[PATCH v2 00/16] c-user: Split up chapter files
Sebastian Huber
Wed Sep 2 16:00:54 UTC 2020
This patch set is a preparation to automatically generate parts of the
documentation (introduction.rst and directives.rst) in the future from
specification items.
v2:
Use longer directory names.
Sebastian Huber (16):
c-user: Split up semaphore manager
c-user: Split up event manager
c-user: Split up barrier manager
c-user: Split up clock manager
c-user: Split up dual-ported memory manager
c-user: Split up interrupt manager
c-user: Split up IO manager
c-user: Split up message manager
c-user: Split up partition manager
c-user: Split up rate-monotonic manager
c-user: Split up region manager
c-user: Split up signal manager
c-user: Split up task manager
c-user: Split up timer manager
c-user: Split up user extensions manager
c-user: Split up scheduling concepts
c-user/barrier/background.rst | 68 +
.../directives.rst} | 169 +--
c-user/barrier/index.rst | 14 +
c-user/barrier/introduction.rst | 20 +
c-user/barrier/operations.rst | 60 +
c-user/clock/background.rst | 96 ++
.../directives.rst} | 238 +---
c-user/clock/index.rst | 15 +
c-user/clock/introduction.rst | 36 +
c-user/clock/operations.rst | 78 ++
c-user/dual-ported-memory/background.rst | 23 +
.../directives.rst} | 84 --
c-user/dual-ported-memory/index.rst | 16 +
c-user/dual-ported-memory/introduction.rst | 20 +
c-user/dual-ported-memory/operations.rst | 44 +
c-user/event/background.rst | 96 ++
c-user/event/directives.rst | 142 +++
c-user/event/index.rst | 15 +
c-user/event/introduction.rst | 13 +
c-user/event/operations.rst | 63 +
c-user/event_manager.rst | 309 -----
c-user/index.rst | 32 +-
c-user/interrupt/background.rst | 106 ++
.../directives.rst} | 251 ----
c-user/interrupt/index.rst | 15 +
c-user/interrupt/introduction.rst | 37 +
c-user/interrupt/operations.rst | 112 ++
c-user/io/background.rst | 162 +++
c-user/{io_manager.rst => io/directives.rst} | 215 ----
c-user/io/index.rst | 16 +
c-user/io/introduction.rst | 30 +
c-user/io/operations.rst | 26 +
c-user/message/background.rst | 91 ++
.../directives.rst} | 205 ----
c-user/message/index.rst | 16 +
c-user/message/introduction.rst | 28 +
c-user/message/operations.rst | 89 ++
c-user/partition/background.rst | 50 +
.../directives.rst} | 120 --
c-user/partition/index.rst | 15 +
c-user/partition/introduction.rst | 19 +
c-user/partition/operations.rst | 55 +
c-user/rate-monotonic/background.rst | 390 ++++++
c-user/rate-monotonic/directives.rst | 474 +++++++
c-user/rate-monotonic/index.rst | 16 +
c-user/rate-monotonic/introduction.rst | 33 +
c-user/rate-monotonic/operations.rst | 200 +++
c-user/rate_monotonic_manager.rst | 1091 -----------------
c-user/region/background.rst | 87 ++
.../directives.rst} | 213 ----
c-user/region/index.rst | 15 +
c-user/region/introduction.rst | 29 +
c-user/region/operations.rst | 101 ++
c-user/scheduling-concepts/background.rst | 327 +++++
c-user/scheduling-concepts/directives.rst | 424 +++++++
c-user/scheduling-concepts/index.rst | 19 +
c-user/scheduling-concepts/introduction.rst | 42 +
c-user/scheduling-concepts/smp-schedulers.rst | 69 ++
.../uniprocessor-schedulers.rst | 113 ++
c-user/scheduling_concepts.rst | 968 ---------------
c-user/semaphore/background.rst | 180 +++
.../directives.rst} | 309 -----
c-user/semaphore/index.rst | 18 +
c-user/semaphore/introduction.rst | 25 +
c-user/semaphore/operations.rst | 105 ++
c-user/signal/background.rst | 112 ++
c-user/signal/directives.rst | 126 ++
c-user/signal/index.rst | 15 +
c-user/signal/introduction.rst | 13 +
c-user/signal/operations.rst | 75 ++
c-user/signal_manager.rst | 322 -----
c-user/task/background.rst | 390 ++++++
.../{task_manager.rst => task/directives.rst} | 625 ----------
c-user/task/index.rst | 15 +
c-user/task/introduction.rst | 50 +
c-user/task/operations.rst | 192 +++
c-user/timer/background.rst | 71 ++
.../directives.rst} | 180 ---
c-user/timer/index.rst | 15 +
c-user/timer/introduction.rst | 29 +
c-user/timer/operations.rst | 84 ++
.../background.rst} | 161 ---
c-user/user-extensions/directives.rst | 143 +++
c-user/user-extensions/index.rst | 16 +
c-user/user-extensions/introduction.rst | 17 +
85 files changed, 5759 insertions(+), 5449 deletions(-)
create mode 100644 c-user/barrier/background.rst
rename c-user/{barrier_manager.rst => barrier/directives.rst} (55%)
create mode 100644 c-user/barrier/index.rst
create mode 100644 c-user/barrier/introduction.rst
create mode 100644 c-user/barrier/operations.rst
create mode 100644 c-user/clock/background.rst
rename c-user/{clock_manager.rst => clock/directives.rst} (65%)
create mode 100644 c-user/clock/index.rst
create mode 100644 c-user/clock/introduction.rst
create mode 100644 c-user/clock/operations.rst
create mode 100644 c-user/dual-ported-memory/background.rst
rename c-user/{dual_ports_memory_manager.rst => dual-ported-memory/directives.rst} (64%)
create mode 100644 c-user/dual-ported-memory/index.rst
create mode 100644 c-user/dual-ported-memory/introduction.rst
create mode 100644 c-user/dual-ported-memory/operations.rst
create mode 100644 c-user/event/background.rst
create mode 100644 c-user/event/directives.rst
create mode 100644 c-user/event/index.rst
create mode 100644 c-user/event/introduction.rst
create mode 100644 c-user/event/operations.rst
delete mode 100644 c-user/event_manager.rst
create mode 100644 c-user/interrupt/background.rst
rename c-user/{interrupt_manager.rst => interrupt/directives.rst} (61%)
create mode 100644 c-user/interrupt/index.rst
create mode 100644 c-user/interrupt/introduction.rst
create mode 100644 c-user/interrupt/operations.rst
create mode 100644 c-user/io/background.rst
rename c-user/{io_manager.rst => io/directives.rst} (61%)
create mode 100644 c-user/io/index.rst
create mode 100644 c-user/io/introduction.rst
create mode 100644 c-user/io/operations.rst
create mode 100644 c-user/message/background.rst
rename c-user/{message_manager.rst => message/directives.rst} (69%)
create mode 100644 c-user/message/index.rst
create mode 100644 c-user/message/introduction.rst
create mode 100644 c-user/message/operations.rst
create mode 100644 c-user/partition/background.rst
rename c-user/{partition_manager.rst => partition/directives.rst} (70%)
create mode 100644 c-user/partition/index.rst
create mode 100644 c-user/partition/introduction.rst
create mode 100644 c-user/partition/operations.rst
create mode 100644 c-user/rate-monotonic/background.rst
create mode 100644 c-user/rate-monotonic/directives.rst
create mode 100644 c-user/rate-monotonic/index.rst
create mode 100644 c-user/rate-monotonic/introduction.rst
create mode 100644 c-user/rate-monotonic/operations.rst
delete mode 100644 c-user/rate_monotonic_manager.rst
create mode 100644 c-user/region/background.rst
rename c-user/{region_manager.rst => region/directives.rst} (66%)
create mode 100644 c-user/region/index.rst
create mode 100644 c-user/region/introduction.rst
create mode 100644 c-user/region/operations.rst
create mode 100644 c-user/scheduling-concepts/background.rst
create mode 100644 c-user/scheduling-concepts/directives.rst
create mode 100644 c-user/scheduling-concepts/index.rst
create mode 100644 c-user/scheduling-concepts/introduction.rst
create mode 100644 c-user/scheduling-concepts/smp-schedulers.rst
create mode 100644 c-user/scheduling-concepts/uniprocessor-schedulers.rst
delete mode 100644 c-user/scheduling_concepts.rst
create mode 100644 c-user/semaphore/background.rst
rename c-user/{semaphore_manager.rst => semaphore/directives.rst} (64%)
create mode 100644 c-user/semaphore/index.rst
create mode 100644 c-user/semaphore/introduction.rst
create mode 100644 c-user/semaphore/operations.rst
create mode 100644 c-user/signal/background.rst
create mode 100644 c-user/signal/directives.rst
create mode 100644 c-user/signal/index.rst
create mode 100644 c-user/signal/introduction.rst
create mode 100644 c-user/signal/operations.rst
delete mode 100644 c-user/signal_manager.rst
create mode 100644 c-user/task/background.rst
rename c-user/{task_manager.rst => task/directives.rst} (63%)
create mode 100644 c-user/task/index.rst
create mode 100644 c-user/task/introduction.rst
create mode 100644 c-user/task/operations.rst
create mode 100644 c-user/timer/background.rst
rename c-user/{timer_manager.rst => timer/directives.rst} (64%)
create mode 100644 c-user/timer/index.rst
create mode 100644 c-user/timer/introduction.rst
create mode 100644 c-user/timer/operations.rst
rename c-user/{user_extensions.rst => user-extensions/background.rst} (77%)
create mode 100644 c-user/user-extensions/directives.rst
create mode 100644 c-user/user-extensions/index.rst
create mode 100644 c-user/user-extensions/introduction.rst
2.26.2
