Change newlib daddr_t to 64 bits
Joel Sherrill
joel at rtems.org
Tue Oct 27 20:48:02 UTC 2020
On Tue, Oct 27, 2020, 3:44 PM Chris Johns <chrisj at rtems.org> wrote:
> On 28/10/20 7:14 am, Joel Sherrill wrote:
> > Chris asked about a patch to newlib to make daddr_t 64-bits since it
> represents
> > a disk address. I haven't tested this because gcc master isn't building
> for me.
> > If this works Chris, I will post it to newlib.
> The change works with the RTEMS 6 tools I have. I patched this file
> manually and
> the effected code built.
> Can the change be added to the RBS for the RTEMS 6 tools?
I can't get gcc master to build to verify this patch.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201027/4638fed4/attachment.html>
