[rtems commit] posix: Fix pthread_spin_unlock()
Gedare Bloom
gedare at rtems.org
Mon Oct 19 18:06:13 UTC 2020
On Mon, Oct 19, 2020 at 11:11 AM Sebastian Huber
> On 19/10/2020 18:53, Gedare Bloom wrote:
> > On Mon, Oct 19, 2020 at 9:48 AM Sebastian Huber
> >> On 19/10/2020 17:42, Joel Sherrill wrote:
> >>> This was reported against 4.11 which means it needs to be committed to
> >>> 4.11, 5, and master.
> >> It depends on the severity of the bug if I create tickets and back ports
> >> for this right now.
> > If we know the bug exists we should at least create tickets on the
> > open, affected branch(es).
> > When we know how to fix it, we should also at least reference that as
> > well. This way someone else can make the fix easier if they need it.
> I thought this is the purpose of the "version" field?
https://lists.rtems.org/pipermail/devel/2018-August/050685.html
The problem is that for example this ticket #4157 is closed. So how
does someone know the bug isn't fixed in 4.11 and 5?
It is a problem we face and why we end up duplicating all these
tickets in the first place. I don't know (if there is) a right answer.
-Gedare
