Updated network-demos ...?
Joel Sherrill
joel at rtems.org
Wed Oct 21 13:13:31 UTC 2020
On Wed, Oct 21, 2020 at 3:15 AM Jiri Gaisler <jiri at gaisler.se> wrote:
> Does anyone have more a updated version of network-demos than what is in
> https://git.rtems.org/network-demos/ ?
> This version does not compile fully with RTEMS-6 and seems to be rather
> outdated.
> If not, then I will try to fix the issues - just want to check if someone
> has already done this.
The tests/demos for rtems-libbsd are in the rtems-libbsd tree. The
network-demos
tree is for the legacy stack and I don't know when it was last touched.
https://git.rtems.org/rtems-libbsd/tree/testsuite
--joel
> Jiri.
> (I am trying to add network support to sis, so I need some test software
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201021/2d640fe1/attachment.html>
