Introducing the Strong APA Scheduler
Richi Dubey
richidubey at gmail.com
Mon Sep 7 14:09:56 UTC 2020
> Did you
> use rtems-test before?
No. I'll do it now.
I am individually testing each smp test for now on this patch:
cpukit/include/rtems/confdefs/scheduler.h | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/confdefs/scheduler.h
b/cpukit/include/rtems/confdefs/scheduler.h
index 9305fc2d90..a93e765e53 100644
--- a/cpukit/include/rtems/confdefs/scheduler.h
+++ b/cpukit/include/rtems/confdefs/scheduler.h
@@ -55,7 +55,7 @@
&& !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
&& !defined(CONFIGURE_SCHEDULER_USER)
#if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
- #define CONFIGURE_SCHEDULER_EDF_SMP
+ #define CONFIGURE_SCHEDULER_STRONG_APA
#else
#define CONFIGURE_SCHEDULER_PRIORITY
#endif
because your suggested patch gives this error:
In file included from
/home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:64:0,
from
/home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/threads.h:48,
from
/home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/objectsposix.h:47,
from
/home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs.h:77,
from
/home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/system.h:39,
from
/home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/init.c:15:
/home/richi/quick-start/src/rtems/cpukit/include/rtems/scheduler.h:260:37:
error: 'CONFIGURE_MAXIMUM_PROCESSORS' undeclared here (not in a function);
did you mean '_CONFIGURE_MAXIMUM_PROCESSORS'?
Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
/home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:149:7:
note: in expansion of macro 'RTEMS_SCHEDULER_STRONG_APA'
RTEMS_SCHEDULER_STRONG_APA( \
/home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:236:3:
note: in expansion of macro 'CONFIGURE_SCHEDULER'
CONFIGURE_SCHEDULER;
Makefile:939: recipe for target 'base_sp/base_sp-init.o' failedp-init.o'
failed
This is because single processor scheduler doesn't
have CONFIGURE_MAXIMUM_PROCESSORS defined, So, would you like for me to
make separate definition of CONFIGURE_SCHEDULER_STRONG_APA in
cpukit/include/rtems/scheduler.h for a single processor system or does the
current version that'd work only for SMP processor serve the purpose?
On Mon, Sep 7, 2020 at 7:26 PM Sebastian Huber <
> On 07/09/2020 15:54, Richi Dubey wrote:
> > How do I run a mass test?
> To make sure all tests use this configuration, please rebuild the BSP
> with all tests enabled. Then use rtems-test to run the tests. Did you
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200907/b550d6f3/attachment.html>
