[PATCH v2] rtems: Add rtems_task_create_from_config()
Sebastian Huber
Wed Sep 9 08:32:26 UTC 2020
On 09/09/2020 00:25, Joel Sherrill wrote:
> This has gotten to be a long-ish side discussion. I havecomments on
> the patch and will reply to the original email for that.
> On Thu, Sep 3, 2020 at 10:17 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 3/9/20 10:08 pm, Sebastian Huber wrote:
> > On 03/09/2020 04:08, Chris Johns wrote:
> >> On 3/9/20 2:09 am, Sebastian Huber wrote:
> >>> In contrast to rtems_task_create() this function creates a task
> with a
> >>> user-provided task storage area. The new create function uses a
> >>> configuration structure instead of individual parameters.
> >>> Add RTEMS_TASK_STORAGE_ALIGNMENT to define the recommended
> alignment of
> >>> a task storage area.
> >>> Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size
> of a
> >>> task storage area based on the task attributes and the size
> dedicated to
> >>> the task stack and thread-local storage. This macro may allow
> future
> >>> extensions without breaking the API.
> >> Have all the issues in the other thread been resolved? It would
> be good to have
> >> Joel ack this patch before it is merged.
> > I tried to address the issues raised by Joel.
> He will need to answer.
> I will also comment on the patch. But the first thing I noticed was how
> does the user
> know the amount of memory required for keys? That was in a Doxygen comment
> about the macro which is a big improvement but still makes the user guess
> something we should compute.
> This reminds me of not giving an option to account for message buffers. Then
> we added a confdefs macro to specify the total amount of memory. It took
> another
> release before we realized that we didn't give the user a way to
> calculate the
> memory required per queue based on number of messages and size of the
> buffer. This made them guess to account for the overhead for each of those.
> Let's try to avoid making users guess the size of memory that we would
> normally
> compute.
The problem is that the TLS size is known at link-time (or even run-time
if you take dynamic linking into account). You can't calculate this at
compile-time.
> >> In considering the support for static allocation in general I am
> wondering if
> >> the RTEMS Classic API Guide is poorly named? This is a new API
> with new features
> >> and it is not "classic". The Key Concepts section of the that
> manual says...
> >> "RTEMS provides directives which can be used to dynamically
> >> create, delete, and manipulate a set of predefined object types."
> >> This change makes this statement questionable.
> > The task is still dynamically created, however, with a
> user-provided task
> > storage area. It is similar to the POSIX threads which also have
> to option to
> > use a user-provided task storage area. When you don't use
> unlimited objects,
> > then the memory for task control blocks is only statically
> allocated. The tasks
> > are dynamically maintained.
> Thanks. This makes sense and almost what could be used in the
> documentation :)
> We just need to make sure we name the various situations clearly without
> names
> like new/old, improved, etc.
> I see a handful of RTOS memory organizations a systems designer has to pick
> and we have to name and explain them.
> (1) Workspace vs C Program Heap
> - usually associated with hard limits on objects. Unlimited is of
> marginal
> use with the split memory model.
> (2) Unified Workspace/Heap
> - usually associated with unlimited objects
> On top of that, you have
> (a) stack and FP allocated from Workspace
> (b) BSP/application provided stack allocator
> (c) Application provided memory per task
> That makes six combinations. I would tend to say that if you choose to
> use Unified Workspace, then 2a makes sense. 2b also makes sense if
> you had some stack protection scheme. But why would someone mix in
> 2c. Should work but not likely to be a common setup unless we do it
> in support code.
> For (1), I can see situations where you would use 1a, 1b, and 1c.
> Overall, I see a-c as useful with 1+2 and a-c should work with 1 or 2
> but we have to explain the choices.
> I think this means we need to name a-c so we use consistent
> terms across the community.
Yes, this makes sense. Finding good names for a-c will not be easy (at
least for me).
> > The self-contained synchronization objects of this chapter
> https://docs.rtems.org/branches/master/c-user/self_contained_objects.html
> > are a different kind of thing.
> Yes and this makes the word Classic look wrong.
> Classic is probably technically only the core APIs that derived from
> RTEID/ORKID
> or soon thereafter. Perhaps only the managers that existed before any
> POSIX was
> added which would be strictly less than v4.x of RTEMS.
> But now, Classic is just RTEMS specific APIs that start with rtems_ even
> though that
> leads to duplicate functionality between Classic proper and the self
> contained objects.
> I think this is just a matter of naming chapters correctly and ensuring
> that the
> first 2 sentences of each self-contained object type's description makes
> it clear
> the distinction.
Yes for me this manual is for everything which is part of the API and
starts with rtems_*.
> >> I am sure there are other places
> >> that will need to be updated. What documentation and examples
> are planned to
> >> explain the different allocation models RTEMS now supports? I
> think we have 3
> >> APIs and the "Classic" API now has 2 allocation models. I fine
> with the
> >> expansion of the ways RTEMS can be used but we need to make sure
> we explain
> >> these differing ways, why they exist, and the advantages and
> disadvantages. I
> >> would prefer we not leave this as an exercise for the users to
> do by reading
> >> header files.
> > Yes, we need some guidance for the users. I will definitely work on
> > documentation updates. I would like to work first on the
> specification of the
> > Classic API directives:
> > https://devel.rtems.org/ticket/3993
> > This involves a unification/consolidation of the Doxgyen and
> Sphinx documentation.
> OK.
> FWIW I also think the rationale for picking a scheduling algorithm is a
> challenge
> and similar in that we have multiple options for a very high level systems
> design decision. Questions like OS memory allocation scheme, scheduler
> selection, and API selection need to be addressed somewhere. The first two
> fit into the Classic API Guide (which used to be the Users Guide so could be
> renamed again). But selecting an API is a bit different in that you are
> already
> down a design level when in this manual.
> > Afterwards I would like to concentrate more on higher level
> aspects which cover
> > more than one directive.
> Excellent and thanks. The question is about the plan not the timeline.
> +1
> I'm not opposed in principle. I am just leary of adding anything that does
> not present a clear definition to the user and has a well-defined purpose.
> You added some concepts that need to be accounted for as design
> variations and the APIs need to be solid.
Ok, good. I just need some way that enables me to work to step by step.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
