[PATCH 2/3] Add networking support for griscv bsp
Jiri Gaisler
jiri at gaisler.se
Sun Oct 25 22:26:25 UTC 2020
* Only GRETH device supported for now
* Fix endian problem in GRETH driver
bsps/riscv/griscv/include/bsp.h | 14 ++++++
bsps/riscv/griscv/net/leon_greth.c | 59 +++++++++++++++++++++++
bsps/shared/net/greth2.c | 6 ++-
c/src/lib/libbsp/riscv/griscv/Makefile.am | 6 +++
4 files changed, 84 insertions(+), 1 deletion(-)
create mode 100644 bsps/riscv/griscv/net/leon_greth.c
diff --git a/bsps/riscv/griscv/include/bsp.h b/bsps/riscv/griscv/include/bsp.h
index 95cccd3d0a..b0d72475cc 100644
--- a/bsps/riscv/griscv/include/bsp.h
+++ b/bsps/riscv/griscv/include/bsp.h
@@ -75,6 +75,20 @@ extern void BSP_shared_interrupt_mask(int irq);
extern void BSP_shared_interrupt_clear(int irq);
extern void BSP_shared_interrupt_unmask(int irq);
+ * Network driver configuration, use leon3 version
+struct rtems_bsdnet_ifconfig;
+extern int rtems_leon_greth_driver_attach(
+ struct rtems_bsdnet_ifconfig *config,
+ int attach
+#define RTEMS_BSP_NETWORK_DRIVER_NAME "gr_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_leon_greth_driver_attach
+#define GRETH_SUPPORTED
+#define CPU_U32_FIX
#ifdef __cplusplus
#endif
diff --git a/bsps/riscv/griscv/net/leon_greth.c b/bsps/riscv/griscv/net/leon_greth.c
new file mode 100644
index 0000000000..eb5dedd413
--- /dev/null
+++ b/bsps/riscv/griscv/net/leon_greth.c
@@ -0,0 +1,59 @@
+ * LEON3 Opencores Ethernet MAC Configuration Information
+ * COPYRIGHT (c) 2004.
+ * Gaisler Research
+#include <machine/rtems-bsd-kernel-space.h>
+#include <bsp.h>
+#include <amba.h>
+#include <grlib/ambapp.h>
+#include <libchip/greth.h>
+/*#if (GRETH_DEBUG & GRETH_DEBUG_PRINT_REGISTERS)*/
+#include <stdio.h>
+/*#endif*/
+ * Default sizes of transmit and receive descriptor areas
+#define RDA_COUNT 32
+#define TDA_COUNT 32
+greth_configuration_t leon_greth_configuration;
+int rtems_leon_greth_driver_attach(
+ int attach
+ unsigned int base_addr = 0; /* avoid warnings */
+ unsigned int eth_irq = 0; /* avoid warnings */
+ struct ambapp_dev *adev;
+ struct ambapp_apb_info *apb;
+ /* Scan for MAC AHB slave interface */
+ adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
+ VENDOR_GAISLER, GAISLER_ETHMAC,
+ ambapp_find_by_idx, NULL);
+ if (adev) {
+ apb = DEV_TO_APB(adev);
+ base_addr = apb->start;
+ eth_irq = apb->irq;
+ /* clear control register and reset NIC */
+ *(volatile int *) base_addr = 0;
+ *(volatile int *) base_addr = GRETH_CTRL_RST;
+ leon_greth_configuration.base_address = (void*)base_addr;
+ leon_greth_configuration.vector = eth_irq; /* on LEON vector is IRQ no. */
+ leon_greth_configuration.txd_count = TDA_COUNT;
+ leon_greth_configuration.rxd_count = RDA_COUNT;
+ rtems_greth_driver_attach(config, &leon_greth_configuration);
+ return 0;
diff --git a/bsps/shared/net/greth2.c b/bsps/shared/net/greth2.c
index 2fc35a5471..13bf7b8884 100644
--- a/bsps/shared/net/greth2.c
+++ b/bsps/shared/net/greth2.c
@@ -21,6 +21,7 @@
#include <rtems/bspIo.h>
+#include <string.h>
#include <stdarg.h>
#include <rtems/error.h>
@@ -514,6 +515,9 @@ void ipalign(struct mbuf *m)
unsigned int tmp;
if ((((int) m->m_data) & 2) && (m->m_len)) {
+#if CPU_LITTLE_ENDIAN == TRUE
+ memmove((caddr_t)(((int) m->m_data) + 2), m->m_data, m->m_len);
+#else
last = (unsigned int *) ((((int) m->m_data) + m->m_len + 8) & ~3);
first = (unsigned int *) (((int) m->m_data) & ~3);
tmp = GRETH_MEM_LOAD(first);
@@ -529,7 +533,7 @@ void ipalign(struct mbuf *m)
tmp = data << 16;
first++;
} while (first <= last);
+#endif
m->m_data = (caddr_t)(((int) m->m_data) + 2);
diff --git a/c/src/lib/libbsp/riscv/griscv/Makefile.am b/c/src/lib/libbsp/riscv/griscv/Makefile.am
index e04598e4bf..221255d0c7 100644
--- a/c/src/lib/libbsp/riscv/griscv/Makefile.am
+++ b/c/src/lib/libbsp/riscv/griscv/Makefile.am
@@ -64,6 +64,12 @@ if HAS_SMP
librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/griscv/start/bspsmp.c
endif
+if HAS_NETWORKING
+if !HAS_SMP
+librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/griscv/net/leon_greth.c
+endif
+endif
include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
include $(srcdir)/../../../../../../bsps/shared/grlib-sources.am
include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
2.17.1
