Error while running rtems-test
Richi Dubey richidubey at gmail.com
Wed Sep 9 15:00:48 UTC 2020
Sorry for the late reply. My university tests are going to come up really
soon and I have to make up for stuff I missed early on :p
Did you build with --enable-tests?
I do not remember. I am going to make the bsp from the beginning again.
Are there *.exe files in ~/quick-start/build/b-smp-leon3?
Nope.
I do not think rtems-test expands a ~ to $HOME so changing to the directory
> should work.
It did not work. Thank you for the suggestion, maybe I haven't enabled
tests while building.
On Tue, Sep 8, 2020 at 8:14 AM Chris Johns <chrisj at rtems.org> wrote:
> On 8/9/20 1:48 am, Sebastian Huber wrote:
> > On 07/09/2020 17:37, Richi Dubey wrote:
> >> My current directory is: ~/quick-start/build/b-smp-leon3$
> >> and I'm running the command:
> >> ~/quick-start/rtems/test/rtems-tools/tester/rtems-test \
> --log=log_leon3_sis \
> >> --rtems-bsp=leon3-sis \
> >> ~/quick-start/build/b-smp-leon3/sparc-rtems5/c/leon3/testsuites
> >> which gives the following error:
> >> RTEMS Testing - Tester, 6 (b1c6a98da4a2)
> >> error: no executables supplied
> > If yes, then try to run it with:
> > cd ~/quick-start/build/b-smp-leon3
> should work.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200909/3671620e/attachment.html>
