Introducing the Strong APA Scheduler
Richi Dubey
richidubey at gmail.com
Mon Sep 7 14:54:31 UTC 2020
Invalid directory. Sorry for the doubt.
On Mon, Sep 7, 2020 at 8:18 PM Richi Dubey <richidubey at gmail.com> wrote:
> You should run all tests that doesn't explicitly configure a scheduler
>> with your new implementation.
> I understand.
>> Maybey add an
>> #ifndef CONFIGURE_MAXIMUM_PROCESSORS
>> #define CONFIGURE_MAXIMUM_PROCESSORS 1
>> #endif
>> before the default scheduler selection.
> This works.
> I am getting this error:
> ./rtems-test \ --log=log_leon3_sis \ --rtems-bsp=leon3-sis \
> ~/quick-start/build/b-smp-leon3/sparc-rtems5/c/leon3/testsuites
> error: RTEMS Toolkit python wrapper not found, please report
> As far as I remember, I had done --enable-tests while building my bsp.
> On Mon, Sep 7, 2020 at 7:45 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 07/09/2020 16:09, Richi Dubey wrote:
>> > Did you
>> > use rtems-test before?
>> > No. I'll do it now.
>> > I am individually testing each smp test for now on this patch:
>> > cpukit/include/rtems/confdefs/scheduler.h | 2 +-
>> > 1 file changed, 1 insertion(+), 1 deletion(-)
>> > diff --git a/cpukit/include/rtems/confdefs/scheduler.h
>> > b/cpukit/include/rtems/confdefs/scheduler.h
>> > index 9305fc2d90..a93e765e53 100644
>> > --- a/cpukit/include/rtems/confdefs/scheduler.h
>> > +++ b/cpukit/include/rtems/confdefs/scheduler.h
>> > @@ -55,7 +55,7 @@
>> > && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
>> > && !defined(CONFIGURE_SCHEDULER_USER)
>> > #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
>> > - #define CONFIGURE_SCHEDULER_EDF_SMP
>> > + #define CONFIGURE_SCHEDULER_STRONG_APA
>> > #else
>> > #define CONFIGURE_SCHEDULER_PRIORITY
>> > #endif
>> > because your suggested patch gives this error:
>> > In file included from
>> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:64:0,
>> > from
>> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/threads.h:48,
>> > from
>> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/objectsposix.h:47,
>> > from
>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs.h:77,
>> > from
>> /home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/system.h:39,
>> > from
>> /home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/init.c:15:
>> /home/richi/quick-start/src/rtems/cpukit/include/rtems/scheduler.h:260:37:
>> > error: 'CONFIGURE_MAXIMUM_PROCESSORS' undeclared here (not in a
>> > function); did you mean '_CONFIGURE_MAXIMUM_PROCESSORS'?
>> > Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
>> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:149:7:
>> > note: in expansion of macro 'RTEMS_SCHEDULER_STRONG_APA'
>> > RTEMS_SCHEDULER_STRONG_APA( \
>> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:236:3:
>> > note: in expansion of macro 'CONFIGURE_SCHEDULER'
>> > CONFIGURE_SCHEDULER;
>> > Makefile:939: recipe for target 'base_sp/base_sp-init.o'
>> > failedp-init.o' failed
>> > This is because single processor scheduler doesn't
>> > have CONFIGURE_MAXIMUM_PROCESSORS defined, So, would you like for me
>> > to make separate definition of CONFIGURE_SCHEDULER_STRONG_APA in
>> > cpukit/include/rtems/scheduler.h for a single processor system or does
>> > the current version that'd work only for SMP processor serve the
>> purpose?
>> Maybey add an
>> #endif
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200907/db54a05c/attachment.html>
