Tftp patch to rtems-tools breaks compilation (on ubuntu 18.04 x64)
Chris Johns
chrisj at rtems.org
Mon Sep 7 00:34:01 UTC 2020
On 7/9/20 10:14 am, Chris Johns wrote:
> On 7/9/20 5:01 am, Jiri Gaisler wrote:
>> source not found: 'rt/tftpy/__init__.py' in bld(target='', idx=3, tg_idx_count=42, meths=['feature_py', 'process_rule', 'process_source'], install_path='${PREFIX}/share/rtems/tester', _name='', source=['rt/tftpy/__init__.py', 'rt/tftpy/TftpClient.py', 'rt/tftpy/TftpContexts.py', 'rt/tftpy/TftpPacketFactory.py', 'rt/tftpy/TftpPacketTypes.py', 'rt/tftpy/TftpServer.py', 'rt/tftpy/TftpShared.py', 'rt/tftpy/TftpStates.py'], path=/home/jiri/ibm/src/rtems/rtems-tools/tester, install_from=/home/jiri/ibm/src/rtems/rtems-tools/tester, posted=True, features=['py']) in /home/jiri/ibm/src/rtems/rtems-tools/tester
> Doh, sorry. I removed the old TFTP server and did not update the install parts
> in the waf script.
> I will update the tools and fix this.
Fixed on master in rtems-tool and the RSB has been updated.
Please test and let know if this is any better.
Thanks
