More RISC-V Failures on Master
Joel Sherrill
joel at rtems.org
Sun Sep 6 21:17:29 UTC 2020
On Sun, Sep 6, 2020 at 3:03 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Sep 6, 2020 at 1:27 PM Hesham Almatary <
> hesham.almatary at cl.cam.ac.uk> wrote:
>> I sent a patch to fix that earlier but it didn’t make it upstream. Please
>> feel free to push it
>> https://lists.rtems.org/pipermail/devel/2020-May/059773.html
> Is this only needed on the master?
I have pushed this to the master. I would expect all RISC-V BSPs to fail
now on the dl issue.
Why isn't this also a problem on the release branch?
--joel
>> On Sun, Sep 6, 2020 at 7:57 PM Joel Sherrill <joel at rtems.org> wrote:
>>> Hi
>>> I see a duplicate symbol error on RISC-V BSPs which must not trip the
>>> dynamic loading section 0 issue. This is the error on multiple RISC-V BSPs
>>> with the list below the message:
>>> /home/joel/rtems-cron-6/tools/6/lib/gcc/riscv-rtems6/10.2.1/../../../../riscv-rtems6/bin/ld:
>>> ./../../lib/libbsp/riscv/riscv/librtemsbsp.a(htif.o):/home/joel/rtems-cron-6/rtems/bsps/riscv/riscv/include/dev/serial/htif.h:48:
>>> multiple definition of `htif_console_handler';
>>> ./../../lib/libbsp/riscv/riscv/librtemsbsp.a(console-config.o):/home/joel/rtems-cron-6/rtems/bsps/riscv/riscv/include/dev/serial/htif.h:48:
>>> first defined here
>>> first defined here
>>> mv -f cdtest/.deps/cdtest-init.Tpo cdtest/.deps/cdtest-init.Po
>>> rv32iac_spike
>>> rv32imac_spike
>>> rv32imafc_spike
>>> rv32imafdc_spike
>>> rv32imafd_spike
>>> rv32im_spike
>>> rv32i_spike
>>> rv64imac_medany_spike
>>> rv64imac_spike
>>> rv64imafdc_medany_spike
>>> rv64imafdc_spike
>>> rv64imafd_medany_spike
>>> rv64imafd_spike
>>> Filed as https://devel.rtems.org/ticket/4070#ticket.
>>> --joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200906/a20b363e/attachment.html>
