[PATCH v2 05/16] c-user: Split up dual-ported memory manager
Wed Sep 2 16:00:59 UTC 2020
This makes it easier to automatically generate parts of the manager
documentation in the future.
Update #3993.
 c-user/dual-ported-memory/background.rst      | 23 +++++
 .../directives.rst}                           | 84 -------------------
 c-user/dual-ported-memory/index.rst           | 16 ++++
 c-user/dual-ported-memory/introduction.rst    | 20 +++++
 c-user/dual-ported-memory/operations.rst      | 44 ++++++++++
 c-user/index.rst                              |  2 +-
 6 files changed, 104 insertions(+), 85 deletions(-)
 create mode 100644 c-user/dual-ported-memory/background.rst
 rename c-user/{dual_ports_memory_manager.rst => dual-ported-memory/directives.rst} (64%)
 create mode 100644 c-user/dual-ported-memory/index.rst
 create mode 100644 c-user/dual-ported-memory/introduction.rst
 create mode 100644 c-user/dual-ported-memory/operations.rst
diff --git a/c-user/dual-ported-memory/background.rst b/c-user/dual-ported-memory/background.rst
new file mode 100644
index 0000000..3b6301e
--- /dev/null
+++ b/c-user/dual-ported-memory/background.rst
@@ -0,0 +1,23 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. index:: dual ported memory, definition
+.. index:: external addresses, definition
+.. index:: internal addresses, definition
+Background
+A dual-ported memory area (DPMA) is an contiguous block of RAM owned by a
+particular processor but which can be accessed by other processors in the
+system.  The owner accesses the memory using internal addresses, while other
+processors must use external addresses.  RTEMS defines a port as a particular
+mapping of internal and external addresses.
+There are two system configurations in which dual-ported memory is commonly
+found.  The first is tightly-coupled multiprocessor computer systems where the
+dual-ported memory is shared between all nodes and is used for inter-node
+communication.  The second configuration is computer systems with intelligent
+peripheral controllers.  These controllers typically utilize the DPMA for
+high-performance data transfers.
diff --git a/c-user/dual_ports_memory_manager.rst b/c-user/dual-ported-memory/directives.rst
similarity index 64%
rename from c-user/dual_ports_memory_manager.rst
rename to c-user/dual-ported-memory/directives.rst
index a8b7183..fb21a4f 100644
--- a/c-user/dual_ports_memory_manager.rst
+++ b/c-user/dual-ported-memory/directives.rst
@@ -2,90 +2,6 @@
-.. index:: ports
-.. index:: dual ported memory
-Dual-Ported Memory Manager
-Introduction
-The dual-ported memory manager provides a mechanism for converting addresses
-between internal and external representations for multiple dual-ported memory
-areas (DPMA).  The directives provided by the dual-ported memory manager are:
-- rtems_port_create_ - Create a port
-- rtems_port_ident_ - Get ID of a port
-- rtems_port_delete_ - Delete a port
-- rtems_port_external_to_internal_ - Convert external to internal address
-- rtems_port_internal_to_external_ - Convert internal to external address
-.. index:: dual ported memory, definition
-.. index:: external addresses, definition
-.. index:: internal addresses, definition
-Background
-A dual-ported memory area (DPMA) is an contiguous block of RAM owned by a
-particular processor but which can be accessed by other processors in the
-system.  The owner accesses the memory using internal addresses, while other
-processors must use external addresses.  RTEMS defines a port as a particular
-mapping of internal and external addresses.
-There are two system configurations in which dual-ported memory is commonly
-found.  The first is tightly-coupled multiprocessor computer systems where the
-dual-ported memory is shared between all nodes and is used for inter-node
-communication.  The second configuration is computer systems with intelligent
-peripheral controllers.  These controllers typically utilize the DPMA for
-high-performance data transfers.
-Operations
-Creating a Port
-The ``rtems_port_create`` directive creates a port into a DPMA with the
-user-defined name.  The user specifies the association between internal and
-external representations for the port being created.  RTEMS allocates a
-Dual-Ported Memory Control Block (DPCB) from the DPCB free list to maintain the
-newly created DPMA.  RTEMS also generates a unique dual-ported memory port ID
-which is returned to the calling task.  RTEMS does not initialize the
-dual-ported memory area or access any memory within it.
-Obtaining Port IDs
-When a port is created, RTEMS generates a unique port ID and assigns it to the
-created port until it is deleted.  The port ID may be obtained by either of two
-methods.  First, as the result of an invocation of the``rtems_port_create``
-directive, the task ID is stored in a user provided location.  Second, the port
-ID may be obtained later using the ``rtems_port_ident`` directive.  The port ID
-is used by other dual-ported memory manager directives to access this port.
-Converting an Address
-The ``rtems_port_external_to_internal`` directive is used to convert an address
-from external to internal representation for the specified port.  The
-``rtems_port_internal_to_external`` directive is used to convert an address
-from internal to external representation for the specified port.  If an attempt
-is made to convert an address which lies outside the specified DPMA, then the
-address to be converted will be returned.
-Deleting a DPMA Port
-A port can be removed from the system and returned to RTEMS with the
-``rtems_port_delete`` directive.  When a port is deleted, its control block is
-returned to the DPCB free list.
 Directives
diff --git a/c-user/dual-ported-memory/index.rst b/c-user/dual-ported-memory/index.rst
index 0000000..07628ce
--- /dev/null
+++ b/c-user/dual-ported-memory/index.rst
@@ -0,0 +1,16 @@
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: ports
+Dual-Ported Memory Manager
+.. toctree::
+    introduction
+    background
+    operations
+    directives
diff --git a/c-user/dual-ported-memory/introduction.rst b/c-user/dual-ported-memory/introduction.rst
index 0000000..752a162
--- /dev/null
+++ b/c-user/dual-ported-memory/introduction.rst
@@ -0,0 +1,20 @@
+Introduction
+The dual-ported memory manager provides a mechanism for converting addresses
+between internal and external representations for multiple dual-ported memory
+areas (DPMA).  The directives provided by the dual-ported memory manager are:
+- :ref:`rtems_port_create`
+- :ref:`rtems_port_ident`
+- :ref:`rtems_port_delete`
+- :ref:`rtems_port_external_to_internal`
+- :ref:`rtems_port_internal_to_external`
diff --git a/c-user/dual-ported-memory/operations.rst b/c-user/dual-ported-memory/operations.rst
index 0000000..15efb36
--- /dev/null
+++ b/c-user/dual-ported-memory/operations.rst
@@ -0,0 +1,44 @@
+Operations
+Creating a Port
+The ``rtems_port_create`` directive creates a port into a DPMA with the
+user-defined name.  The user specifies the association between internal and
+external representations for the port being created.  RTEMS allocates a
+Dual-Ported Memory Control Block (DPCB) from the DPCB free list to maintain the
+newly created DPMA.  RTEMS also generates a unique dual-ported memory port ID
+which is returned to the calling task.  RTEMS does not initialize the
+dual-ported memory area or access any memory within it.
+Obtaining Port IDs
+When a port is created, RTEMS generates a unique port ID and assigns it to the
+created port until it is deleted.  The port ID may be obtained by either of two
+methods.  First, as the result of an invocation of the``rtems_port_create``
+directive, the task ID is stored in a user provided location.  Second, the port
+ID may be obtained later using the ``rtems_port_ident`` directive.  The port ID
+is used by other dual-ported memory manager directives to access this port.
+Converting an Address
+The ``rtems_port_external_to_internal`` directive is used to convert an address
+from external to internal representation for the specified port.  The
+``rtems_port_internal_to_external`` directive is used to convert an address
+from internal to external representation for the specified port.  If an attempt
+is made to convert an address which lies outside the specified DPMA, then the
+address to be converted will be returned.
+Deleting a DPMA Port
+A port can be removed from the system and returned to RTEMS with the
+``rtems_port_delete`` directive.  When a port is deleted, its control block is
+returned to the DPCB free list.
diff --git a/c-user/index.rst b/c-user/index.rst
index f4922da..51998bf 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -42,7 +42,7 @@ RTEMS Classic API Guide (|version|).
 	signal_manager
 	partition_manager
 	region_manager
-	dual_ports_memory_manager
+	dual-ported-memory/index
 	io_manager
 	fatal_error
 	board_support_packages
2.26.2
