[PATCH] user: Add xilinx-zynq BSP details
chrisj at rtems.org
chrisj at rtems.org
Tue Sep 8 03:30:07 UTC 2020
user/bsps/arm/xilinx-zynq.rst | 114 +++++++++++++++++++++++++++++++++-
1 file changed, 112 insertions(+), 2 deletions(-)
diff --git a/user/bsps/arm/xilinx-zynq.rst b/user/bsps/arm/xilinx-zynq.rst
index 909b23e..365c336 100644
--- a/user/bsps/arm/xilinx-zynq.rst
+++ b/user/bsps/arm/xilinx-zynq.rst
@@ -1,8 +1,118 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2019 TBD
+.. Copyright (C) 2020 Chris Johns (chrisj at rtems.org)
xilinx-zynq
-TODO.
+This BSP supports the Xilinx Zynq range of devices. This family of
+devices contain the same ARM hard IP and the different parts have
+different sizes of programable logic.
+The BSP defaults may need to be adjusted using ``configure`` BSP
+options to match the size of memory your board may have.
+Bootloader
+The bootloader initialises the Zynq device. The Xilinx tool provide an
+interface to configure the hardware. This is includes the buses,
+clocks, memory and UART board rate. The output of this is called
+``ps7_init`` and it a C file. The Xilinx SDK builds a first stage boot
+loader (FSBL) using this file.
+The U-Boot boot loader has it's own FSBL called ``MLO`` to initialise
+the hardware.
+Clocks
+An application can provide a function called:
+.. code-block:: none
+ uint32_t a9mpcore_clock_periphclk(void);
+to return the peripheral clock. Normally this is half the CPU
+clock. This function is declared ``weak`` so you can override the
+default behaviour by providing it in your application.
+Debugging with xilinx_zynq_a9_qemu
+To debug an application add the QEMU options ``-s``. If you need to
+debug an initialisation issue also add ``-S``. For example to debug a
+networking application you could use:
+ qemu-system-arm -M xilinx-zynq-a9 -m 256M -no-reboot -serial \
+ null -serial mon:stdio -nographic \
+ -net nic,model=cadence_gem -net vde,id=vde0,sock=/tmp/vde1 \
+ -kernel myapp.exe \
+ -s -S
+Start GDB with the same executable QEMU is running and connect to the
+QEMU GDB server:
+ (gdb) target remote :1234
+If your application is crashing set a breakpoint on the fatal error
+handler:
+ (gdb) b bsp_fatal_extension
+Enter continue to run the application. Running QEMU loads the
+executable and initialises the CPU. If the ``-S`` option is provided
+the CPU is held in reset. Without the option the CPU runs starting
+RTEMS. Either way you are connecting to set up target and all you need
+to do is continue:
+ (gdb) c
+If you have a crash and the breakpoint on ``bsp_fatal_extension`` is
+hit, load the following a GDB script:
+ define arm-crash
+ set $code = $arg0
+ set $r0 = ((const rtems_exception_frame *) $code)->register_r0
+ set $r1 = ((const rtems_exception_frame *) $code)->register_r1
+ set $r2 = ((const rtems_exception_frame *) $code)->register_r2
+ set $r3 = ((const rtems_exception_frame *) $code)->register_r3
+ set $r4 = ((const rtems_exception_frame *) $code)->register_r4
+ set $r5 = ((const rtems_exception_frame *) $code)->register_r5
+ set $r6 = ((const rtems_exception_frame *) $code)->register_r6
+ set $r7 = ((const rtems_exception_frame *) $code)->register_r7
+ set $r8 = ((const rtems_exception_frame *) $code)->register_r8
+ set $r9 = ((const rtems_exception_frame *) $code)->register_r9
+ set $r10 = ((const rtems_exception_frame *) $code)->register_r10
+ set $r11 = ((const rtems_exception_frame *) $code)->register_r11
+ set $r12 = ((const rtems_exception_frame *) $code)->register_r12
+ set $sp = ((const rtems_exception_frame *) $code)->register_sp
+ set $lr = ((const rtems_exception_frame *) $code)->register_lr
+ set $pc = ((const rtems_exception_frame *) $code)->register_pc
+ set $cpsr = ((const rtems_exception_frame *) $code)->register_cpsr
+ end
+Enter the command:
+ (gdb) arm-crash code
+Enter ``bt`` to see the stack back trace.
+The script moves the context back to the crash location. You should be
+able to view variables and inspect the stack.
+The fatal error handler runs inside an exception context that is not
+the one than generated the exception.
2.24.1
