LibBSD PowerPC motorola_shared BSP PCI Support
Joel Sherrill
joel at rtems.org
Tue Oct 27 18:18:34 UTC 2020
I
On Tue, Oct 27, 2020, 12:42 PM Sebastian Huber <
> On 27/10/2020 15:41, Joel Sherrill wrote:
> > On Tue, Oct 27, 2020 at 9:23 AM Heinz Junkes <junkes at fhi-berlin.mpg.de
> > <mailto:junkes at fhi-berlin.mpg.de>> wrote:
> > I am currently trying git rtems6.
> > ../source-builder/sb-set-builder --prefix=$HOME/.rtems --log
> > powerpc_beatnik.log --no-clean --target=powerpc-rtems6
> > --with-rtems-bsp=beatnik 6/rtems-powerpc 6/rtems-kernel
> > works …
> > Unfortunately It fails here:
> > libbsd.log --no-clean --target=powerpc-rtems6
> > --with-rtems-bsp=beatnik --host=powerpc-rtems6 6/rtems-libbsd
> > [1562/1948] Compiling freebsd/sbin/nvmecontrol/ns.c
> > In file included from
> > /home/ad/.rtems/lib/gcc/powerpc-rtems6/10.2.1/include/c++/cstdlib:75,
> > from
> /home/ad/.rtems/lib/gcc/powerpc-rtems6/10.2.1/include/c++/stdlib.h:36,
> > from ../../freebsd/sys/sys/libkern.h:216,
> > from ../../freebsd/sys/sys/systm.h:543,
> > from ../../freebsd/sys/sys/mbuf.h:42,
> > from ../../rtemsbsd/rtems/rtems-bsd-cxx.cc:48:
> > /home/ad/.rtems/powerpc-rtems6/include/stdlib.h:309:6: error:
> > conflicting declaration of C function 'void qsort_r(void*, size_t,
> > size_t, int (*)(const void*, const void*, void*
> > ), void*)'
> > 309 | void qsort_r (void *__base, size_t __nmemb, size_t __size,
> > int (*_compar)(const void *, const void *, void *), void *__thunk);
> > In file included from ../../freebsd/sys/sys/systm.h:543,
> > ../../freebsd/sys/sys/libkern.h:211:7: note: previous declaration
> > 'void qsort_r(void*, size_t, size_t, void*, int (*)(void*, const
> > void*, const void*))'
> > 211 | void qsort_r(void *base, size_t nmemb, size_t size, void
> > *thunk,
> > Waf: Leaving directory
> `/home/ad/RTEMS_DEV/rtems-source-builder/rtems/build/rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1/rtems-libbsd-d964a6703c705cc9
> > 2fd053bcefc08bb3b6baa0e2/build/powerpc-rtems6-beatnik-default'
> > Build failed
> > -> task in 'bsd' failed with exit status 1 (run with -v to
> > display more information)
> > shell cmd failed: /bin/sh -ex
> /home/ad/RTEMS_DEV/rtems-source-builder/rtems/build/rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1/do-build
> > error: building
> > I'm not sure why this would not have shown up before but the FreeBSD
> > kernel reuses some standard library method names with different
> > signatures. The
> > file rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h renames a
> > lot of items to put them in a BSD namespace. qsort_r isn't in this
> > list but perhaps should be.
> I think its is this bug:
> https://devel.rtems.org/ticket/4078
> I added a workaround to the latest master and 6-freebsd-12 branches.
Why don't we fix it in the gcc sources for 5 and later? Any code fixing
this breaks was already broken
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201027/ef12c6aa/attachment.html>
