * (br->divfactor + tseg));
+#ifdef GRLIB_CANBTRS_DEBUG
+ printf(" baud=%d, tseg=%d, sc=%d, error=%d\n",
+ baud, tseg, sc, error);
+#endif
+ if (error < 0)
+ error = -error;
+ /* tseg is increasing, so we accept higher tseg with the same
+ * baudrate to get better sampling point.
+ if (error <= best_error) {
+ best_error = error;
+ best_tseg = tseg;
+ best_scaler = sc;
+ printf(" ! best baud=%d\n",
+ core_hz/(sc * (br->divfactor + tseg)));
+#endif
+ /* return an error if 5% off baud-rate */
+ if (best_error && (baud / best_error <= 5)) {
+ return -2;
+ } else if (!timing) {
+ return 0; /* nothing to store result in, but a valid bitrate can be calculated */
+ tseg2 = (best_tseg + br->divfactor) -
+ ((sampl_pt * (best_tseg + br->divfactor)) / 100);
+ if (tseg2 < br->min_tseg2) {
+ tseg2 = br->min_tseg2;
+ } else if (tseg2 > br->max_tseg2) {
+ tseg2 = br->max_tseg2;
+ tseg1 = best_tseg - tseg2;
+ if (tseg1 > br->max_tseg1) {
+ tseg1 = br->max_tseg1;
+ tseg2 = best_tseg - tseg1;
+ } else if (tseg1 < br->min_tseg1) {
+ tseg1 = br->min_tseg1;
+ /* Get scaler and BPR from pseudo SCALER clock */
+ if (best_scaler <= 256) {
+ timing->scaler = best_scaler - 1;
+ timing->bpr = 0;
+ } else if (best_scaler <= 256 * 2) {
+ timing->scaler = ((best_scaler + 1) >> 1) - 1;
+ timing->bpr = 1;
+ } else if (best_scaler <= 256 * 4) {
+ timing->scaler = ((best_scaler + 1) >> 2) - 1;
+ timing->bpr = 2;
+ } else {
+ timing->scaler = ((best_scaler + 1) >> 3) - 1;
+ timing->bpr = 3;
+ timing->ps1 = tseg1;
+ timing->ps2 = tseg2;
+ timing->rsj = 1;
+ printf(" ! result: sc=%d,bpr=%d,ps1=%d,ps2=%d\n", timing->scaler, timing->bpr, timing->ps1, timing->ps2);
+#endif
+ return 0;
2.7.4
