[PATCH v1 0/6] [libbsd] Fix e1000 driver for i386 in master and 5
Jan.Sommer at dlr.de
Wed Sep 9 06:55:29 UTC 2020
Hi Chris,
> -----Original Message-----
> From: Chris Johns <chrisj at rtems.org>
> Sent: Friday, August 14, 2020 11:43 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> Subject: Re: [PATCH v1 0/6] [libbsd] Fix e1000 driver for i386 in master and 5
> On 15/8/20 5:57 am, Jan Sommer wrote:
> > Hello,
> > I finally got around to port the e1000 driver fixes which are already
> > present in the 5-freebsd-12 branch of rtems-libbsd also for the master
> > (and 5) branch.
> Thanks. I will push these soon.
As mentioned over at the users list, could you please push these changes?
They should enable compilation for i386 again and we could establish Ethernet connections with Intel network devices.
The patches should apply to libbsd master and 5 branch, as they are both based on FreeBSD master.
> I am not sure if the 5 branch in the rtems-libbsd.git repo is right and if it
> should be made from the 5-freebsd-12 branch? I feel it is currently confusing
> but either way it has issues.
Maybe, we can continue to discuss that outside of this patch set? Renaming a branch later should be no trouble.
An option could be to rename 5 -> 5-freebsd-master, then the mapping between rtems and FreeBSD would always be explicit.
Cheers,
Jan
> Chris
