Build Linux: FAILED 6/rtems-aarch64 on x86_64-linux-gnu (aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1)
Joel Sherrill
joel at rtems.org
Sat Oct 31 19:12:11 UTC 2020
Hi again,
This failed on FreeBSD, Ubuntu, and CentOS. Failure message is:
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1/build/./gcc/xgcc
-B/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1/build/./gcc/
-nostdinc
-B/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1/build/aarch64-rtems6/newlib/
-isystem
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1/build/aarch64-rtems6/newlib/targ-include
-isystem
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1/gnu-mirror-gcc-a78cd75/newlib/libc/include
-B/home/joel/rtems-cron-6/tools/6/aarch64-rtems6/bin/
-B/home/joel/rtems-cron-6/tools/6/aarch64-rtems6/lib/ -isystem
/home/joel/rtems-cron-6/tools/6/aarch64-rtems6/include -isystem
/home/joel/rtems-cron-6/tools/6/aarch64-rtems6/sys-include -g -O2
-mabi=ilp32 -O2
-I../../../../gnu-mirror-gcc-a78cd75/libgcc/../newlib/libc/sys/rtems/include
-g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall -Wno-narrowing
-Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes
-Wold-style-definition -isystem ./include -g -DIN_LIBGCC2
-fbuilding-libgcc -fno-stack-protector -Dinhibit_libc -I. -I.
-I../../.././gcc -I../../../../gnu-mirror-gcc-a78cd75/libgcc
-I../../../../gnu-mirror-gcc-a78cd75/libgcc/../gcc
-I../../../../gnu-mirror-gcc-a78cd75/libgcc/../include -DHAVE_CC_TLS -o
sfp-exceptions.o -MT sfp-exceptions.o -MD -MP -MF sfp-exceptions.dep -c
../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/sfp-exceptions.c
-fvisibility=hidden -DHIDE_EXPORTS
-nostdinc
-isystem
-isystem
-mabi=ilp32 -O2
-Wno-missing-prototypes -Wno-type-limits -o addtf3.o -MT addtf3.o -MD -MP
-MF addtf3.dep -c
../../../../gnu-mirror-gcc-a78cd75/libgcc/soft-fp/addtf3.c
/tmp/ccSQZBqd.s: Assembler messages:
/tmp/ccSQZBqd.s:89: Error: missing immediate expression at operand 1 --
`dsb ish'
/tmp/ccSQZBqd.s:138: Error: missing immediate expression at operand 1 --
`dsb ish'
I assume this is some transient synchronization issue between binutils and
gcc.
--joel
On Sat, Oct 31, 2020 at 10:25 AM Joel Sherrill <joel at rtems.org> wrote:
> FYI failed on Centos and Ubuntu. I am not seeing logs posted from FreeBSD
> but I thought I started one there.
> Not sure there is much to do beyond noting and reporting
> ---------- Forwarded message ---------
> From: <joel at rtems.org>
> Date: Fri, Oct 30, 2020, 5:48 PM
> Subject: Build Linux: FAILED 6/rtems-aarch64 on x86_64-linux-gnu
> To: <build at rtems.org>
> RTEMS Source Builder - Set Builder, 6 (4c5af1f7c155)
> Host: Linux-4.15.0-118-generic-x86_64-with-Ubuntu-18.04-bionic
> Linux rtbf64a 4.15.0-118-generic #119-Ubuntu SMP Tue Sep 8 12:30:01
> UTC
> 2020 x86_64 x86_64
> Build Time: 0:23:06.535945
> Build FAILED: aarch64-rtems6-gcc-a78cd75-newlib-fcaaf40-x86_64-linux-gnu-1
> ln -s
> ../../../../gnu-mirror-gcc-a78cd75/libgcc/enable-execute-stack-empty.c
> enable-execute-stack.c
> ln -s ../../../../gnu-mirror-gcc-a78cd75/libgcc/unwind-generic.h unwind.h
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> -I../../../gnu-mirror-gcc-a78cd75/libgcc/../newlib/libc/sys/rtems/include
> -I../.././gcc -I../../../gnu-mirror-gcc-a78cd75/libgcc
> -I../../../gnu-mirror-gcc-a78cd75/libgcc/../gcc
> -I../../../gnu-mirror-gcc-a78cd75/libgcc/../include -DHAVE_CC_TLS -o
> cas_16_2.o -MT cas_16_2.o -MD -MP -MF cas_16_2.dep -DL_cas -DSIZE=16
> -DMODEL=2 -c ../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> ln -s
> ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/aarch64-unwind.h
> md-unwind-support.h
> ln -s
> ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/sfp-machine.h
> sfp-machine.h
> ln -s ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/gthr-rtems.h
> gthr-default.h
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_1_3.o -MT cas_1_3.o -MD -MP -MF cas_1_3.dep -DL_cas -DSIZE=1 -DMODEL=3
> DEFINES=''
> HEADERS='../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/value-unwind.h'
> ../../../../gnu-mirror-gcc-a78cd75/libgcc/mkheader.sh >
> tmp-libgcc_tm.h
> /bin/bash ../../../../gnu-mirror-gcc-a78cd75/libgcc/../move-if-change
> tmp-libgcc_tm.h libgcc_tm.h
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_2_3.o -MT cas_2_3.o -MD -MP -MF cas_2_3.dep -DL_cas -DSIZE=2 -DMODEL=3
> echo timestamp > libgcc_tm.stamp
> dest=../../.././gcc/include/tmp$$-unwind.h; \
> cp unwind.h $dest; \
> chmod a+r $dest; \
> sh ../../../../gnu-mirror-gcc-a78cd75/libgcc/../move-if-change $dest
> ../../.././gcc/include/unwind.h
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_4_3.o -MT cas_4_3.o -MD -MP -MF cas_4_3.dep -DL_cas -DSIZE=4 -DMODEL=3
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_8_3.o -MT cas_8_3.o -MD -MP -MF cas_8_3.dep -DL_cas -DSIZE=8 -DMODEL=3
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_16_3.o -MT cas_16_3.o -MD -MP -MF cas_16_3.dep -DL_cas -DSIZE=16
> -DMODEL=3 -c ../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -mabi=ilp32 -O2
> cas_1_1.o -MT cas_1_1.o -MD -MP -MF cas_1_1.dep -DL_cas -DSIZE=1 -DMODEL=1
> -c ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_1_4.o -MT cas_1_4.o -MD -MP -MF cas_1_4.dep -DL_cas -DSIZE=1 -DMODEL=4
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_2_4.o -MT cas_2_4.o -MD -MP -MF cas_2_4.dep -DL_cas -DSIZE=2 -DMODEL=4
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_4_4.o -MT cas_4_4.o -MD -MP -MF cas_4_4.dep -DL_cas -DSIZE=4 -DMODEL=4
> -nostdinc
> -isystem
> -isystem
> cas_2_1.o -MT cas_2_1.o -MD -MP -MF cas_2_1.dep -DL_cas -DSIZE=2 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_8_4.o -MT cas_8_4.o -MD -MP -MF cas_8_4.dep -DL_cas -DSIZE=8 -DMODEL=4
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> cas_16_4.o -MT cas_16_4.o -MD -MP -MF cas_16_4.dep -DL_cas -DSIZE=16
> -DMODEL=4 -c ../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> cas_4_1.o -MT cas_4_1.o -MD -MP -MF cas_4_1.dep -DL_cas -DSIZE=4 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> cas_8_1.o -MT cas_8_1.o -MD -MP -MF cas_8_1.dep -DL_cas -DSIZE=8 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> swp_1_1.o -MT swp_1_1.o -MD -MP -MF swp_1_1.dep -DL_swp -DSIZE=1 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> cas_16_1.o -MT cas_16_1.o -MD -MP -MF cas_16_1.dep -DL_cas -DSIZE=16
> -DMODEL=1 -c ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldadd_1_1.o -MT ldadd_1_1.o -MD -MP -MF ldadd_1_1.dep -DL_ldadd -DSIZE=1
> -DMODEL=1 -c ../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> cas_1_2.o -MT cas_1_2.o -MD -MP -MF cas_1_2.dep -DL_cas -DSIZE=1 -DMODEL=2
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldclr_1_1.o -MT ldclr_1_1.o -MD -MP -MF ldclr_1_1.dep -DL_ldclr -DSIZE=1
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldeor_1_1.o -MT ldeor_1_1.o -MD -MP -MF ldeor_1_1.dep -DL_ldeor -DSIZE=1
> -nostdinc
> -isystem
> -isystem
> cas_2_2.o -MT cas_2_2.o -MD -MP -MF cas_2_2.dep -DL_cas -DSIZE=2 -DMODEL=2
> -nostdinc
> -isystem
> -isystem
> cas_4_2.o -MT cas_4_2.o -MD -MP -MF cas_4_2.dep -DL_cas -DSIZE=4 -DMODEL=2
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldset_1_1.o -MT ldset_1_1.o -MD -MP -MF ldset_1_1.dep -DL_ldset -DSIZE=1
> -nostdinc
> -isystem
> -isystem
> cas_8_2.o -MT cas_8_2.o -MD -MP -MF cas_8_2.dep -DL_cas -DSIZE=8 -DMODEL=2
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> swp_2_1.o -MT swp_2_1.o -MD -MP -MF swp_2_1.dep -DL_swp -DSIZE=2 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> -DMODEL=2 -c ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldadd_2_1.o -MT ldadd_2_1.o -MD -MP -MF ldadd_2_1.dep -DL_ldadd -DSIZE=2
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldclr_2_1.o -MT ldclr_2_1.o -MD -MP -MF ldclr_2_1.dep -DL_ldclr -DSIZE=2
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldeor_2_1.o -MT ldeor_2_1.o -MD -MP -MF ldeor_2_1.dep -DL_ldeor -DSIZE=2
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> -DMODEL=3 -c ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldset_2_1.o -MT ldset_2_1.o -MD -MP -MF ldset_2_1.dep -DL_ldset -DSIZE=2
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> swp_4_1.o -MT swp_4_1.o -MD -MP -MF swp_4_1.dep -DL_swp -DSIZE=4 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldadd_4_1.o -MT ldadd_4_1.o -MD -MP -MF ldadd_4_1.dep -DL_ldadd -DSIZE=4
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldclr_4_1.o -MT ldclr_4_1.o -MD -MP -MF ldclr_4_1.dep -DL_ldclr -DSIZE=4
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldeor_4_1.o -MT ldeor_4_1.o -MD -MP -MF ldeor_4_1.dep -DL_ldeor -DSIZE=4
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldset_4_1.o -MT ldset_4_1.o -MD -MP -MF ldset_4_1.dep -DL_ldset -DSIZE=4
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> swp_8_1.o -MT swp_8_1.o -MD -MP -MF swp_8_1.dep -DL_swp -DSIZE=8 -DMODEL=1
> -nostdinc
> -isystem
> -isystem
> -DMODEL=4 -c ../../../../gnu-mirror-gcc-a78cd75/libgcc/config/aarch64/lse.S
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldadd_8_1.o -MT ldadd_8_1.o -MD -MP -MF ldadd_8_1.dep -DL_ldadd -DSIZE=8
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> ldclr_8_1.o -MT ldclr_8_1.o -MD -MP -MF ldclr_8_1.dep -DL_ldclr -DSIZE=8
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> -nostdinc
> -isystem
> -isystem
> nclude -g -O2 -O2
> -Wold-style-defini
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201031/7e8a28a0/attachment-0001.html>
