[PATCH] arm: Fix arm_cp15_set_translation_table_entries()
Fri Sep 4 14:19:29 UTC 2020
On Fri, Sep 4, 2020 at 7:47 AM Sebastian Huber
> From: "sebastian.huber" <sebastian.huber at ad346e48-6743-2946-b04c-964484d2d4e6>
git-config problem
> In a multi-processor system we must broadcast the TLB maintenance operation to
> the Inner Shareable domain to ensure that the other processors update their TLB
> caches accordingly.
> Close #4068.
>  bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c |  2 +-
>  cpukit/score/cpu/arm/include/libcpu/arm-cp15.h  | 16 ++++++++++++++++
>  2 files changed, 17 insertions(+), 1 deletion(-)
> diff --git a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> index 507277dca1..976f87a36e 100644
> --- a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> +++ b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> @@ -107,7 +107,7 @@ static uint32_t set_translation_table_entries(
>      #define MPIDR_UP     (1 << 30)
>      const uint32_t mpidr = arm_cp15_get_multiprocessor_affinity();
>      if ((mpidr & (MPIDR_MX_FMT | MPIDR_UP)) == MPIDR_MX_FMT) {
> -      arm_cp15_tlb_invalidate_entry_all_asids(mva);
> +      arm_cp15_tlb_invalidate_entry_all_asids_inner_shareable(mva);
>      else
>  #endif
> diff --git a/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h b/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
> index 8d43ca0ac2..6097d60ba6 100644
> --- a/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
> +++ b/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
> @@ -646,6 +646,22 @@ arm_cp15_tlb_invalidate_entry_all_asids(const void *mva)
> +ARM_CP15_TEXT_SECTION static inline void
> +arm_cp15_tlb_invalidate_entry_all_asids_inner_shareable(const void *mva)
> +  ARM_SWITCH_REGISTERS;
> +  mva = ARM_CP15_TLB_PREPARE_MVA(mva);
> +  __asm__ volatile (
> +    ARM_SWITCH_TO_ARM
> +    "mcr p15, 0, %[mva], c8, c3, 3\n"
> +    ARM_SWITCH_BACK
> +    : ARM_SWITCH_OUTPUT
> +    : [mva] "r" (mva)
>  arm_cp15_tlb_instruction_invalidate(void)
> 2.26.2
> devel mailing list
> devel at rtems.org
