Patch needed for GCC 9?
Fri Oct 30 07:58:39 UTC 2020
On 29/10/2020 22:15, Joel Sherrill wrote:
> When I build RTEMS with GCC 9 (sparc/leon3) to get Coverity results, I
> get this error linking tests that I don't get with gcc 10. I am using
> the same newlib and binutils-gdb source so I am a bit confused. Are
> there patches in GCC 10 that I need on GCC 9?
I think you have to back port:
commit 4461384026a708bc0267b2965144b42f95689974
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date:   Mon Apr 6 16:34:50 2020 +0200
     RTEMS: Improve GCC specification
     Add a start/end file specification if the -qrtems option is present.
     Allow targets to customize it.
     Support the standard -nodefaultlibs option.
     gcc/
             * config/rtems.h (RTEMS_STARTFILE_SPEC): Define if undefined.
             (RTEMS_ENDFILE_SPEC): Likewise.
             (STARTFILE_SPEC): Update comment.  Add RTEMS_STARTFILE_SPEC.
             (ENDFILE_SPEC): Add RTEMS_ENDFILE_SPEC.
             (LIB_SPECS): Support -nodefaultlibs option.
             * config/or1k/rtems.h (RTEMS_STARTFILE_SPEC): Define.
             * config/rs6000/rtems.h (RTEMS_STARTFILE_SPEC): Likewise.
             * config/v850/rtems.h (RTEMS_STARTFILE_SPEC): Likewise.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
