Introducing the Strong APA Scheduler
Richi Dubey
richidubey at gmail.com
Mon Sep 7 13:54:47 UTC 2020
How do I run a mass test?
On Mon, Sep 7, 2020 at 7:04 PM Richi Dubey <richidubey at gmail.com> wrote:
> Thanks for the advice. I'll work on this.
> On Mon, Sep 7, 2020 at 11:28 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 03/09/2020 17:10, Richi Dubey wrote:
>> > Any views on this?
>> Sorry for the delay. Did you run the test suite with this scheduler as
>> the default and check how many tests pass?
>> diff --git a/cpukit/include/rtems/confdefs/scheduler.h
>> b/cpukit/include/rtems/confdefs/scheduler.h
>> index 9305fc2d90..63f4be4247 100644
>> --- a/cpukit/include/rtems/confdefs/scheduler.h
>> +++ b/cpukit/include/rtems/confdefs/scheduler.h
>> @@ -55,9 +55,9 @@
>> && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
>> && !defined(CONFIGURE_SCHEDULER_USER)
>> #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
>> - #define CONFIGURE_SCHEDULER_EDF_SMP
>> + #define CONFIGURE_SCHEDULER_STRONG_APA
>> #else
>> - #define CONFIGURE_SCHEDULER_PRIORITY
>> #endif
>> #endif
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200907/8f2c5b4c/attachment.html>
