[PATCH v2] User Manual languages section
Tue Oct 20 15:55:01 UTC 2020
On Mon, Oct 19, 2020 at 4:27 PM Chris Johns <chrisj at rtems.org> wrote:
> On 20/10/20 2:43 am, Joel Sherrill wrote:
> > On Mon, Oct 19, 2020 at 10:20 AM Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> >     Thanks for this. Someone should at least add TBD stubs for a few
> >     languages. If we say nothing, the assumption is there is nothing to
> >     say. You can open a ticket, assign it to me if you like. It will take
> >     some research to find the set of languages.
> > +1 Please add a TBD section for at least C and Ada along with a comment
> > that points to a ticket for it.
> > This will get lost otherwise.
> I am happy to add TBD sections and tickets for languages if there is a list to
> create.
There's a hint at user/overview/index.rst :57
There used to be a broader list somewhere but I think that has been
lost to time, and who knows if it was correct.
> I removed Ada because Joel suggested Fortran if the RSB can build it. I then
> started to think, I do not build Ada ot Fortran so maybe I should not add things
> I am not sure about.
> Chris
