[PATCH 1/3] Remove duplicate GRETH driver
Jiri Gaisler jiri at gaisler.se
Sun Oct 25 22:56:50 UTC 2020
On 10/25/20 6:35 PM, Joel Sherrill wrote:
> Is the code deleted referenced in the new build system?
Good question! I don't really know how the new systems works to answer
that. I could only remove the references from the .am files...
> On Sun, Oct 25, 2020, 5:26 PM Jiri Gaisler <jiri at gaisler.se
> <mailto:jiri at gaisler.se>> wrote:
>             * bsps/shared/net/greth2.c is being used instead
>      bsps/shared/grlib-sources.am <http://grlib-sources.am>
>           |    4 -
>      bsps/shared/grlib/net/README                  |    7 -
>      bsps/shared/grlib/net/greth.c                 | 1655
>      bsps/shared/grlib/net/network_interface_add.c |   62 -
>      4 files changed, 1728 deletions(-)
>      delete mode 100644 bsps/shared/grlib/net/README
>      delete mode 100644 bsps/shared/grlib/net/greth.c
>      delete mode 100644 bsps/shared/grlib/net/network_interface_add.c
>     diff --git a/bsps/shared/grlib-sources.am
>     <http://grlib-sources.am> b/bsps/shared/grlib-sources.am
>     index 512a48c7f7..2261eb957f 100644
>     --- a/bsps/shared/grlib-sources.am <http://grlib-sources.am>
>     +++ b/bsps/shared/grlib-sources.am <http://grlib-sources.am>
>     @@ -34,10 +34,6 @@ librtemsbsp_a_SOURCES +=
>     ../../../../../../bsps/shared/grlib/iommu/griommu.c
>     ../../../../../../bsps/shared/grlib/irq/genirq.c
>     ../../../../../../bsps/shared/grlib/l2c/l2c.c
>     ../../../../../../bsps/shared/grlib/mem/mctrl.c
>     -if HAS_NETWORKING
>     -librtemsbsp_a_SOURCES +=
>     ../../../../../../bsps/shared/grlib/net/greth.c
>     ../../../../../../bsps/shared/grlib/net/network_interface_add.c
>     -endif
>     ../../../../../../bsps/shared/grlib/pci/gr_701.c
>     ../../../../../../bsps/shared/grlib/pci/grpci2.c
>     ../../../../../../bsps/shared/grlib/pci/grpci2dma.c
>     diff --git a/bsps/shared/grlib/net/README
>     b/bsps/shared/grlib/net/README
>     deleted file mode 100644
>     index 3ef086f223..0000000000
>     --- a/bsps/shared/grlib/net/README
>     +++ /dev/null
>     @@ -1,7 +0,0 @@
>     -A non Driver Manager GRETH driver is located in
>     libchip/network/greth.c. This
>     -version requires the driver manager.
>     -network_interface_add is used to assign IP/NETMASK and MAC address to
>     -GRETH interfaces dynamically according to in which order devices are
>     -registered. The function takes the settings from the user defined
>     -interface_configs[] array, defined in the project configuration.
>     diff --git a/bsps/shared/grlib/net/greth.c
>     b/bsps/shared/grlib/net/greth.c
>     index bc4d3cc40f..0000000000
>     --- a/bsps/shared/grlib/net/greth.c
>     +++ /dev/null
>     @@ -1,1655 +0,0 @@
>     - * Gaisler Research ethernet MAC driver
>     - * adapted from Opencores driver by Marko Isomaki
>     - *  The license and distribution terms for this file may be
>     - *  found in found in the file LICENSE in this distribution or at
>     - *  http://www.rtems.org/license/LICENSE.
>     - *  2008-12-10, Converted to driver manager and added support for
>     - *              multiple GRETH cores. <daniel at gaisler.com
>     <mailto:daniel at gaisler.com>>
>     - *  2007-09-07, Ported GBIT support from 4.6.5
>     -#include <machine/rtems-bsd-kernel-space.h>
>     -#include <rtems.h>
>     -#define CPU_U32_FIX
>     -#include <bsp.h>
>     -#ifdef GRETH_SUPPORTED
>     -#include <inttypes.h>
>     -#include <errno.h>
>     -#include <rtems/bspIo.h>
>     -#include <stdlib.h>
>     -#include <stdio.h>
>     -#include <stdarg.h>
>     -#include <rtems/error.h>
>     -#include <rtems/rtems_bsdnet.h>
>     -#include <grlib/greth.h>
>     -#include <drvmgr/drvmgr.h>
>     -#include <grlib/ambapp_bus.h>
>     -#include <grlib/ambapp.h>
>     -#include <sys/param.h>
>     -#include <sys/mbuf.h>
>     -#include <sys/socket.h>
>     -#include <sys/sockio.h>
>     -#include <net/if.h>
>     -#include <netinet/in.h>
>     -#include <netinet/if_ether.h>
>     -#ifdef malloc
>     -#undef malloc
>     -#endif
>     -#ifdef free
>     -#undef free
>     -#endif
>     -#include <grlib/grlib_impl.h>
>     -#if defined(__m68k__)
>     -extern m68k_isr_entry set_vector( rtems_isr_entry,
>     rtems_vector_number, int );
>     -#else
>     -extern rtems_isr_entry set_vector( rtems_isr_entry,
>     -#endif
>     -/* #define GRETH_DEBUG */
>     -#ifdef GRETH_DEBUG
>     -#define DBG(args...) printk(args)
>     -#else
>     -#endif
>     -/* #define GRETH_DEBUG_MII */
>     -#ifdef GRETH_DEBUG_MII
>     -#define MIIDBG(args...) printk(args)
>     -#else
>     -#endif
>     -#ifdef CPU_U32_FIX
>     -extern void ipalign(struct mbuf *m);
>     -#endif
>     -/* Used when reading from memory written by GRETH DMA unit */
>     -#ifndef GRETH_MEM_LOAD
>     -#define GRETH_MEM_LOAD(addr) (*(volatile unsigned int *)(addr))
>     -#endif
>     - * Number of OCs supported by this driver
>     -#define NOCDRIVER      1
>     - * Receive buffer size -- Allow for a full ethernet packet
>     including CRC
>     -#define RBUF_SIZE 1518
>     -#define        ET_MINLEN 64            /* minimum message length */
>     - * RTEMS event used by interrupt handler to signal driver tasks.
>     - * This must not be any of the events used by the network task
>     synchronization.
>     -#define INTERRUPT_EVENT        RTEMS_EVENT_1
>     - * RTEMS event used to start transmit daemon.
>     - * This must not be the same as INTERRUPT_EVENT.
>     -#define START_TRANSMIT_EVENT   RTEMS_EVENT_2
>     - /* event to send when tx buffers become available */
>     -#define GRETH_TX_WAIT_EVENT  RTEMS_EVENT_3
>     -#if (MCLBYTES < RBUF_SIZE)
>     -# error "Driver must have MCLBYTES > RBUF_SIZE"
>     -#endif
>     -/* 4s Autonegotiation Timeout */
>     -#ifndef GRETH_AUTONEGO_TIMEOUT_MS
>     -#define GRETH_AUTONEGO_TIMEOUT_MS 4000
>     -#endif
>     -const struct timespec greth_tan = {
>     -   GRETH_AUTONEGO_TIMEOUT_MS/1000,
>     -   (GRETH_AUTONEGO_TIMEOUT_MS % 1000) * 1000000
>     -/* For optimizing the autonegotiation time */
>     -#define GRETH_AUTONEGO_PRINT_TIME
>     -/* Ethernet buffer descriptor */
>     -typedef struct _greth_rxtxdesc {
>     -   volatile uint32_t ctrl; /* Length and status */
>     -   uint32_t *addr;         /* Buffer pointer */
>     -} greth_rxtxdesc;
>     - * Per-device data
>     -struct greth_softc
>     -   struct arpcom arpcom;
>     -   struct drvmgr_dev *dev;             /* Driver manager device */
>     -   char devName[32];
>     -   greth_regs *regs;
>     -   int minor;
>     -   int phyaddr;  /* PHY Address configured by user (or -1 to
>     autodetect) */
>     -   unsigned int edcl_dis;
>     -   int greth_rst;
>     -   int acceptBroadcast;
>     -   rtems_id daemonTid;
>     -   unsigned int tx_ptr;
>     -   unsigned int tx_dptr;
>     -   unsigned int tx_cnt;
>     -   unsigned int rx_ptr;
>     -   unsigned int txbufs;
>     -   unsigned int rxbufs;
>     -   greth_rxtxdesc *txdesc;
>     -   greth_rxtxdesc *rxdesc;
>     -   unsigned int txdesc_remote;
>     -   unsigned int rxdesc_remote;
>     -   struct mbuf **rxmbuf;
>     -   struct mbuf **txmbuf;
>     -   rtems_vector_number vector;
>     -   /* TX descriptor interrupt generation */
>     -   int tx_int_gen;
>     -   int tx_int_gen_cur;
>     -   struct mbuf *next_tx_mbuf;
>     -   int max_fragsize;
>     -   /*Status*/
>     -   struct phy_device_info phydev;
>     -   int phy_read_access;
>     -   int phy_write_access;
>     -   int fd;
>     -   int sp;
>     -   int gb;
>     -   int gbit_mac;
>     -   int auto_neg;
>     -   unsigned int advmodes; /* advertise ethernet speed modes. 0 =
>     all modes. */
>     -   struct timespec auto_neg_time;
>     -   int mc_available;
>     -    * Statistics
>     -   unsigned long rxInterrupts;
>     -   unsigned long rxPackets;
>     -   unsigned long rxLengthError;
>     -   unsigned long rxNonOctet;
>     -   unsigned long rxBadCRC;
>     -   unsigned long rxOverrun;
>     -   unsigned long txInterrupts;
>     -   unsigned long txDeferred;
>     -   unsigned long txHeartbeat;
>     -   unsigned long txLateCollision;
>     -   unsigned long txRetryLimit;
>     -   unsigned long txUnderrun;
>     -   /* Spin-lock ISR protection */
>     -   SPIN_DECLARE(devlock);
>     -int greth_process_tx_gbit(struct greth_softc *sc);
>     -int greth_process_tx(struct greth_softc *sc);
>     -static char *almalloc(int sz, int alignment)
>     -        char *tmp;
>     -        tmp = grlib_calloc(1, sz + (alignment-1));
>     -        tmp = (char *) (((int)tmp+alignment) & ~(alignment -1));
>     -        return(tmp);
>     -/* GRETH interrupt handler */
>     -static void greth_interrupt (void *arg)
>     -        uint32_t status;
>     -        uint32_t ctrl;
>     -        rtems_event_set events = 0;
>     -        struct greth_softc *greth = arg;
>     -        SPIN_ISR_IRQFLAGS(flags);
>     -        /* read and clear interrupt cause */
>     -        status = greth->regs->status;
>     -        greth->regs->status = status;
>     -        SPIN_LOCK(&greth->devlock, flags);
>     -        ctrl = greth->regs->ctrl;
>     -        /* Frame received? */
>     -        if ((ctrl & GRETH_CTRL_RXIRQ) && (status &
>     (GRETH_STATUS_RXERR | GRETH_STATUS_RXIRQ)))
>     -                greth->rxInterrupts++;
>     -                /* Stop RX-Error and RX-Packet interrupts */
>     -                ctrl &= ~GRETH_CTRL_RXIRQ;
>     -                events |= INTERRUPT_EVENT;
>     -        if ( (ctrl & GRETH_CTRL_TXIRQ) && (status &
>     (GRETH_STATUS_TXERR | GRETH_STATUS_TXIRQ)) )
>     -                greth->txInterrupts++;
>     -                ctrl &= ~GRETH_CTRL_TXIRQ;
>     -                events |= GRETH_TX_WAIT_EVENT;
>     -        /* Clear interrupt sources */
>     -        greth->regs->ctrl = ctrl;
>     -        SPIN_UNLOCK(&greth->devlock, flags);
>     -        /* Send the event(s) */
>     -        if ( events )
>     -            rtems_bsdnet_event_send(greth->daemonTid, events);
>     -static uint32_t read_mii(struct greth_softc *sc, uint32_t
>     phy_addr, uint32_t reg_addr)
>     -    sc->phy_read_access++;
>     -    while (sc->regs->mdio_ctrl & GRETH_MDIO_BUSY) {}
>     -    sc->regs->mdio_ctrl = (phy_addr << 11) | (reg_addr << 6) |
>     GRETH_MDIO_READ;
>     -    if (!(sc->regs->mdio_ctrl & GRETH_MDIO_LINKFAIL)) {
>     -        MIIDBG("greth%d: mii read[%d] OK to %" PRIx32 ".%" PRIx32
>     -               " (0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
>     -               sc->minor, sc->phy_read_access, phy_addr, reg_addr,
>     -               sc->regs->ctrl, sc->regs->mdio_ctrl);
>     -        return((sc->regs->mdio_ctrl >> 16) & 0xFFFF);
>     -    } else {
>     -        printf("greth%d: mii read[%d] failed to %" PRIx32 ".%" PRIx32
>     -        return (0xffff);
>     -static void write_mii(struct greth_softc *sc, uint32_t phy_addr,
>     uint32_t reg_addr, uint32_t data)
>     -    sc->phy_write_access++;
>     -     ((data & 0xFFFF) << 16) | (phy_addr << 11) | (reg_addr << 6)
>     | GRETH_MDIO_WRITE;
>     -        MIIDBG("greth%d: mii write[%d] OK to  to %" PRIx32 ".%"
>     PRIx32
>     -               "(0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
>     -               sc->minor, sc->phy_write_access, phy_addr, reg_addr,
>     -    } else {
>     -        printf("greth%d: mii write[%d] failed to to %" PRIx32
>     ".%" PRIx32
>     -static void print_init_info(struct greth_softc *sc)
>     -    printf("greth: driver attached\n");
>     -    if ( sc->auto_neg == -1 ){
>     -        printf("Auto negotiation timed out. Selecting default
>     config\n");
>     -    printf("**** PHY ****\n");
>     -    printf("Vendor: %x   Device: %x   Revision:
>     %d\n",sc->phydev.vendor, sc->phydev.device, sc->phydev.rev);
>     -    printf("Current Operating Mode: ");
>     -    if (sc->gb) {
>     -        printf("1000 Mbit ");
>     -    } else if (sc->sp) {
>     -        printf("100 Mbit ");
>     -    } else {
>     -        printf("10 Mbit ");
>     -    if (sc->fd) {
>     -        printf("Full Duplex\n");
>     -    } else {
>     -        printf("Half Duplex\n");
>     -#ifdef GRETH_AUTONEGO_PRINT_TIME
>     -    if ( sc->auto_neg ) {
>     -        printf("Autonegotiation Time: %" PRIdMAX "ms\n",
>     -               (intmax_t)sc->auto_neg_time.tv_sec * 1000 +
>     -               sc->auto_neg_time.tv_nsec / 1000000);
>     -#endif
>     - * Generates the hash words based on CRCs of the enabled MAC
>     addresses that are
>     - * allowed to be received. The allowed MAC addresses are
>     maintained in a linked
>     - * "multi-cast" list available in the arpcom structure.
>     - * Returns the number of MAC addresses that were processed (in
>     the list)
>     -static int
>     -greth_mac_filter_calc(struct arpcom *ac, uint32_t *msb, uint32_t
>     *lsb)
>     -    struct ether_multistep step;
>     -    struct ether_multi *enm;
>     -    int cnt = 0;
>     -    uint32_t crc, htindex, ht[2] = {0, 0};
>     -    /* Go through the Ethernet Multicast addresses one by one and
>     add their
>     -     * CRC contribution to the MAC filter.
>     -    ETHER_FIRST_MULTI(step, ac, enm);
>     -    while (enm) {
>     -        crc = ether_crc32_be((uint8_t *)enm->enm_addrlo, 6);
>     -        htindex = crc & 0x3f;
>     -        ht[htindex >> 5] |= (1 << (htindex & 0x1F));
>     -        cnt++;
>     -        ETHER_NEXT_MULTI(step, enm);
>     -    if (cnt > 0) {
>     -        *msb = ht[1];
>     -        *lsb = ht[0];
>     -    return cnt;
>     - * Initialize the ethernet hardware
>     -static int greth_mac_filter_set(struct greth_softc *sc)
>     -    struct ifnet *ifp = &sc->arpcom.ac_if;
>     -    uint32_t hash_msb, hash_lsb, ctrl;
>     -    SPIN_IRQFLAGS(flags);
>     -    hash_msb = 0;
>     -    hash_lsb = 0;
>     -    ctrl = 0;
>     -    if (ifp->if_flags & IFF_PROMISC) {
>     -        /* No need to enable multi-cast when promiscous mode
>     accepts all */
>     -        ctrl |= GRETH_CTRL_PRO;
>     -    } else if(!sc->mc_available) {
>     -        return EINVAL; /* no hardware support for multicast
>     filtering. */
>     -    } else if (ifp->if_flags & IFF_ALLMULTI) {
>     -        /* We should accept all multicast addresses */
>     -        ctrl |= GRETH_CTRL_MCE;
>     -        hash_msb = 0xFFFFFFFF;
>     -        hash_lsb = 0xFFFFFFFF;
>     -    } else if (greth_mac_filter_calc(&sc->arpcom, &hash_msb,
>     &hash_lsb) > 0) {
>     -        /* Generate hash for MAC filtering out multicast addresses */
>     -    } else {
>     -        /* Multicast list is empty .. disable multicast */
>     -    SPIN_LOCK_IRQ(&sc->devlock, flags);
>     -    sc->regs->ht_msb = hash_msb;
>     -    sc->regs->ht_lsb = hash_lsb;
>     -    sc->regs->ctrl = (sc->regs->ctrl & ~(GRETH_CTRL_PRO |
>     GRETH_CTRL_MCE)) |
>     -                     ctrl;
>     -    SPIN_UNLOCK_IRQ(&sc->devlock, flags);
>     -    return 0;
>     -static void
>     -greth_initialize_hardware (struct greth_softc *sc)
>     -    struct mbuf *m;
>     -    int i;
>     -    int phyaddr;
>     -    int phyctrl;
>     -    int phystatus;
>     -    int tmp1;
>     -    int tmp2;
>     -    struct timespec tstart, tnow;
>     -    greth_regs *regs;
>     -    unsigned int advmodes, speed;
>     -    regs = sc->regs;
>     -    /* Reset the controller.  */
>     -    sc->rxInterrupts = 0;
>     -    sc->rxPackets = 0;
>     -    if (sc->greth_rst) {
>     -        /* Reset ON */
>     -        regs->ctrl = GRETH_CTRL_RST | GRETH_CTRL_DD | GRETH_CTRL_ED;
>     -        for (i = 0; i<100 && (regs->ctrl & GRETH_CTRL_RST); i++)
>     -        speed = 0; /* probe mode below */
>     -    } else {
>     -        /* inherit EDCL mode for now */
>     -        speed = sc->regs->ctrl &
>     (GRETH_CTRL_GB|GRETH_CTRL_SP|GRETH_CTRL_FULLD);
>     -    /* Reset OFF and RX/TX DMA OFF. SW do PHY Init */
>     -    regs->ctrl = GRETH_CTRL_DD | GRETH_CTRL_ED | speed;
>     -    /* Check if mac is gbit capable*/
>     -    sc->gbit_mac = (regs->ctrl >> 27) & 1;
>     -    /* Get the phy address which assumed to have been set
>     -       correctly with the reset value in hardware*/
>     -    if ( sc->phyaddr == -1 ) {
>     -        phyaddr = (regs->mdio_ctrl >> 11) & 0x1F;
>     -    } else {
>     -        phyaddr = sc->phyaddr;
>     -    sc->phy_read_access = 0;
>     -    sc->phy_write_access = 0;
>     -    /* As I understand the PHY comes back to a good default state
>     after
>     -     * Power-down or Reset, so we do both just in case.
>     Power-down bit should
>     -     * be cleared.
>     -     * Wait for old reset (if asserted by boot loader) to
>     complete, otherwise
>     -     * power-down instruction might not have any effect.
>     -    while (read_mii(sc, phyaddr, 0) & 0x8000) {}
>     -    write_mii(sc, phyaddr, 0, 0x0800); /* Power-down */
>     -    write_mii(sc, phyaddr, 0, 0x0000); /* Power-Up */
>     -    write_mii(sc, phyaddr, 0, 0x8000); /* Reset */
>     -    /* We wait about 30ms */
>     -    rtems_task_wake_after(rtems_clock_get_ticks_per_second()/32);
>     -    /* Wait for reset to complete and get default values */
>     -    while ((phyctrl = read_mii(sc, phyaddr, 0)) & 0x8000) {}
>     -    /* Set up PHY advertising modes for auto-negotiation */
>     -    advmodes = sc->advmodes;
>     -    if (advmodes == 0)
>     -        advmodes = GRETH_ADV_ALL;
>     -    if (!sc->gbit_mac)
>     -        advmodes &= ~(GRETH_ADV_1000_FD | GRETH_ADV_1000_HD);
>     -    /* Enable/Disable GBit auto-neg advetisement so that the link
>     partner
>     -     * know that we have/haven't GBit capability. The MAC may not
>     support
>     -     * Gbit even though PHY does...
>     -    phystatus = read_mii(sc, phyaddr, 1);
>     -    if (phystatus & 0x0100) {
>     -        tmp1 = read_mii(sc, phyaddr, 9);
>     -        tmp1 &= ~0x300;
>     -        if (advmodes & GRETH_ADV_1000_FD)
>     -            tmp1 |= 0x200;
>     -        if (advmodes & GRETH_ADV_1000_HD)
>     -            tmp1 |= 0x100;
>     -        write_mii(sc, phyaddr, 9, tmp1);
>     -    /* Optionally limit the 10/100 modes as configured by user */
>     -    tmp1 = read_mii(sc, phyaddr, 4);
>     -    tmp1 &= ~0x1e0;
>     -    if (advmodes & GRETH_ADV_100_FD)
>     -        tmp1 |= 0x100;
>     -    if (advmodes & GRETH_ADV_100_HD)
>     -        tmp1 |= 0x080;
>     -    if (advmodes & GRETH_ADV_10_FD)
>     -        tmp1 |= 0x040;
>     -    if (advmodes & GRETH_ADV_10_HD)
>     -        tmp1 |= 0x020;
>     -    write_mii(sc, phyaddr, 4, tmp1);
>     -    /* If autonegotiation implemented we start it */
>     -    if (phystatus & 0x0008) {
>     -        write_mii(sc, phyaddr, 0, phyctrl | 0x1200);
>     -        phyctrl = read_mii(sc, phyaddr, 0);
>     -    /* Check if PHY is autoneg capable and then determine
>     operating mode,
>     -       otherwise force it to 10 Mbit halfduplex */
>     -    sc->gb = 0;
>     -    sc->fd = 0;
>     -    sc->sp = 0;
>     -    sc->auto_neg = 0;
>     -    timespecclear(&sc->auto_neg_time);
>     -    if ((phyctrl >> 12) & 1) {
>     -            /*wait for auto negotiation to complete*/
>     -            sc->auto_neg = 1;
>     -            if (rtems_clock_get_uptime(&tstart) != RTEMS_SUCCESSFUL)
>     -                    printk("rtems_clock_get_uptime failed\n");
>     -            while (!(((phystatus = read_mii(sc, phyaddr, 1)) >>
>     5) & 1)) {
>     -                    if (rtems_clock_get_uptime(&tnow) !=
>     RTEMS_SUCCESSFUL)
>     failed\n");
>     -                    timespecsub(&tnow, &tstart, &sc->auto_neg_time);
>     -                    if (timespeccmp(&sc->auto_neg_time,
>     &greth_tan, >)) {
>     -                            sc->auto_neg = -1; /* Failed */
>     -                            tmp1 = read_mii(sc, phyaddr, 0);
>     -                            sc->gb = ((phyctrl >> 6) & 1) &&
>     !((phyctrl >> 13) & 1);
>     -                            sc->sp = !((phyctrl >> 6) & 1) &&
>     -                            sc->fd = (phyctrl >> 8) & 1;
>     -                            goto auto_neg_done;
>     -                    /* Wait about 30ms, time is PHY dependent */
>     -            sc->phydev.adv = read_mii(sc, phyaddr, 4);
>     -            sc->phydev.part = read_mii(sc, phyaddr, 5);
>     -            if ((phystatus >> 8) & 1) {
>     -                    sc->phydev.extadv = read_mii(sc, phyaddr, 9);
>     -                    sc->phydev.extpart = read_mii(sc, phyaddr, 10);
>     -                       if ( (sc->phydev.extadv &
>     GRETH_MII_EXTADV_1000HD) &&
>     -                            (sc->phydev.extpart &
>     GRETH_MII_EXTPRT_1000HD)) {
>     -                               sc->gb = 1;
>     -                               sc->fd = 0;
>     GRETH_MII_EXTADV_1000FD) &&
>     GRETH_MII_EXTPRT_1000FD)) {
>     -                               sc->gb = 1;
>     -                               sc->fd = 1;
>     -            if ((sc->gb == 0) || ((sc->gb == 1) && (sc->gbit_mac
>     == 0))) {
>     -                    if ( (sc->phydev.adv & GRETH_MII_100TXFD) &&
>     -                         (sc->phydev.part & GRETH_MII_100TXFD)) {
>     -                            sc->sp = 1;
>     -                            sc->fd = 1;
>     -                    } else if ( (sc->phydev.adv &
>     GRETH_MII_100TXHD) &&
>     GRETH_MII_100TXHD)) {
>     -                            sc->sp = 1;
>     -                            sc->fd = 0;
>     -                    } else if ( (sc->phydev.adv & GRETH_MII_10FD) &&
>     -                                (sc->phydev.part & GRETH_MII_10FD)) {
>     -                            sc->fd = 1;
>     -auto_neg_done:
>     -    sc->phydev.vendor = 0;
>     -    sc->phydev.device = 0;
>     -    sc->phydev.rev = 0;
>     -    /* Read out PHY info if extended registers are available */
>     -    if (phystatus & 1) {
>     -            tmp1 = read_mii(sc, phyaddr, 2);
>     -            tmp2 = read_mii(sc, phyaddr, 3);
>     -            sc->phydev.vendor = (tmp1 << 6) | ((tmp2 >> 10) & 0x3F);
>     -            sc->phydev.rev = tmp2 & 0xF;
>     -            sc->phydev.device = (tmp2 >> 4) & 0x3F;
>     -    /* Force to 10 mbit half duplex if the 10/100 MAC is used
>     with a 1000 PHY */
>     -    if (((sc->gb) && !(sc->gbit_mac)) || !((phyctrl >> 12) & 1)) {
>     -        write_mii(sc, phyaddr, 0, sc->sp << 13);
>     -        /* check if marvell 88EE1111 PHY. Needs special reset
>     handling */
>     -        if ((phystatus & 1) && (sc->phydev.vendor == 0x005043) &&
>     -            (sc->phydev.device == 0x0C))
>     -        sc->gb = 0;
>     -        sc->sp = 0;
>     -        sc->fd = 0;
>     -    while ((read_mii(sc, phyaddr, 0)) & 0x8000) {}
>     -        /* Reset ON */
>     -        for (i = 0; i < 100 && (regs->ctrl & GRETH_CTRL_RST); i++)
>     -    /* Reset OFF. Set mode matching PHY settings. */
>     -    speed = (sc->gb << 8) | (sc->sp << 7) | (sc->fd << 4);
>     -    regs->ctrl = GRETH_CTRL_DD | sc->edcl_dis | speed;
>     -    /* Initialize rx/tx descriptor table pointers. Due to
>     alignment we
>     -     * always allocate maximum table size.
>     -    sc->txdesc = (greth_rxtxdesc *) almalloc(0x800, 0x400);
>     -    sc->rxdesc = (greth_rxtxdesc *) &sc->txdesc[128];
>     -    sc->tx_ptr = 0;
>     -    sc->tx_dptr = 0;
>     -    sc->tx_cnt = 0;
>     -    sc->rx_ptr = 0;
>     -    /* Translate the Descriptor DMA table base address into an
>     address that
>     -     * the GRETH core can understand
>     -    drvmgr_translate_check(
>     -        sc->dev,
>     -        CPUMEM_TO_DMA,
>     -        (void *)sc->txdesc,
>     -        (void **)&sc->txdesc_remote,
>     -        0x800);
>     -    sc->rxdesc_remote = sc->txdesc_remote + 0x400;
>     -    regs->txdesc = (int) sc->txdesc_remote;
>     -    regs->rxdesc = (int) sc->rxdesc_remote;
>     -    sc->rxmbuf = grlib_calloc(sc->rxbufs, sizeof(*sc->rxmbuf));
>     -    sc->txmbuf = grlib_calloc(sc->txbufs, sizeof(*sc->txmbuf));
>     -    for (i = 0; i < sc->txbufs; i++)
>     -        sc->txdesc[i].ctrl = 0;
>     -        if (!(sc->gbit_mac)) {
>     -                sc->dev,
>     -                CPUMEM_TO_DMA,
>     -                (void *)grlib_malloc(GRETH_MAXBUF_LEN),
>     -                (void **)&sc->txdesc[i].addr,
>     -                GRETH_MAXBUF_LEN);
>     -#ifdef GRETH_DEBUG
>     -              /* printf("TXBUF: %08x\n", (int)
>     sc->txdesc[i].addr); */
>     -#endif
>     -    for (i = 0; i < sc->rxbufs; i++)
>     -         MGETHDR (m, M_WAIT, MT_DATA);
>     -          MCLGET (m, M_WAIT);
>     -          if (sc->gbit_mac)
>     -                  m->m_data += 2;
>     -         m->m_pkthdr.rcvif = &sc->arpcom.ac_if;
>     -          sc->rxmbuf[i] = m;
>     -            sc->dev,
>     -            CPUMEM_TO_DMA,
>     -            (void *)mtod(m, uint32_t *),
>     -            (void **)&sc->rxdesc[i].addr,
>     -          sc->rxdesc[i].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ;
>     -#ifdef GRETH_DEBUG
>     -/*       printf("RXBUF: %08x\n", (int) sc->rxdesc[i].addr); */
>     -#endif
>     -    sc->rxdesc[sc->rxbufs - 1].ctrl |= GRETH_RXD_WRAP;
>     -    /* set ethernet address.  */
>     -    regs->mac_addr_msb =
>     -      sc->arpcom.ac_enaddr[0] << 8 | sc->arpcom.ac_enaddr[1];
>     -    regs->mac_addr_lsb =
>     -      sc->arpcom.ac_enaddr[2] << 24 | sc->arpcom.ac_enaddr[3] << 16 |
>     -      sc->arpcom.ac_enaddr[4] << 8 | sc->arpcom.ac_enaddr[5];
>     -    if ( sc->rxbufs < 10 ) {
>     -        sc->tx_int_gen = sc->tx_int_gen_cur = 1;
>     -    }else{
>     -        sc->tx_int_gen = sc->tx_int_gen_cur = sc->txbufs/2;
>     -    sc->next_tx_mbuf = NULL;
>     -    if ( !sc->gbit_mac )
>     -        sc->max_fragsize = 1;
>     -    /* clear all pending interrupts */
>     -    regs->status = 0xffffffff;
>     -    /* install interrupt handler */
>     -    drvmgr_interrupt_register(sc->dev, 0, "greth",
>     greth_interrupt, sc);
>     -    regs->ctrl |= GRETH_CTRL_RXEN | GRETH_CTRL_RXIRQ;
>     -    print_init_info(sc);
>     -#ifdef CPU_U32_FIX
>     - * Routine to align the received packet so that the ip header
>     - * is on a 32-bit boundary. Necessary for cpu's that do not
>     - * allow unaligned loads and stores and when the 32-bit DMA
>     - * mode is used.
>     - * Transfers are done on word basis to avoid possibly slow byte
>     - * and half-word writes.
>     -void ipalign(struct mbuf *m)
>     -  unsigned int *first, *last, data;
>     -  unsigned int tmp = 0;
>     -  if ((((int) m->m_data) & 2) && (m->m_len)) {
>     -    last = (unsigned int *) ((((int) m->m_data) + m->m_len + 8) &
>     ~3);
>     -    first = (unsigned int *) (((int) m->m_data) & ~3);
>     -               /* tmp = *first << 16; */
>     -               asm volatile (" lda [%1] 1, %0\n" : "=r"(tmp) :
>     "r"(first) );
>     -               tmp = tmp << 16;
>     -    first++;
>     -    do {
>     -                       /* When snooping is not available the LDA
>     instruction must be used
>     -                        * to avoid the cache to return an illegal
>     value.
>     -                        ** Load with forced cache miss
>     -                        * data = *first;
>     -      asm volatile (" lda [%1] 1, %0\n" : "=r"(data) : "r"(first) );
>     -      *first = tmp | (data >> 16);
>     -      tmp = data << 16;
>     -      first++;
>     -    } while (first <= last);
>     -    m->m_data = (caddr_t)(((int) m->m_data) + 2);
>     -#endif
>     -static void
>     -greth_Daemon (void *arg)
>     -    struct ether_header *eh;
>     -    struct greth_softc *dp = (struct greth_softc *) arg;
>     -    struct ifnet *ifp = &dp->arpcom.ac_if;
>     -    struct mbuf *m;
>     -    unsigned int len, len_status, bad;
>     -    rtems_event_set events;
>     -    int first;
>     -    int tmp;
>     -    unsigned int addr;
>     -    for (;;)
>     -        rtems_bsdnet_event_receive (INTERRUPT_EVENT |
>     GRETH_TX_WAIT_EVENT,
>     -                                    RTEMS_WAIT | RTEMS_EVENT_ANY,
>     -                                    RTEMS_NO_TIMEOUT, &events);
>     -        if ( events & GRETH_TX_WAIT_EVENT ){
>     -            /* TX interrupt.
>     -             * We only end up here when all TX descriptors has
>     been used,
>     -             * and
>     -            if ( dp->gbit_mac )
>     -                greth_process_tx_gbit(dp);
>     -            else
>     -                greth_process_tx(dp);
>     -            /* If we didn't get a RX interrupt we don't process it */
>     -            if ( (events & INTERRUPT_EVENT) == 0 )
>     -                continue;
>     -#ifdef GRETH_ETH_DEBUG
>     -    printf ("r\n");
>     -#endif
>     -    first=1;
>     -    /* Scan for Received packets */
>     -again:
>     -    while (!((len_status =
>     -                   GRETH_MEM_LOAD(&dp->rxdesc[dp->rx_ptr].ctrl))
>     & GRETH_RXD_ENABLE))
>     -                    bad = 0;
>     -                    if (len_status & GRETH_RXD_TOOLONG)
>     -                            dp->rxLengthError++;
>     -                            bad = 1;
>     -                    if (len_status & GRETH_RXD_DRIBBLE)
>     -                            dp->rxNonOctet++;
>     -                            bad = 1;
>     -                    if (len_status & GRETH_RXD_CRCERR)
>     -                            dp->rxBadCRC++;
>     -                            bad = 1;
>     -                    if (len_status & GRETH_RXD_OVERRUN)
>     -                            dp->rxOverrun++;
>     -                            bad = 1;
>     -                    if (len_status & GRETH_RXD_LENERR)
>     -                            bad = 1;
>     -                    if (!bad)
>     -                            /* pass on the packet in the receive
>     buffer */
>     -                            len = len_status & 0x7FF;
>     -                            m = dp->rxmbuf[dp->rx_ptr];
>     -#ifdef GRETH_DEBUG
>     -                            int i;
>     -                            printf("RX: 0x%08x, Len: %d : ",
>     (int) m->m_data, len);
>     -                            for (i=0; i<len; i++)
>     -                                    printf("%x%x", (m->m_data[i]
>     >> 4) & 0x0ff, m->m_data[i] & 0x0ff);
>     -                            printf("\n");
>     -#endif
>     -                            m->m_len = m->m_pkthdr.len =
>     -                                    len - sizeof (struct
>     ether_header);
>     -                            eh = mtod (m, struct ether_header *);
>     -                            m->m_data += sizeof (struct
>     ether_header);
>     -#ifdef CPU_U32_FIX
>     -                            if(!dp->gbit_mac) {
>     -                                    /* OVERRIDE CACHED ETHERNET
>     HEADER FOR NON-SNOOPING SYSTEMS */
>     -                                    addr = (unsigned int)eh;
>     %0\n" : "=r"(tmp) : "r"(addr) );
>     -                                    addr+=4;
>     -                                    addr+=4;
>     -                                    addr+=4;
>     -                                    ipalign(m);        /* Align
>     packet on 32-bit boundary */
>     -#endif
>     -                            if(!(dp->gbit_mac) &&
>     !CPU_SPARC_HAS_SNOOPING) {
>     rtems_cache_invalidate_entire_data();
>     -                            ether_input (ifp, eh, m);
>     -                            if (dp->gbit_mac)
>     -                                    m->m_data += 2;
>     -                            dp->rxmbuf[dp->rx_ptr] = m;
>     -                            m->m_pkthdr.rcvif = ifp;
>     -                                dp->dev,
>     -                                CPUMEM_TO_DMA,
>     -                                (void *)mtod (m, uint32_t *),
>     -                                (void
>     **)&dp->rxdesc[dp->rx_ptr].addr,
>     -                            dp->rxPackets++;
>     -                    if (dp->rx_ptr == dp->rxbufs - 1) {
>     -                            dp->rxdesc[dp->rx_ptr].ctrl =
>     GRETH_RXD_ENABLE | GRETH_RXD_IRQ | GRETH_RXD_WRAP;
>     -                    } else {
>     -                    SPIN_LOCK_IRQ(&dp->devlock, flags);
>     -                    dp->regs->ctrl |= GRETH_CTRL_RXEN;
>     -                    SPIN_UNLOCK_IRQ(&dp->devlock, flags);
>     -                    dp->rx_ptr = (dp->rx_ptr + 1) % dp->rxbufs;
>     -        /* Always scan twice to avoid deadlock */
>     -        if ( first ){
>     -            first=0;
>     -            dp->regs->ctrl |= GRETH_CTRL_RXIRQ;
>     -            goto again;
>     -static int
>     -sendpacket (struct ifnet *ifp, struct mbuf *m)
>     -    struct greth_softc *dp = ifp->if_softc;
>     -    unsigned char *temp;
>     -    struct mbuf *n;
>     -    unsigned int len;
>     -     * Is there a free descriptor available?
>     -    if (GRETH_MEM_LOAD(&dp->txdesc[dp->tx_ptr].ctrl) &
>     GRETH_TXD_ENABLE){
>     -            /* No. */
>     -            return 1;
>     -    /* Remember head of chain */
>     -    n = m;
>     -    len = 0;
>     -    temp = (unsigned char *)
>     GRETH_MEM_LOAD(&dp->txdesc[dp->tx_ptr].addr);
>     -    drvmgr_translate(dp->dev, CPUMEM_FROM_DMA, (void *)temp,
>     (void **)&temp);
>     -#ifdef GRETH_DEBUG
>     -    printf("TXD: 0x%08x : BUF: 0x%08x\n", (int) m->m_data, (int)
>     temp);
>     -#endif
>     -    for (;;)
>     -#ifdef GRETH_DEBUG
>     -            int i;
>     -            printf("MBUF: 0x%08x : ", (int) m->m_data);
>     -            for (i=0;i<m->m_len;i++)
>     -                    printf("%x%x", (m->m_data[i] >> 4) & 0x0ff,
>     -            printf("\n");
>     -#endif
>     -            len += m->m_len;
>     -            if (len <= RBUF_SIZE)
>     -                    memcpy ((void *) temp, (char *) m->m_data,
>     m->m_len);
>     -            temp += m->m_len;
>     -            if ((m = m->m_next) == NULL)
>     -                    break;
>     -    m_freem (n);
>     -    /* don't send long packets */
>     -    if (len <= GRETH_MAXBUF_LEN) {
>     -            if (dp->tx_ptr < dp->txbufs-1) {
>     -                    dp->txdesc[dp->tx_ptr].ctrl = GRETH_TXD_IRQ |
>     GRETH_TXD_ENABLE | len;
>     -            } else {
>     -                            GRETH_TXD_WRAP | GRETH_TXD_ENABLE | len;
>     -            dp->tx_ptr = (dp->tx_ptr + 1) % dp->txbufs;
>     -            dp->regs->ctrl = dp->regs->ctrl | GRETH_CTRL_TXEN;
>     -    return 0;
>     -static int
>     -sendpacket_gbit (struct ifnet *ifp, struct mbuf *m)
>     -        unsigned int len;
>     -        unsigned int ctrl;
>     -        int frags;
>     -        struct mbuf *mtmp;
>     -        int int_en;
>     -        len = 0;
>     -#ifdef GRETH_DEBUG
>     -        printf("TXD: 0x%08x\n", (int) m->m_data);
>     -#endif
>     -        /* Get number of fragments too see if we have enough
>     -         * resources.
>     -        frags=1;
>     -        mtmp=m;
>     -        while(mtmp->m_next){
>     -            frags++;
>     -            mtmp = mtmp->m_next;
>     -        if ( frags > dp->max_fragsize )
>     -            dp->max_fragsize = frags;
>     -        if ( frags > dp->txbufs ){
>     -            printf("GRETH: MBUF-chain cannot be sent. Increase
>     descriptor count.\n");
>     -            return -1;
>     -        if ( frags > (dp->txbufs-dp->tx_cnt) ){
>     -            /* Return number of fragments */
>     -            return frags;
>     -        /* Enable interrupt from descriptor every tx_int_gen
>     -         * descriptor. Typically every 16 descriptor. This
>     -         * is only to reduce the number of interrupts during
>     -         * heavy load.
>     -        dp->tx_int_gen_cur-=frags;
>     -        if ( dp->tx_int_gen_cur <= 0 ){
>     -            dp->tx_int_gen_cur = dp->tx_int_gen;
>     -            int_en = GRETH_TXD_IRQ;
>     -        }else{
>     -            int_en = 0;
>     -        /* At this stage we know that enough descriptors are
>     available */
>     -        for (;;)
>     -#ifdef GRETH_DEBUG
>     -            int i;
>     -            printf("MBUF: 0x%08x, Len: %d : ", (int) m->m_data,
>     m->m_len);
>     -            for (i=0; i<m->m_len; i++)
>     -            printf("\n");
>     -#endif
>     -            len += m->m_len;
>     -                dp->dev,
>     -                CPUMEM_TO_DMA,
>     -                (void *)(uint32_t *)m->m_data,
>     -                (void **)&dp->txdesc[dp->tx_ptr].addr,
>     -                m->m_len);
>     -            /* Wrap around? */
>     -                ctrl = GRETH_TXD_ENABLE;
>     -            }else{
>     -                ctrl = GRETH_TXD_ENABLE | GRETH_TXD_WRAP;
>     -            /* Enable Descriptor */
>     -            if ((m->m_next) == NULL) {
>     -                dp->txdesc[dp->tx_ptr].ctrl = ctrl | int_en |
>     m->m_len;
>     -                break;
>     -            }else{
>     -                dp->txdesc[dp->tx_ptr].ctrl = GRETH_TXD_MORE |
>     ctrl | int_en | m->m_len;
>     -            /* Next */
>     -            dp->txmbuf[dp->tx_ptr] = m;
>     -            dp->tx_cnt++;
>     -            m = m->m_next;
>     -        dp->tx_cnt++;
>     -        /* Tell Hardware about newly enabled descriptor */
>     -        return 0;
>     -    struct mbuf *m;
>     -    int first=1;
>     -     * Send packets till queue is empty
>     -    for (;;){
>     -        /* Reap Sent packets */
>     -        while((sc->tx_cnt > 0) &&
>     !(GRETH_MEM_LOAD(&sc->txdesc[sc->tx_dptr].ctrl) & GRETH_TXD_ENABLE)) {
>     -            m_free(sc->txmbuf[sc->tx_dptr]);
>     -            sc->tx_dptr = (sc->tx_dptr + 1) % sc->txbufs;
>     -            sc->tx_cnt--;
>     -        if ( sc->next_tx_mbuf ){
>     -            /* Get packet we tried but faild to transmit last time */
>     -            m = sc->next_tx_mbuf;
>     -            sc->next_tx_mbuf = NULL; /* Mark packet taken */
>     -        }else{
>     -             * Get the next mbuf chain to transmit from Stack.
>     -            IF_DEQUEUE (&ifp->if_snd, m);
>     -            if (!m){
>     -                /* Hardware has sent all schedule packets, this
>     -                 * makes the stack enter at greth_start next time
>     -                 * a packet is to be sent.
>     -                ifp->if_flags &= ~IFF_OACTIVE;
>     -                break;
>     -        /* Are there free descriptors available? */
>     -        /* Try to send packet, if it a negative number is
>     returned. */
>     -        if ( (sc->tx_cnt >= sc->txbufs) || sendpacket_gbit(ifp, m) ){
>     -            /* Not enough resources */
>     -            /* Since we have taken the mbuf out of the "send chain"
>     -             * we must remember to use that next time we come back.
>     -             * or else we have dropped a packet.
>     -            sc->next_tx_mbuf = m;
>     -            /* Not enough resources, enable interrupt for
>     transmissions
>     -             * this way we will be informed when more
>     TX-descriptors are
>     -             * available.
>     -            if ( first ){
>     -                first = 0;
>     -                ifp->if_flags |= IFF_OACTIVE;
>     -                sc->regs->ctrl |= GRETH_CTRL_TXIRQ;
>     -                /* We must check again to be sure that we didn't
>     -                 * miss an interrupt (if a packet was sent just
>     before
>     -                 * enabling interrupts)
>     -                continue;
>     -            return -1;
>     -        }else{
>     -            /* Sent Ok, proceed to process more packets if
>     available */
>     -    return 0;
>     -    struct mbuf *m;
>     -    int first=1;
>     -    for (;;){
>     -            /* Get packet we tried but failed to transmit last
>     time */
>     -        }else{
>     -            if (!m){
>     -                break;
>     -        /* Try to send packet, failed if it a non-zero number is
>     returned. */
>     -        if ( sendpacket(ifp, m) ){
>     transmissions
>     TX-descriptors are
>     -             * available.
>     -            if ( first ){
>     -                first = 0;
>     before
>     -                continue;
>     -            return -1;
>     -        }else{
>     available */
>     -    return 0;
>     -static void
>     -greth_start (struct ifnet *ifp)
>     -    struct greth_softc *sc = ifp->if_softc;
>     -    if ( ifp->if_flags & IFF_OACTIVE )
>     -            return;
>     -    if ( sc->gbit_mac ){
>     -        /* No use trying to handle this if we are waiting on GRETH
>     -         * to send the previously scheduled packets.
>     -        greth_process_tx_gbit(sc);
>     -    }else{
>     -        greth_process_tx(sc);
>     - * Initialize and start the device
>     -static void
>     -greth_init (void *arg)
>     -    struct greth_softc *sc = arg;
>     -    char name[4] = {'E', 'T', 'H', '0'};
>     -    if (sc->daemonTid == 0)
>     -           * Start driver tasks
>     -          name[3] += sc->minor;
>     -          sc->daemonTid = rtems_bsdnet_newproc (name, 4096,
>     -                                                greth_Daemon, sc);
>     -           * Set up GRETH hardware
>     -          greth_initialize_hardware (sc);
>     -     * Setup promiscous/multi-cast MAC address filters if user
>     enabled it
>     -    greth_mac_filter_set(sc);
>     -     * Tell the world that we're running.
>     -    ifp->if_flags |= IFF_RUNNING;
>     - * Stop the device
>     -static void
>     -greth_stop (struct greth_softc *sc)
>     -    unsigned int speed;
>     -    ifp->if_flags &= ~IFF_RUNNING;
>     -    speed = sc->regs->ctrl & (GRETH_CTRL_GB | GRETH_CTRL_SP |
>     GRETH_CTRL_FULLD);
>     -    /* RX/TX OFF */
>     -    sc->regs->ctrl = GRETH_CTRL_DD | GRETH_CTRL_ED | speed;
>     -    /* Reset ON */
>     -        sc->regs->ctrl = GRETH_CTRL_RST | GRETH_CTRL_DD |
>     -    /* Reset OFF and restore link settings previously detected if
>     any */
>     -    sc->regs->ctrl = GRETH_CTRL_DD | sc->edcl_dis | speed;
>     - * Show interface statistics
>     -static void
>     -greth_stats (struct greth_softc *sc)
>     -  printf ("      Rx Interrupts:%-8lu", sc->rxInterrupts);
>     -  printf ("      Rx Packets:%-8lu", sc->rxPackets);
>     -  printf ("          Length:%-8lu", sc->rxLengthError);
>     -  printf ("       Non-octet:%-8lu\n", sc->rxNonOctet);
>     -  printf ("            Bad CRC:%-8lu", sc->rxBadCRC);
>     -  printf ("         Overrun:%-8lu", sc->rxOverrun);
>     -  printf ("      Tx Interrupts:%-8lu", sc->txInterrupts);
>     -  printf ("      Maximal Frags:%-8d", sc->max_fragsize);
>     -  printf ("      GBIT MAC:%-8d", sc->gbit_mac);
>     - * Driver ioctl handler
>     -static int
>     -greth_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t
>     data)
>     -    int error = 0;
>     -    struct ifreq *ifr;
>     -    switch (command)
>     -      case SIOCGIFADDR:
>     -      case SIOCSIFADDR:
>     -         ether_ioctl (ifp, command, data);
>     -         break;
>     -      case SIOCSIFFLAGS:
>     -         switch (ifp->if_flags & (IFF_UP | IFF_RUNNING))
>     -           case IFF_RUNNING:
>     -               greth_stop (sc);
>     -                break;
>     -           case IFF_UP:
>     -               greth_init (sc);
>     -               break;
>     -           case IFF_UP | IFF_RUNNING:
>     -               greth_stop (sc);
>     -               greth_init (sc);
>     -               break;
>     -       default:
>     -               break;
>     -         break;
>     -      case SIO_RTEMS_SHOW_STATS:
>     -         greth_stats (sc);
>     -         break;
>     -          * Multicast commands: Enabling/disabling filtering of
>     MAC addresses
>     -      case SIOCADDMULTI:
>     -      case SIOCDELMULTI:
>     -      ifr = (struct ifreq *)data;
>     -      if (command == SIOCADDMULTI) {
>     -        error = ether_addmulti(ifr, &sc->arpcom);
>     -      } else {
>     -        error = ether_delmulti(ifr, &sc->arpcom);
>     -      if (error == ENETRESET) {
>     -        error = greth_mac_filter_set(sc);
>     -      break;
>     -      default:
>     -         error = EINVAL;
>     -         break;
>     -    return error;
>     - * Attach an GRETH driver to the system
>     -static int
>     -greth_interface_driver_attach (
>     -    struct rtems_bsdnet_ifconfig *config,
>     -    int attach
>     -    struct greth_softc *sc;
>     -    struct ifnet *ifp;
>     -    int mtu;
>     -    int unitNumber;
>     -    char *unitName;
>     -      /* parse driver name */
>     -    if ((unitNumber = rtems_bsdnet_parse_driver_name (config,
>     &unitName)) < 0)
>     -       return 0;
>     -    sc = config->drv_ctrl;
>     -    ifp = &sc->arpcom.ac_if;
>     -#ifdef GRETH_DEBUG
>     -    printf("GRETH[%d]: %s, sc %p, dev %p on %s\n", unitNumber,
>     config->ip_address, sc, sc->dev, sc->dev->parent->dev->name);
>     -#endif
>     -    if (config->hardware_address)
>     -         memcpy (sc->arpcom.ac_enaddr, config->hardware_address,
>     -                 ETHER_ADDR_LEN);
>     -    else
>     -         memset (sc->arpcom.ac_enaddr, 0x08, ETHER_ADDR_LEN);
>     -    if (config->mtu)
>     -       mtu = config->mtu;
>     -    else
>     -       mtu = ETHERMTU;
>     -    sc->acceptBroadcast = !config->ignore_broadcast;
>     -     * Set up network interface values
>     -    ifp->if_softc = sc;
>     -    ifp->if_unit = unitNumber;
>     -    ifp->if_name = unitName;
>     -    ifp->if_mtu = mtu;
>     -    ifp->if_init = greth_init;
>     -    ifp->if_ioctl = greth_ioctl;
>     -    ifp->if_start = greth_start;
>     -    ifp->if_output = ether_output;
>     -    ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX;
>     -    if (sc->mc_available)
>     -        ifp->if_flags |= IFF_MULTICAST;
>     -    if (ifp->if_snd.ifq_maxlen == 0)
>     -       ifp->if_snd.ifq_maxlen = ifqmaxlen;
>     -     * Attach the interface
>     -    if_attach (ifp);
>     -    ether_ifattach (ifp);
>     -#ifdef GRETH_DEBUG
>     -    printf ("GRETH : driver has been attached\n");
>     -#endif
>     -    return 1;
>     -/******************* Driver manager interface
>     -/* Driver prototypes */
>     -int greth_register_io(rtems_device_major_number *m);
>     -int greth_device_init(struct greth_softc *sc);
>     -int network_interface_add(struct rtems_bsdnet_ifconfig *interface);
>     -#ifdef GRETH_INFO_AVAIL
>     -static int greth_info(
>     -       struct drvmgr_dev *dev,
>     -       void (*print_line)(void *p, char *str),
>     -       void *p, int argc, char *argv[]);
>     -#define GRETH_INFO_FUNC greth_info
>     -#else
>     -#define GRETH_INFO_FUNC NULL
>     -#endif
>     -int greth_init2(struct drvmgr_dev *dev);
>     -int greth_init3(struct drvmgr_dev *dev);
>     -struct drvmgr_drv_ops greth_ops =
>     -       .init   =
>     -                       NULL,
>     -                       greth_init2,
>     -                       greth_init3,
>     -                       NULL
>     -       .remove = NULL,
>     -       .info = GRETH_INFO_FUNC,
>     -struct amba_dev_id greth_ids[] =
>     -       {VENDOR_GAISLER, GAISLER_ETHMAC},
>     -       {0, 0}          /* Mark end of table */
>     -struct amba_drv_info greth_drv_info =
>     -               DRVMGR_OBJ_DRV,                 /* Driver */
>     -               NULL,                           /* Next driver */
>     -               NULL,                           /* Device list */
>     -               DRIVER_AMBAPP_GAISLER_GRETH_ID, /* Driver ID */
>     -               "GRETH_DRV",                    /* Driver Name */
>     -               DRVMGR_BUS_TYPE_AMBAPP,         /* Bus Type */
>     -               &greth_ops,
>     -               NULL,                           /* Funcs */
>     -               0,                              /* No devices yet */
>     -               0,
>     -       &greth_ids[0]
>     -void greth_register_drv (void)
>     -       DBG("Registering GRETH driver\n");
>     -       drvmgr_drv_register(&greth_drv_info.general);
>     -       struct greth_softc *priv;
>     -       DBG("GRETH[%d] on bus %s\n", dev->minor_drv,
>     -       priv = dev->priv = grlib_calloc(1, sizeof(*priv));
>     -       if ( !priv )
>     -               return DRVMGR_NOMEM;
>     -       priv->dev = dev;
>     -       /* This core will not find other cores, so we wait for
>     init3() */
>     -       return DRVMGR_OK;
>     -    struct rtems_bsdnet_ifconfig *ifp;
>     -    rtems_status_code status;
>     -    sc = dev->priv;
>     -    sprintf(sc->devName, "gr_eth%d", (dev->minor_drv+1));
>     -    /* Init GRETH device */
>     -    if ( greth_device_init(sc) ) {
>     -        printk("GRETH: Failed to init device\n");
>     -        return DRVMGR_FAIL;
>     -    /* Initialize Spin-lock for GRSPW Device. This is to protect
>     -     * CTRL and DMACTRL registers from ISR.
>     -    SPIN_INIT(&sc->devlock, sc->devName);
>     -    /* Register GRETH device as an Network interface */
>     -    ifp = grlib_calloc(1, sizeof(*ifp));
>     -    ifp->name = sc->devName;
>     -    ifp->drv_ctrl = sc;
>     -    ifp->attach = greth_interface_driver_attach;
>     -    status = network_interface_add(ifp);
>     -    if (status != 0) {
>     -    return DRVMGR_OK;
>     -    struct amba_dev_info *ambadev;
>     -    struct ambapp_core *pnpinfo;
>     -    union drvmgr_key_value *value;
>     -    /* Get device information from AMBA PnP information */
>     -    ambadev = (struct amba_dev_info *)sc->dev->businfo;
>     -    if ( ambadev == NULL ) {
>     -        return -1;
>     -    pnpinfo = &ambadev->info;
>     -    sc->regs = (greth_regs *)pnpinfo->apb_slv->start;
>     -    sc->minor = sc->dev->minor_drv;
>     -    sc->greth_rst = 1;
>     -    /* Remember EDCL enabled/disable state before reset */
>     -    sc->edcl_dis = sc->regs->ctrl & GRETH_CTRL_ED;
>     -    /* Default is to inherit EDCL Disable bit from HW. User can
>     force En/Dis */
>     -    value = drvmgr_dev_key_get(sc->dev, "edclDis", DRVMGR_KT_INT);
>     -    if ( value ) {
>     -        /* Force EDCL mode. Has an effect later when GRETH+PHY is
>     initialized */
>     -        if (value->i > 0) {
>     -            sc->edcl_dis = GRETH_CTRL_ED;
>     -        } else {
>     -            /* Default to avoid soft-reset the GRETH when EDCL is
>     forced */
>     -            sc->edcl_dis = 0;
>     -            sc->greth_rst = 0;
>     -    /* let user control soft-reset of GRETH (for debug) */
>     -    value = drvmgr_dev_key_get(sc->dev, "soft-reset", DRVMGR_KT_INT);
>     -    if ( value) {
>     -        sc->greth_rst = value->i ? 1 : 0;
>     -    /* clear control register and reset NIC and keep current
>     speed modes.
>     -     * This should be done as quick as possible during startup,
>     this is to
>     -     * stop DMA transfers after a reboot.
>     -     * When EDCL is forced enabled reset is skipped, disabling
>     RX/TX DMA is
>     -     * is enough during debug.
>     GRETH_CTRL_FULLD);
>     -    /* Configure driver by overriding default config with the bus
>     resources
>     -     * configured by the user
>     -    sc->txbufs = 32;
>     -    sc->rxbufs = 32;
>     -    sc->phyaddr = -1;
>     -    value = drvmgr_dev_key_get(sc->dev, "txDescs", DRVMGR_KT_INT);
>     -    if ( value && (value->i <= 128) )
>     -        sc->txbufs = value->i;
>     -    value = drvmgr_dev_key_get(sc->dev, "rxDescs", DRVMGR_KT_INT);
>     -        sc->rxbufs = value->i;
>     -    value = drvmgr_dev_key_get(sc->dev, "phyAdr", DRVMGR_KT_INT);
>     -    if ( value && (value->i < 32) )
>     -        sc->phyaddr = value->i;
>     -    value = drvmgr_dev_key_get(sc->dev, "advModes", DRVMGR_KT_INT);
>     -    if ( value )
>     -        sc->advmodes = value->i;
>     -    /* Check if multicast support is available */
>     -    sc->mc_available = sc->regs->ctrl & GRETH_CTRL_MC;
>     -    return 0;
>     -       char buf[64];
>     -       if (dev->priv == NULL)
>     -               return -DRVMGR_EINVAL;
>     -       sc = dev->priv;
>     -       sprintf(buf, "IFACE NAME:  %s", sc->devName);
>     -       print_line(p, buf);
>     -       sprintf(buf, "GBIT MAC:    %s", sc->gbit_mac ? "YES" : "NO");
>     -       return DRVMGR_OK;
>     -#endif
>     -#endif
>     diff --git a/bsps/shared/grlib/net/network_interface_add.c
>     b/bsps/shared/grlib/net/network_interface_add.c
>     index 011137404f..0000000000
>     --- a/bsps/shared/grlib/net/network_interface_add.c
>     +++ /dev/null
>     @@ -1,62 +0,0 @@
>     -/*  Network interface register help function
>     - *  COPYRIGHT (c) 2008.
>     - *  Cobham Gaisler AB.
>     - *  This function adds a network interface to the
>     - *  rtems_bsdnet_config.ifconfig linked list of interfaces.
>     - *  The interface configuration is taken from the user defined
>     - *  array interface_configs. This function is useful for PnP
>     - *  systems when an unknown number of interfaces are available.
>     -#include <stdio.h>
>     -#include <grlib/network_interface_add.h>
>     -extern struct rtems_bsdnet_config rtems_bsdnet_config;
>     -/* Number of interfaces taken */
>     -int network_interface_cnt = 0;
>     -       struct ethernet_config *cfg = NULL;
>     -       int i, last_entry = 1;
>     -       /* Init interface description */
>     -       interface->next = NULL;
>     -       cfg = &interface_configs[network_interface_cnt];
>     -       for(i=0; i<6; i++) {
>     -               if ( cfg->eth_adr[i] != 0 ) {
>     -                       last_entry = 0;
>     -                       break;
>     -       /* Do we have a valid configuration? */
>     -       if ( last_entry == 0 ) {
>     -               interface->ip_address = cfg->ip_addr;
>     -               interface->ip_netmask = cfg->ip_netmask;
>     -               interface->hardware_address = cfg->eth_adr;
>     -               network_interface_cnt++;
>     -       } else {
>     -               interface->ip_address = NULL;
>     -               interface->ip_netmask = NULL;
>     -               interface->hardware_address = NULL;
>     -       /* Insert interface first into list */
>     -       interface->next = rtems_bsdnet_config.ifconfig;
>     -       rtems_bsdnet_config.ifconfig = interface;
>     -       return 0;
>     2.17.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201025/4c9e6c5e/attachment-0001.html>
