Error while running rtems-test
Richi Dubey richidubey at gmail.com
Mon Sep 7 15:37:52 UTC 2020
Hi,
My current directory is: ~/quick-start/build/b-smp-leon3$
and I'm running the command:
~/quick-start/rtems/test/rtems-tools/tester/rtems-test \
--log=log_leon3_sis \ --rtems-bsp=leon3-sis \
~/quick-start/build/b-smp-leon3/sparc-rtems5/c/leon3/testsuites
which gives the following error:
RTEMS Testing - Tester, 6 (b1c6a98da4a2)
error: no executables supplied
I'd appreciate your help in solving this issue.
My source tree looks like this from ~/quick-start/:
./rtems/.git
./rtems/.git/refs
./rtems/.git/hooks
./rtems/.git/branches
./rtems/.git/info
./rtems/.git/objects
./rtems/test
./rtems/test/rtems-tools
./rtems/5
./rtems/5/bin
./rtems/5/libexec
./rtems/5/arm-rtems5
./rtems/5/sparc-rtems5
./rtems/5/share
./rtems/5/make
./rtems/5/include
./rtems/5/var
./rtems/5/lib
./rtems/4.10
./rtems/4.10/bin
./rtems/4.10/share
./rtems/4.12
./rtems/4.12/bin
./rtems/4.12/share
./src/rsb
./src/rsb/bare
./src/rsb/.git
./src/rsb/rtems
./src/rsb/source-builder
./src/rtems
./src/rtems/.git
./src/rtems/cpukit
./src/rtems/make
./src/rtems/wow
./src/rtems/autom4te.cache
./src/rtems/c
./src/rtems/testsuites
./src/rtems/aclocal
./src/rtems/bsps
./src/rtems/automake
./build/b-smp-leon3-tests
./build/b-smp-leon3
./build/b-smp-leon3/sparc-rtems5
./build/b2-erc32
./build/b2-erc32/sparc-rtems5
./build/b3-realview
./build/b3-realview/arm-rtems5
./rtems-docs/.git
./rtems-docs/.git/logs
./rtems-docs/.git/refs
./rtems-docs/.git/hooks
./rtems-docs/.git/branches
./rtems-docs/.git/info
./rtems-docs/.git/objects
./rtems-docs/porting
./rtems-docs/common
./rtems-docs/common/_templates
./rtems-docs/common/sphinx_rtd_theme_rtems
./rtems-docs/common/latex
./rtems-docs/common/spell
./rtems-docs/common/_static
./rtems-docs/common/coverpage
./rtems-docs/images
./rtems-docs/images/eng
./rtems-docs/images/eclipse
./rtems-docs/images/user
./rtems-docs/images/cpu_supplement
./rtems-docs/images/c_user
./rtems-docs/images/networking
./rtems-docs/bsp-howto
./rtems-docs/cpu-supplement
./rtems-docs/c-user
./rtems-docs/c-user/Save
./rtems-docs/c-user/config
./rtems-docs/c-user/APA
./rtems-docs/eng
./rtems-docs/eng/req
./rtems-docs/eclipse
./rtems-docs/user
./rtems-docs/user/glossary
./rtems-docs/user/rsb
./rtems-docs/user/support
./rtems-docs/user/testing
./rtems-docs/user/hosts
./rtems-docs/user/migration
./rtems-docs/user/tracing
./rtems-docs/user/exe
./rtems-docs/user/tools
./rtems-docs/user/bsps
./rtems-docs/user/overview
./rtems-docs/user/start
./rtems-docs/user/hardware
./rtems-docs/user/installation
./rtems-docs/user/apps
./rtems-docs/posix-compliance
./rtems-docs/develenv
./rtems-docs/filesystem
./rtems-docs/rtemsconfig
./rtems-docs/maintainer-scripts
./rtems-docs/networking
./rtems-docs/book
./rtems-docs/shell
./rtems-docs/posix-users
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200907/99138ec0/attachment-0001.html>
