Different files than the current master?
Richi Dubey
richidubey at gmail.com
Fri Oct 30 18:33:58 UTC 2020
HI Dr. Sherrill,
Thanks a lot for looking into this. I have realized my mistakes. I should
have looked around a bit more before asking on the devel.
On Fri, Oct 30, 2020 at 12:08 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Oct 29, 2020 at 10:53 AM Richi Dubey <richidubey at gmail.com> wrote:
>> Hi,
>> I have attached my cpukit/include/rtems/confdefs/scheduler.h with this
>> email, which is different from the current file that I should have, which
>> can be seen here:
>> https://git.rtems.org/rtems/tree/cpukit/include/rtems/confdefs/scheduler.h
> I think you are looking at the wrong file named scheduler.h. There are
> three options apparently:
> $ find cpukit/ -name scheduler.h
> cpukit/include/rtems/scheduler.h
> cpukit/include/rtems/score/scheduler.h
> And the file you attached looks more like cpukit/include/rtems/scheduler.h
> diff -u ~/Downloads/scheduler.h cpukit/include/rtems/scheduler.h
> --- /home/joel/Downloads/scheduler.h 2020-10-29 13:32:18.338022528 -0500
> +++ cpukit/include/rtems/scheduler.h 2020-10-12 16:26:27.858302686 -0500
> @@ -257,14 +257,16 @@
> #define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
> static struct { \
> Scheduler_strong_APA_Context Base; \
> - Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
> + Chain_Control Ready[ ( prio_count ) ]; \
> } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
> #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
> &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
> SCHEDULER_STRONG_APA_ENTRY_POINTS, \
> - SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
> + RTEMS_ARRAY_SIZE( \
> + SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
> + ) - 1, \
> ( obj_name ) \
> SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
>> On running :
>> $ git log --oneline
>> 68239434c2 (HEAD -> master, origin/master, origin/HEAD) score: Fix unused
>> parameter 'lock' warning
>> eebad5ffcd build: Improve cache handling
>> b052e3aefa build: Report caching errors
>> 99494370d6 bsp/stm32h7: New BSP
>> c44e404888 bsp/stm32h7: Fix warnings
>> I can verify that my RTEMS is at the current
>> <https://git.rtems.org/rtems/> master, why are the files different then?
>> - Richi
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201031/05dcf59f/attachment.html>
