[rtems commit] posix: Fix pthread_spin_unlock()
Wed Oct 21 00:26:52 UTC 2020
On 21/10/20 3:01 am, Gedare Bloom wrote:
> On Mon, Oct 19, 2020 at 10:59 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 20/10/2020 00:17, Chris Johns wrote:
>>> On 20/10/20 5:06 am, Gedare Bloom wrote:
>>>> On Mon, Oct 19, 2020 at 11:11 AM Sebastian Huber
>>>>> On 19/10/2020 18:53, Gedare Bloom wrote:
>>>>>> On Mon, Oct 19, 2020 at 9:48 AM Sebastian Huber
>>>>>>> On 19/10/2020 17:42, Joel Sherrill wrote:
>>>>>>>> This was reported against 4.11 which means it needs to be committed to
>>>>>>>> 4.11, 5, and master.
>>>>>>> It depends on the severity of the bug if I create tickets and back ports
>>>>>>> for this right now.
>>>>>> If we know the bug exists we should at least create tickets on the
>>>>>> open, affected branch(es).
>>>>>> When we know how to fix it, we should also at least reference that as
>>>>>> well. This way someone else can make the fix easier if they need it.
>>>>> I thought this is the purpose of the "version" field?
>>>> https://lists.rtems.org/pipermail/devel/2018-August/050685.html
>>>> The problem is that for example this ticket #4157 is closed. So how
>>>> does someone know the bug isn't fixed in 4.11 and 5?
>>>> It is a problem we face and why we end up duplicating all these
>>>> tickets in the first place. I don't know (if there is) a right answer.
>>> I think cloning tickets is the best solution we have. I cannot see a better path.
>> Not everything is equally important.
>> I did run the test suite in an unusual configuration, identified two
>> unexpected test failures, debugged the tests, reported two issues with
>> the first affected RTEMS version and a target milestone, and fixed the
>> issues on the master. This is enough work for bugs which probably affect
>> only one person on this planet.
> I agree with this perspective as a philosophical point. Although, I
> suspect there are GSoC students who ran the testsuite on 5 with SMP
> enabled and PROFILING turned on. So whether a bug is so esoteric no
> one else will encounter it is something of a subjective opinion.
> But as a rule/standard, we should at least document known bugs on our
> open branch (last released). This means if the bug is known to exist
> on 5, there should be a ticket for it. Whether or not you want to fix
> it is irrelevant. If creating a ticket is too much work, just say so
> and maybe someone else will be bothered enough to handle it.
+1
