[PATCH v2] Add networking support for griscv bsp
Jiri Gaisler jiri at gaisler.se
Wed Oct 28 16:57:37 UTC 2020
	* Only GRETH device supported for now
	* Fix endian problem in GRETH driver
	* Remove SPARC assembly from greth.c
	* Builds with both autoconf and waf
 bsps/riscv/griscv/console/console.c          |  2 +-
 bsps/riscv/griscv/include/bsp.h              | 14 +++++
 bsps/riscv/griscv/net/griscv_greth.c         | 59 ++++++++++++++++++++
 bsps/shared/grlib/net/greth.c                | 23 ++++----
 bsps/shared/net/greth2.c                     |  6 +-
 c/src/lib/libbsp/riscv/griscv/Makefile.am    |  6 ++
 spec/build/bsps/riscv/griscv/objnetnosmp.yml | 18 ++++++
 7 files changed, 114 insertions(+), 14 deletions(-)
 create mode 100644 bsps/riscv/griscv/net/griscv_greth.c
 create mode 100644 spec/build/bsps/riscv/griscv/objnetnosmp.yml
diff --git a/bsps/riscv/griscv/console/console.c b/bsps/riscv/griscv/console/console.c
index 582b4c81b8..c92be99fdb 100644
--- a/bsps/riscv/griscv/console/console.c
+++ b/bsps/riscv/griscv/console/console.c
@@ -64,7 +64,7 @@ static int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
   /* Extract needed information of one APBUART */
   apbuarts[uarts].regs = (struct apbuart_regs *)apb->start;
-  apbuarts[uarts].irq = apb->irq;
+  apbuarts[uarts].irq = apb->common.irq;
   /* Get APBUART core frequency, it is assumed that it is the same
    * as Bus frequency where the UART is situated
diff --git a/bsps/riscv/griscv/include/bsp.h b/bsps/riscv/griscv/include/bsp.h
index 95cccd3d0a..9d6fb2a16f 100644
--- a/bsps/riscv/griscv/include/bsp.h
+++ b/bsps/riscv/griscv/include/bsp.h
@@ -75,6 +75,20 @@ extern void BSP_shared_interrupt_mask(int irq);
 extern void BSP_shared_interrupt_clear(int irq);
 extern void BSP_shared_interrupt_unmask(int irq);
+ * Network driver configuration for greth
+struct rtems_bsdnet_ifconfig;
+extern int rtems_griscv_greth_driver_attach(
+  struct rtems_bsdnet_ifconfig *config,
+  int attach
+#define RTEMS_BSP_NETWORK_DRIVER_NAME "gr_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_griscv_greth_driver_attach
+#define GRETH_SUPPORTED
+#define CPU_U32_FIX
 #ifdef __cplusplus
 #endif
diff --git a/bsps/riscv/griscv/net/griscv_greth.c b/bsps/riscv/griscv/net/griscv_greth.c
new file mode 100644
index 0000000000..e5c05fd060
--- /dev/null
+++ b/bsps/riscv/griscv/net/griscv_greth.c
@@ -0,0 +1,59 @@
+ *  LEON3 Opencores Ethernet MAC Configuration Information
+ *  COPYRIGHT (c) 2004.
+ *  Gaisler Research
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <bsp.h>
+#include <amba.h>
+#include <grlib/ambapp.h>
+#include <libchip/greth.h>
+/*#if (GRETH_DEBUG & GRETH_DEBUG_PRINT_REGISTERS)*/
+#include <stdio.h>
+/*#endif*/
+ * Default sizes of transmit and receive descriptor areas
+#define RDA_COUNT     32
+#define TDA_COUNT     32
+greth_configuration_t griscv_greth_configuration;
+int rtems_griscv_greth_driver_attach(
+  int attach
+  unsigned int base_addr = 0; /* avoid warnings */
+  unsigned int eth_irq = 0;   /* avoid warnings */
+  struct ambapp_dev *adev;
+  struct ambapp_apb_info *apb;
+  /* Scan for MAC AHB slave interface */
+  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
+                                 VENDOR_GAISLER, GAISLER_ETHMAC,
+                                 ambapp_find_by_idx, NULL);
+  if (adev) {
+    apb = DEV_TO_APB(adev);
+    base_addr = apb->start;
+    eth_irq = apb->common.irq;
+    /* clear control register and reset NIC */
+    *(volatile int *) base_addr = 0;
+    *(volatile int *) base_addr = GRETH_CTRL_RST;
+    griscv_greth_configuration.base_address = (void*)base_addr;
+    griscv_greth_configuration.vector = eth_irq; /* on LEON vector is IRQ no. */
+    griscv_greth_configuration.txd_count = TDA_COUNT;
+    griscv_greth_configuration.rxd_count = RDA_COUNT;
+    rtems_greth_driver_attach(config, &griscv_greth_configuration);
+  return 0;
diff --git a/bsps/shared/grlib/net/greth.c b/bsps/shared/grlib/net/greth.c
index bc4d3cc40f..2daa38e3fc 100644
--- a/bsps/shared/grlib/net/greth.c
+++ b/bsps/shared/grlib/net/greth.c
@@ -721,10 +721,13 @@ void ipalign(struct mbuf *m)
   unsigned int tmp = 0;
   if ((((int) m->m_data) & 2) && (m->m_len)) {
+#if CPU_LITTLE_ENDIAN == TRUE
+    memmove((caddr_t)(((int) m->m_data) + 2), m->m_data, m->m_len);
+#else
     last = (unsigned int *) ((((int) m->m_data) + m->m_len + 8) & ~3);
     first = (unsigned int *) (((int) m->m_data) & ~3);
 		/* tmp = *first << 16; */
-		asm volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(first) );
+		tmp = GRETH_MEM_LOAD(first);
 		tmp = tmp << 16;
     first++;
     do {
@@ -733,12 +736,12 @@ void ipalign(struct mbuf *m)
 			 ** Load with forced cache miss
 			 * data = *first;
-      asm volatile (" lda [%1] 1, %0\n" : "=r"(data) : "r"(first) );
+      data = GRETH_MEM_LOAD(first);
       *first = tmp | (data >> 16);
       tmp = data << 16;
       first++;
     } while (first <= last);
+#endif
     m->m_data = (caddr_t)(((int) m->m_data) + 2);
@@ -756,7 +759,6 @@ greth_Daemon (void *arg)
     SPIN_IRQFLAGS(flags);
     int first;
     int tmp;
-    unsigned int addr;
     for (;;)
@@ -836,14 +838,11 @@ again:
 #ifdef CPU_U32_FIX
                             if(!dp->gbit_mac) {
                                     /* OVERRIDE CACHED ETHERNET HEADER FOR NON-SNOOPING SYSTEMS */
-                                    addr = (unsigned int)eh;
-                                    asm volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(addr) );
-                                    addr+=4;
-                                    addr+=4;
-                                    addr+=4;
+                                    tmp = GRETH_MEM_LOAD((uintptr_t)eh);
+                                    tmp = GRETH_MEM_LOAD(4+(uintptr_t)eh);
+                                    tmp = GRETH_MEM_LOAD(8+(uintptr_t)eh);
+                                    tmp = GRETH_MEM_LOAD(12+(uintptr_t)eh);
+				    (void)tmp;
                                     ipalign(m);	/* Align packet on 32-bit boundary */
diff --git a/bsps/shared/net/greth2.c b/bsps/shared/net/greth2.c
index 2fc35a5471..13bf7b8884 100644
--- a/bsps/shared/net/greth2.c
+++ b/bsps/shared/net/greth2.c
@@ -21,6 +21,7 @@
 #include <rtems/bspIo.h>
+#include <string.h>
 #include <stdarg.h>
 #include <rtems/error.h>
@@ -514,6 +515,9 @@ void ipalign(struct mbuf *m)
   unsigned int tmp;
+#else
@@ -529,7 +533,7 @@ void ipalign(struct mbuf *m)
       tmp = data << 16;
       first++;
+#endif
diff --git a/c/src/lib/libbsp/riscv/griscv/Makefile.am b/c/src/lib/libbsp/riscv/griscv/Makefile.am
index e04598e4bf..07f5cc03ca 100644
--- a/c/src/lib/libbsp/riscv/griscv/Makefile.am
+++ b/c/src/lib/libbsp/riscv/griscv/Makefile.am
@@ -64,6 +64,12 @@ if HAS_SMP
 librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/griscv/start/bspsmp.c
 endif
+if HAS_NETWORKING
+if !HAS_SMP
+librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/griscv/net/griscv_greth.c
+endif
+endif
 include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
 include $(srcdir)/../../../../../../bsps/shared/grlib-sources.am
 include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
diff --git a/spec/build/bsps/riscv/griscv/objnetnosmp.yml b/spec/build/bsps/riscv/griscv/objnetnosmp.yml
index 0000000000..105a23351d
--- /dev/null
+++ b/spec/build/bsps/riscv/griscv/objnetnosmp.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by:
+- and:
+  - RTEMS_NETWORKING
+  - not: RTEMS_SMP
+includes:
+- cpukit/libnetworking
+install: []
+links: []
+source:
+- bsps/riscv/griscv/net/griscv_greth.c
+type: build
2.17.1
