LibBSD PowerPC motorola_shared BSP PCI Support
Fri Oct 30 02:31:01 UTC 2020
On Thu, Oct 29, 2020, 6:07 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> I can now run the test programs of libbsd. But on the MVME6100
> no network interfaces gets found.
> MVME6100> netShut
> config addr is 0xf1000cf8
> config data is 0xf1000cfc
> Welcome to RTEMS rtems-6.0.0 (PowerPC/Generic (classic FPU)/beatnik)
> CPU: MPC7457
> Board Type: MVME6100-0163 (S/N E173D27)
> Bus Clock Freq:   133333333 Hz
> CPU Clock Freq:  1266666654 Hz
> Memory:           536870912 bytes
> Now BSP_mem_size = 0x1fe00000
> Configuration.work_space_size = ed620
> Page table setup finished; will activate it NOW...
> Going to start PCI buses scanning and initialization
> Number of PCI buses found is : 3
> MSR 0x2003032
> Exit from bspstart
> unable to find the universe in pci config space
> Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
> Tsi148 Outbound Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0e000000 0x90000000 A32, SUP, D32, SCT
> 1:    0x00000000 0x00ff0000 0x9f000000 A24, SUP, D32, SCT
> 2:    0x00000000 0x00010000 0x9fff0000 A16, SUP, D32, SCT
> 7:    0x00000000 0x01000000 0x9e000000 CSR, SUP, D32, SCT
> Tsi148 Inbound Ports:
> 0:    0x90000000 0x1fe00000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
> vmeTsi148 IRQ manager: looking for registers on VME...
> Trying to find CSR on VME...
> vmeTsi148 - IRQ manager using VME CSR to flush FIFO
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> *** BEGIN OF TEST LIBBSD DHCPCD 1 ***
> *** TEST VERSION: 6.0.0.5f4fd63a0c2b4b0657b64abdcfa70c47bee21c52
> *** TEST STATE: EXPECTED_PASS
> *** TEST BUILD: RTEMS_POSIX_API
> *** TEST TOOLS: 10.2.1 20201026 (RTEMS 6, RSB
> 5f4fd63a0c2b4b0657b64abdcfa70c47bee21c52, Newlib 17b7dfc)
> RTEMS Shell on /dev/console. Use 'help' to list commands.
> SHLL [/] # xus0: <RTEMS Nexus device>
> [zone: unpcb] kern.ipc.maxsockets limit reached
> info: lo0: link state changed to UP
> info: version 6.2.1 starting
> err: no valid interfaces found
> warning: no interfaces have a carrier
Afaik the mvme6100 does not have a configuration in libbsd. My recollection
(which could be wrong) is that there isn't a libbsd driver in the tree for
the NIC.
There was a table in Chris' EPICS slides about which bsps we thought needed
attention with notes on the drivers.
And the mvme2500 wasn't on the list. I think we may need an alias or some
documentation on this BSP.
> Viele Grüße
> Heinz Junkes
> Experience directly varies with equipment ruined.
> > On 27. Oct 2020, at 18:41, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > On 27/10/2020 15:41, Joel Sherrill wrote:
> >> On Tue, Oct 27, 2020 at 9:23 AM Heinz Junkes <junkes at fhi-berlin.mpg.de
> <mailto:junkes at fhi-berlin.mpg.de>> wrote:
> >>    I am currently trying git rtems6.
> >>    ../source-builder/sb-set-builder --prefix=$HOME/.rtems --log
> >>    powerpc_beatnik.log --no-clean --target=powerpc-rtems6
> >>    --with-rtems-bsp=beatnik 6/rtems-powerpc 6/rtems-kernel
> >>    works …
> >>    Unfortunately It fails here:
> >>    libbsd.log --no-clean --target=powerpc-rtems6
> >>    --with-rtems-bsp=beatnik --host=powerpc-rtems6 6/rtems-libbsd
> >>    [1562/1948] Compiling freebsd/sbin/nvmecontrol/ns.c
> >>    In file included from
> >>    /home/ad/.rtems/lib/gcc/powerpc-rtems6/10.2.1/include/c++/cstdlib:75,
> >>                     from
> /home/ad/.rtems/lib/gcc/powerpc-rtems6/10.2.1/include/c++/stdlib.h:36,
> >>                     from ../../freebsd/sys/sys/libkern.h:216,
> >>                     from ../../freebsd/sys/sys/systm.h:543,
> >>                     from ../../freebsd/sys/sys/mbuf.h:42,
> >>                     from ../../rtemsbsd/rtems/rtems-bsd-cxx.cc:48:
> >>    /home/ad/.rtems/powerpc-rtems6/include/stdlib.h:309:6: error:
> >>    conflicting declaration of C function 'void qsort_r(void*, size_t,
> >>    size_t, int (*)(const void*, const void*, void*
> >>    ), void*)'
> >>      309 | void qsort_r (void *__base, size_t __nmemb, size_t __size,
> >>    int (*_compar)(const void *, const void *, void *), void *__thunk);
> >>    In file included from ../../freebsd/sys/sys/systm.h:543,
> >>    ../../freebsd/sys/sys/libkern.h:211:7: note: previous declaration
> >>    'void qsort_r(void*, size_t, size_t, void*, int (*)(void*, const
> >>    void*, const void*))'
> >>      211 | void  qsort_r(void *base, size_t nmemb, size_t size, void
> >>    *thunk,
> >>    Waf: Leaving directory
> `/home/ad/RTEMS_DEV/rtems-source-builder/rtems/build/rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1/rtems-libbsd-d964a6703c705cc9
> >>    2fd053bcefc08bb3b6baa0e2/build/powerpc-rtems6-beatnik-default'
> >>    Build failed
> >>     -> task in 'bsd' failed with exit status 1 (run with -v to
> >>    display more information)
> >>    shell cmd failed: /bin/sh -ex
> /home/ad/RTEMS_DEV/rtems-source-builder/rtems/build/rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1/do-build
> >>    error: building
> >> I'm not sure why this would not have shown up before but the FreeBSD
> kernel reuses some standard library method names with different signatures.
> The file rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h renames a
> lot of items to put them in a BSD namespace. qsort_r isn't in this list but
> perhaps should be.
> > I think its is this bug:
> > https://devel.rtems.org/ticket/4078
> > I added a workaround to the latest master and 6-freebsd-12 branches.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201029/955c98f0/attachment.html>
