[PATCH] Add Strong APA 2nd test
Richi Dubey
richidubey at gmail.com
Wed Sep 2 15:03:20 UTC 2020
Hi Dr. Bloom,
Is the original test that this patch replaces not good?
I'm afraid so. It only tests if the affinity is respected, but there is no
task-shifting in the test.
Simulating a WCET is challenging, but you can get an overestimate by
> spinning over a running timer until the timeout you want is reached.
> There will be error in both the setup and completion, since you won't
> know how long it took to read the timer initially and you won't know
> how long it took before the timeout was reached and your task yields.
Thank you. This sounds good and I'll implement this in a week.
I would prefer to add new test cases to smpstrongapa01 and keep the
> previous tests if they pass. I am not sure if two CPUs are enough to
> fully test this scheduler. Chips with three CPUs are quite unusual, so
> why not keep the CPU count at 4?
Okay. I'm working to make a basic test with 4 CPUs. It'll be done in a day.
On Wed, Sep 2, 2020 at 10:31 AM Sebastian Huber <
> On 01/09/2020 20:55, Gedare Bloom wrote:
> > Is the original test that this patch replaces not good? Or should you
> > provide an additional smpstrongapa02 instead?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200902/d46484d1/attachment.html>
