[PATCH v2 07/16] c-user: Split up IO manager
Wed Sep 2 16:01:01 UTC 2020
This makes it easier to automatically generate parts of the manager
documentation in the future.
Update #3993.
 c-user/index.rst                             |   2 +-
 c-user/io/background.rst                     | 162 ++++++++++++++
 c-user/{io_manager.rst => io/directives.rst} | 215 -------------------
 c-user/io/index.rst                          |  16 ++
 c-user/io/introduction.rst                   |  30 +++
 c-user/io/operations.rst                     |  26 +++
 6 files changed, 235 insertions(+), 216 deletions(-)
 create mode 100644 c-user/io/background.rst
 rename c-user/{io_manager.rst => io/directives.rst} (61%)
 create mode 100644 c-user/io/index.rst
 create mode 100644 c-user/io/introduction.rst
 create mode 100644 c-user/io/operations.rst
diff --git a/c-user/index.rst b/c-user/index.rst
index d955cc8..cf73c77 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -43,7 +43,7 @@ RTEMS Classic API Guide (|version|).
 	partition_manager
 	region_manager
 	dual-ported-memory/index
-	io_manager
+	io/index
 	fatal_error
 	board_support_packages
 	user_extensions
diff --git a/c-user/io/background.rst b/c-user/io/background.rst
new file mode 100644
index 0000000..28e5369
--- /dev/null
+++ b/c-user/io/background.rst
@@ -0,0 +1,162 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Background
+.. index:: Device Driver Table
+Device Driver Table
+Each application utilizing the RTEMS I/O manager must specify the address of a
+Device Driver Table in its Configuration Table. This table contains each device
+driver's entry points that is to be initialised by RTEMS during initialization.
+Each device driver may contain the following entry points:
+- Initialization
+- Open
+- Close
+- Read
+- Write
+- Control
+If the device driver does not support a particular entry point, then that entry
+in the Configuration Table should be NULL.  RTEMS will return
+``RTEMS_SUCCESSFUL`` as the executive's and zero (0) as the device driver's
+return code for these device driver entry points.
+Applications can register and unregister drivers with the RTEMS I/O manager
+avoiding the need to have all drivers statically defined and linked into this
+table.
+The :file:`confdefs.h` entry ``CONFIGURE_MAXIMUM_DRIVERS`` configures the
+number of driver slots available to the application.
+.. index:: major device number
+.. index:: minor device number
+Major and Minor Device Numbers
+Each call to the I/O manager must provide a device's major and minor numbers as
+arguments.  The major number is the index of the requested driver's entry
+points in the Device Driver Table, and is used to select a specific device
+driver.  The exact usage of the minor number is driver specific, but is
+commonly used to distinguish between a number of devices controlled by the same
+driver.
+.. index:: rtems_device_major_number
+.. index:: rtems_device_minor_number
+The data types ``rtems_device_major_number`` and ``rtems_device_minor_number``
+are used to manipulate device major and minor numbers, respectively.
+.. index:: device names
+Device Names
+The I/O Manager provides facilities to associate a name with a particular
+device.  Directives are provided to register the name of a device and to look
+up the major/minor number pair associated with a device name.
+Device Driver Environment
+Application developers, as well as device driver developers, must be aware of
+the following regarding the RTEMS I/O Manager:
+- A device driver routine executes in the context of the invoking task.  Thus
+  if the driver blocks, the invoking task blocks.
+- The device driver is free to change the modes of the invoking task, although
+  the driver should restore them to their original values.
+- Device drivers may be invoked from ISRs.
+- Only local device drivers are accessible through the I/O manager.
+- A device driver routine may invoke all other RTEMS directives, including I/O
+  directives, on both local and global objects.
+Although the RTEMS I/O manager provides a framework for device drivers, it
+makes no assumptions regarding the construction or operation of a device
+driver.
+.. index:: runtime driver registration
+Runtime Driver Registration
+Board support package and application developers can select wether a device
+driver is statically entered into the default device table or registered at
+runtime.
+Dynamic registration helps applications where:
+- The BSP and kernel libraries are common to a range of applications for a
+  specific target platform. An application may be built upon a common library
+  with all drivers. The application selects and registers the drivers. Uniform
+  driver name lookup protects the application.
+- The type and range of drivers may vary as the application probes a bus during
+  initialization.
+- Support for hot swap bus system such as Compact PCI.
+- Support for runtime loadable driver modules.
+.. index:: device driver interface
+Device Driver Interface
+When an application invokes an I/O manager directive, RTEMS determines which
+device driver entry point must be invoked.  The information passed by the
+application to RTEMS is then passed to the correct device driver entry point.
+RTEMS will invoke each device driver entry point assuming it is compatible with
+the following prototype:
+.. code-block:: c
+    rtems_device_driver io_entry(
+        rtems_device_major_number  major,
+        rtems_device_minor_number  minor,
+        void                      *argument_block
+The format and contents of the parameter block are device driver and entry
+point dependent.
+It is recommended that a device driver avoid generating error codes which
+conflict with those used by application components.  A common technique used to
+generate driver specific error codes is to make the most significant part of
+the status indicate a driver specific code.
+Device Driver Initialization
+RTEMS automatically initializes all device drivers when multitasking is
+initiated via the ``rtems_initialize_executive`` directive.  RTEMS initializes
+the device drivers by invoking each device driver initialization entry point
+with the following parameters:
+``major``
+    the major device number for this device driver.
+``minor``
+    zero.
+``argument_block``
+    will point to  the Configuration Table.
+The returned status will be ignored by RTEMS.  If the driver cannot
+successfully initialize the device, then it should invoke the
+fatal_error_occurred directive.
diff --git a/c-user/io_manager.rst b/c-user/io/directives.rst
similarity index 61%
rename from c-user/io_manager.rst
rename to c-user/io/directives.rst
index 12282d7..d3098cb 100644
--- a/c-user/io_manager.rst
+++ b/c-user/io/directives.rst
@@ -2,221 +2,6 @@
-.. index:: device drivers
-.. index:: IO Manager
-I/O Manager
-Introduction
-The input/output interface manager provides a well-defined mechanism for
-accessing device drivers and a structured methodology for organizing device
-drivers.  The directives provided by the I/O manager are:
-- rtems_io_initialize_ - Initialize a device driver
-- rtems_io_register_driver_ - Register a device driver
-- rtems_io_unregister_driver_ - Unregister a device driver
-- rtems_io_register_name_ - Register a device name
-- rtems_io_lookup_name_ - Look up a device name
-- rtems_io_open_ - Open a device
-- rtems_io_close_ - Close a device
-- rtems_io_read_ - Read from a device
-- rtems_io_write_ - Write to a device
-- rtems_io_control_ - Special device services
-Background
-.. index:: Device Driver Table
-Device Driver Table
-Each application utilizing the RTEMS I/O manager must specify the address of a
-Device Driver Table in its Configuration Table. This table contains each device
-driver's entry points that is to be initialised by RTEMS during initialization.
-Each device driver may contain the following entry points:
-- Initialization
-- Open
-- Close
-- Read
-- Write
-- Control
-If the device driver does not support a particular entry point, then that entry
-in the Configuration Table should be NULL.  RTEMS will return
-``RTEMS_SUCCESSFUL`` as the executive's and zero (0) as the device driver's
-return code for these device driver entry points.
-Applications can register and unregister drivers with the RTEMS I/O manager
-avoiding the need to have all drivers statically defined and linked into this
-table.
-The :file:`confdefs.h` entry ``CONFIGURE_MAXIMUM_DRIVERS`` configures the
-number of driver slots available to the application.
-.. index:: major device number
-.. index:: minor device number
-Major and Minor Device Numbers
-Each call to the I/O manager must provide a device's major and minor numbers as
-arguments.  The major number is the index of the requested driver's entry
-points in the Device Driver Table, and is used to select a specific device
-driver.  The exact usage of the minor number is driver specific, but is
-commonly used to distinguish between a number of devices controlled by the same
-driver.
-.. index:: rtems_device_major_number
-.. index:: rtems_device_minor_number
-The data types ``rtems_device_major_number`` and ``rtems_device_minor_number``
-are used to manipulate device major and minor numbers, respectively.
-.. index:: device names
-Device Names
-The I/O Manager provides facilities to associate a name with a particular
-device.  Directives are provided to register the name of a device and to look
-up the major/minor number pair associated with a device name.
-Device Driver Environment
-Application developers, as well as device driver developers, must be aware of
-the following regarding the RTEMS I/O Manager:
-- A device driver routine executes in the context of the invoking task.  Thus
-  if the driver blocks, the invoking task blocks.
-- The device driver is free to change the modes of the invoking task, although
-  the driver should restore them to their original values.
-- Device drivers may be invoked from ISRs.
-- Only local device drivers are accessible through the I/O manager.
-- A device driver routine may invoke all other RTEMS directives, including I/O
-  directives, on both local and global objects.
-Although the RTEMS I/O manager provides a framework for device drivers, it
-makes no assumptions regarding the construction or operation of a device
-driver.
-.. index:: runtime driver registration
-Runtime Driver Registration
-Board support package and application developers can select wether a device
-driver is statically entered into the default device table or registered at
-runtime.
-Dynamic registration helps applications where:
-- The BSP and kernel libraries are common to a range of applications for a
-  specific target platform. An application may be built upon a common library
-  with all drivers. The application selects and registers the drivers. Uniform
-  driver name lookup protects the application.
-- The type and range of drivers may vary as the application probes a bus during
-  initialization.
-- Support for hot swap bus system such as Compact PCI.
-- Support for runtime loadable driver modules.
-.. index:: device driver interface
-Device Driver Interface
-When an application invokes an I/O manager directive, RTEMS determines which
-device driver entry point must be invoked.  The information passed by the
-application to RTEMS is then passed to the correct device driver entry point.
-RTEMS will invoke each device driver entry point assuming it is compatible with
-the following prototype:
-.. code-block:: c
-    rtems_device_driver io_entry(
-        rtems_device_major_number  major,
-        rtems_device_minor_number  minor,
-        void                      *argument_block
-The format and contents of the parameter block are device driver and entry
-point dependent.
-It is recommended that a device driver avoid generating error codes which
-conflict with those used by application components.  A common technique used to
-generate driver specific error codes is to make the most significant part of
-the status indicate a driver specific code.
-Device Driver Initialization
-RTEMS automatically initializes all device drivers when multitasking is
-initiated via the ``rtems_initialize_executive`` directive.  RTEMS initializes
-the device drivers by invoking each device driver initialization entry point
-with the following parameters:
-``major``
-    the major device number for this device driver.
-``minor``
-    zero.
-``argument_block``
-    will point to  the Configuration Table.
-The returned status will be ignored by RTEMS.  If the driver cannot
-successfully initialize the device, then it should invoke the
-fatal_error_occurred directive.
-Operations
-Register and Lookup Name
-The ``rtems_io_register`` directive associates a name with the specified device
-(i.e. major/minor number pair).  Device names are typically registered as part
-of the device driver initialization sequence.  The ``rtems_io_lookup``
-directive is used to determine the major/minor number pair associated with the
-specified device name.  The use of these directives frees the application from
-being dependent on the arbitrary assignment of major numbers in a particular
-application.  No device naming conventions are dictated by RTEMS.
-Accessing an Device Driver
-The I/O manager provides directives which enable the application program to
-utilize device drivers in a standard manner.  There is a direct correlation
-between the RTEMS I/O manager directives ``rtems_io_initialize``,
-``rtems_io_open``, ``rtems_io_close``, ``rtems_io_read``, ``rtems_io_write``,
-and ``rtems_io_control`` and the underlying device driver entry points.
 Directives
diff --git a/c-user/io/index.rst b/c-user/io/index.rst
index 0000000..0b6ff6f
--- /dev/null
+++ b/c-user/io/index.rst
@@ -0,0 +1,16 @@
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: device drivers
+.. index:: IO Manager
+I/O Manager
+.. toctree::
+    introduction
+    background
+    operations
+    directives
diff --git a/c-user/io/introduction.rst b/c-user/io/introduction.rst
index 0000000..e097c7f
--- /dev/null
+++ b/c-user/io/introduction.rst
@@ -0,0 +1,30 @@
+Introduction
+The input/output interface manager provides a well-defined mechanism for
+accessing device drivers and a structured methodology for organizing device
+drivers.  The directives provided by the I/O manager are:
+- :ref:`rtems_io_initialize`
+- :ref:`rtems_io_register_driver`
+- :ref:`rtems_io_unregister_driver`
+- :ref:`rtems_io_register_name`
+- :ref:`rtems_io_lookup_name`
+- :ref:`rtems_io_open`
+- :ref:`rtems_io_close`
+- :ref:`rtems_io_read`
+- :ref:`rtems_io_write`
+- :ref:`rtems_io_control`
diff --git a/c-user/io/operations.rst b/c-user/io/operations.rst
index 0000000..ec0212d
--- /dev/null
+++ b/c-user/io/operations.rst
@@ -0,0 +1,26 @@
+Operations
+Register and Lookup Name
+The ``rtems_io_register`` directive associates a name with the specified device
+(i.e. major/minor number pair).  Device names are typically registered as part
+of the device driver initialization sequence.  The ``rtems_io_lookup``
+directive is used to determine the major/minor number pair associated with the
+specified device name.  The use of these directives frees the application from
+being dependent on the arbitrary assignment of major numbers in a particular
+application.  No device naming conventions are dictated by RTEMS.
+Accessing an Device Driver
+The I/O manager provides directives which enable the application program to
+utilize device drivers in a standard manner.  There is a direct correlation
+between the RTEMS I/O manager directives ``rtems_io_initialize``,
+``rtems_io_open``, ``rtems_io_close``, ``rtems_io_read``, ``rtems_io_write``,
+and ``rtems_io_control`` and the underlying device driver entry points.
2.26.2
