[PATCH] display/disp_hcms29xx fix string turncation warning
Aschref Ben-Thabet
aschref.ben-thabet at embedded-brains.de
Thu Sep 3 14:46:17 UTC 2020
From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
strncpy is unsafe if the terminating NULL is missing, as it may copy
more characters than fit in the destination area
Replace it by the safer strlcpy() and fix the string
turncation warnings.
bsps/shared/dev/display/disp_hcms29xx.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/bsps/shared/dev/display/disp_hcms29xx.c b/bsps/shared/dev/display/disp_hcms29xx.c
index 5730b36ea9..fb88f66343 100644
--- a/bsps/shared/dev/display/disp_hcms29xx.c
+++ b/bsps/shared/dev/display/disp_hcms29xx.c
@@ -589,10 +589,9 @@ static rtems_task disp_hcms29xx_update_task
RTEMS_WAIT,RTEMS_NO_TIMEOUT);
if (rc == RTEMS_SUCCESSFUL) {
- strncpy(softc_ptr->disp_param.disp_buffer,
+ strlcpy(softc_ptr->disp_param.disp_buffer,
softc_ptr->disp_param.trns_buffer,
sizeof(softc_ptr->disp_param.disp_buffer));
- softc_ptr->disp_param.disp_buffer[sizeof(softc_ptr->disp_param.disp_buffer)-1] = '\0';
softc_ptr->disp_param.disp_buf_cnt =
(int) strlen(softc_ptr->disp_param.disp_buffer);
2.26.2
