[rtems commit] posix: Fix pthread_spin_unlock()
Joel Sherrill
joel at rtems.org
Mon Oct 19 15:42:09 UTC 2020
This was reported against 4.11 which means it needs to be committed to
4.11, 5, and master.
--joel
On Mon, Oct 19, 2020 at 10:33 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: 2b9fb3141cb10b8bbfa1a18a6aab42474988a636
> Changeset:
> http://git.rtems.org/rtems/commit/?id=2b9fb3141cb10b8bbfa1a18a6aab42474988a636
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Mon Oct 19 16:31:51 2020 +0200
> Prevent a call to _SMP_lock_Stats_register_or_max_section_time(). This
> fixes a
> thread stack corruption in case RTEMS_PROFILING and RTEMS_SMP is enabled.
> Close #4157.
> cpukit/posix/src/pspinunlock.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/posix/src/pspinunlock.c
> b/cpukit/posix/src/pspinunlock.c
> index ca36a5f..5c02012 100644
> --- a/cpukit/posix/src/pspinunlock.c
> +++ b/cpukit/posix/src/pspinunlock.c
> @@ -40,7 +40,7 @@ int pthread_spin_unlock( pthread_spinlock_t *lock )
> #if defined(RTEMS_PROFILING)
> /* This is a hack to get around the lock profiling statistics */
> unused_stats.total_section_time = 0;
> - unused_stats.max_section_time = 0;
> + unused_stats.max_section_time = UINT32_MAX;
> unused_context.stats = &unused_stats;
> unused_context.acquire_instant = 0;
> #endif
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201019/c828476f/attachment.html>
