Introducing the Strong APA Scheduler
Richi Dubey
richidubey at gmail.com
Wed Oct 28 09:26:58 UTC 2020
Hi,
--- a/cpukit/include/rtems/confdefs/scheduler.h
> +++ b/cpukit/include/rtems/confdefs/scheduler.h
> @@ -55,9 +55,9 @@
> && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
> && !defined(CONFIGURE_SCHEDULER_USER)
> #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
> - #define CONFIGURE_SCHEDULER_EDF_SMP
> + #define CONFIGURE_SCHEDULER_STRONG_APA
> #else
> - #define CONFIGURE_SCHEDULER_PRIORITY
This won't work anymore because the scheduler.h file has been changed in
the current master. I am having difficulty trying to achieve the same
outcome in the new file. Please guide me.
Thanks,
Richi.
On Mon, Sep 7, 2020 at 11:28 AM Sebastian Huber <
> On 03/09/2020 17:10, Richi Dubey wrote:
> > Any views on this?
> Sorry for the delay. Did you run the test suite with this scheduler as
> the default and check how many tests pass?
> diff --git a/cpukit/include/rtems/confdefs/scheduler.h
> index 9305fc2d90..63f4be4247 100644
> @@ -55,9 +55,9 @@
> #else
> #endif
> #endif
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201028/de7f6379/attachment.html>
