[PATCH] eng: Update the python template, add a shell template
Sebastian Huber
Tue Sep 1 04:45:33 UTC 2020
On 01/09/2020 04:10, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> eng/coding-file-hdr.rst | 62 ++++++++++++++++++++++++++++++++++++++---
> 1 file changed, 58 insertions(+), 4 deletions(-)
> diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
> index cda631a..dafe82c 100644
> --- a/eng/coding-file-hdr.rst
> +++ b/eng/coding-file-hdr.rst
> @@ -92,7 +92,7 @@ Use the following guidelines and template for C and C++ header files (here
> * Separate the Doxygen comment block from the copyright and license, so that
> the copyright and license information is not included in the Doxygen output.
> -* For C++ header files discard the extern "C".
> +* For C++ header files discard the ``extern "C"`` start and end sections.
> .. code-block:: c
> @@ -138,12 +138,14 @@ Use the following guidelines and template for C and C++ header files (here
> #include <foo/bar/xyz.h>
> + /* Remove for C++ code */
> #ifdef __cplusplus
> extern "C" {
> #endif
> /* Declarations, defines, macros, inline functions, etc. */
> #ifdef __cplusplus
> #endif
> @@ -207,13 +209,65 @@ and <COPYRIGHT HOLDER> placeholders see :ref:`FileHeaderCopyright`.
> Python File Template
> -Use the following template for Python source files and other files which accept
> -a ``#``-style comment block. For the <FIRST YEAR>, <LAST YEAR>, and
> -<COPYRIGHT HOLDER> placeholders see :ref:`FileHeaderCopyright`.
> +Use the following template for Python source files. For the <FIRST YEAR>,
> +<LAST YEAR>, and <COPYRIGHT HOLDER> placeholders see
> +:ref:`FileHeaderCopyright`.
> +The ``File documentation block`` is a Python docstring module documentation
Maybe add a link to:
https://www.python.org/dev/peps/pep-0257/
> +block.
> +.. code-block:: python
> + # SPDX-License-Identifier: BSD-2-Clause
> + '''File documentation block'''
All the examples in PEP 257 use """ strings. I used this style for all
the new Python code in rtems-central. Could we use """ instead of '''?
> + # Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
> + # Redistribution and use in source and binary forms, with or without
> + # modification, are permitted provided that the following conditions
> + # are met:
> + # 1. Redistributions of source code must retain the above copyright
> + # notice, this list of conditions and the following disclaimer.
> + # 2. Redistributions in binary form must reproduce the above copyright
> + # notice, this list of conditions and the following disclaimer in the
> + # documentation and/or other materials provided with the distribution.
> + # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + # POSSIBILITY OF SUCH DAMAGE.
> +If the python source file is a command line command add the following as the
Python source file
> +first line of the file:
> #!/usr/bin/env python
> +A command line python module does not need to have the ``.py`` file extension.
Python module
> +Only specify ``python`` as the command to ``env``. A system that does not
> +provide the ``python`` command can install a virtual python environment or the
Python environment
> +user can prepend the specific Python versioned command to the python script on
> +the command line when invoking the command.
> +Shell Scripts
> +Use the following template for shell script source files and other files which
> +accept a ``#``-style comment block. For the <FIRST YEAR>, <LAST YEAR>, and
> +<COPYRIGHT HOLDER> placeholders see :ref:`FileHeaderCopyright`.
> + # /bin/sh
#!/bin/sh
> # File documentation block
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
