[PATCH rtems-libbsd 1/2] sdhci: Add some workarrounds for i.MX
Gedare Bloom
gedare at rtems.org
Wed Sep 9 15:58:31 UTC 2020
Can this be pushed upstream in a non-RTEMS specific way?
On Wed, Sep 9, 2020 at 5:16 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Some bits are in the wrong order. Beneath that, the interrupts can occur
> in an unexpected order. The DATA_AVAIL interrupt can occur at the same
> time as the DMA interrupt (or slightly before it). With that, the DMA
> and PIO interrupt handling doesn't work well together. Beneath that the
> DMA interrupt isn't only executed at block ends but also if all data is
> transfered. That can lead to problems with the DATA_END interrupt.
> Therefore check whether there is really data left to unload.
> Update #3869
> freebsd/sys/dev/sdhci/fsl_sdhci.c | 41 +++++++++++++++++++++++++++++++
> freebsd/sys/dev/sdhci/sdhci.c | 40 ++++++++++++++++++++++++++++++
> 2 files changed, 81 insertions(+)
> diff --git a/freebsd/sys/dev/sdhci/fsl_sdhci.c b/freebsd/sys/dev/sdhci/fsl_sdhci.c
> index be3d1de3..acef1c4a 100644
> --- a/freebsd/sys/dev/sdhci/fsl_sdhci.c
> +++ b/freebsd/sys/dev/sdhci/fsl_sdhci.c
> @@ -74,6 +74,9 @@ uint32_t mpc85xx_get_system_clock(void);
> #endif /* __rtems__ */
> #endif
> +#ifndef __rtems__
> +#include <bsp.h>
> +#endif /* __rtems__ */
> #include <dev/gpio/gpiobusvar.h>
> #include <dev/ofw/ofw_bus.h>
> @@ -168,6 +171,16 @@ struct fsl_sdhci_softc {
> #define SDHC_PROT_CDSS (1 << 7)
> #define SDHC_SYS_CTRL 0x2c
> +#ifdef __rtems__
> + * Freescale messed up the INT DMA ERR bit and placed it at bit 28 instead of
> + * bit 25 which would be standard.
> +#define SDHC_INT_DMAES (1 << 28)
> +#define SDHC_CAN_DO_ADMA2 0x00100000
> * The clock enable bits exist in different registers for ESDHC vs USDHC, but
> @@ -349,6 +362,16 @@ fsl_sdhci_read_4(device_t dev, struct sdhci_slot *slot, bus_size_t off)
> val32 &= ~SDHCI_CAN_VDD_180;
> val32 &= ~SDHCI_CAN_DO_SUSPEND;
> val32 |= SDHCI_CAN_DO_8BITBUS;
> +#ifdef __rtems__
> + * Freescale signals ADMA2 capability via bit 20 (which would be
> + * ADMA1) instead of 19.
> + if (val32 & SDHC_CAN_DO_ADMA2) {
> + val32 &= ~SDHC_CAN_DO_ADMA2;
> + val32 |= SDHCI_CAN_DO_ADMA2;
> return (val32);
> @@ -373,6 +396,13 @@ fsl_sdhci_read_4(device_t dev, struct sdhci_slot *slot, bus_size_t off)
> * command with an R1B response, mix it into the hardware status.
> if (off == SDHCI_INT_STATUS) {
> +#ifdef __rtems__
> + /* Fix messed up DMA error. */
> + if (val32 & SDHC_INT_DMAES) {
> + val32 &= ~SDHC_INT_DMAES;
> + val32 |= SDHCI_INT_ADMAERR;
> return (val32 | sc->r1bfix_intmask);
> @@ -519,6 +549,15 @@ fsl_sdhci_write_4(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint32_
> sc->r1bfix_intmask &= ~val;
> +#ifdef __rtems__
> + if (off == SDHCI_INT_STATUS || off == SDHCI_INT_ENABLE || off == SDHCI_SIGNAL_ENABLE) {
> + if (val & SDHCI_INT_ADMAERR) {
> + val &= ~SDHCI_INT_ADMAERR;
> + val |= SDHC_INT_DMAES;
> WR4(sc, off, val);
> @@ -884,10 +923,12 @@ fsl_sdhci_attach(device_t dev)
> sc->slot.quirks |= SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK;
> +#if !defined(__rtems__) || !defined(LIBBSP_ARM_IMX_BSP_H)
> * DMA is not really broken, I just haven't implemented it yet.
> sc->slot.quirks |= SDHCI_QUIRK_BROKEN_DMA;
> * Set the buffer watermark level to 128 words (512 bytes) for both read
> diff --git a/freebsd/sys/dev/sdhci/sdhci.c b/freebsd/sys/dev/sdhci/sdhci.c
> index ed6010e8..53d86fe8 100644
> --- a/freebsd/sys/dev/sdhci/sdhci.c
> +++ b/freebsd/sys/dev/sdhci/sdhci.c
> @@ -68,6 +68,9 @@ __FBSDID("$FreeBSD$");
> #include <rtems/bsd/local/sdhci_if.h>
> #include <rtems/bsd/local/opt_mmccam.h>
> +#ifdef __rtems__
> +#include <bsp.h>
> SYSCTL_NODE(_hw, OID_AUTO, sdhci, CTLFLAG_RD, 0, "sdhci driver");
> @@ -766,6 +769,17 @@ sdhci_dma_alloc(struct sdhci_slot *slot)
> else
> slot->sdma_boundary = SDHCI_BLKSZ_SDMA_BNDRY_512K;
> +#ifdef __rtems__
> +#if defined(LIBBSP_ARM_IMX_BSP_H)
> + * i.MX6ULL doesn't have the SDMA Buffer Boundary bits. Instead the
> + * BLKSIZE is one bit larger and would overlap the Buffer Boundary.
> + * Setting the Buffer Boundary to 4K makes sure that the highest BLKSIZE
> + * bit is always 0.
> + slot->sdma_boundary = SDHCI_BLKSZ_SDMA_BNDRY_4K;
> +#endif
> slot->sdma_bbufsz = SDHCI_SDMA_BNDRY_TO_BBUFSZ(slot->sdma_boundary);
> @@ -1896,6 +1910,10 @@ sdhci_start_data(struct sdhci_slot *slot, const struct mmc_data *data)
> BUS_DMASYNC_PREWRITE);
> WR4(slot, SDHCI_DMA_ADDRESS, slot->paddr);
> +#ifdef __rtems__
> + /* Avoid PIO interrupt if we use DMA */
> + slot->intmask &= ~(SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL);
> * Interrupt aggregation: Mask border interrupt for the last
> * bounce buffer and unmask otherwise.
> @@ -1932,15 +1950,27 @@ sdhci_finish_data(struct sdhci_slot *slot)
> WR4(slot, SDHCI_SIGNAL_ENABLE,
> slot->intmask |= SDHCI_INT_RESPONSE);
> +#ifdef __rtems__
> + /* Restore PIO interrupts in case they are necessary elsewhere */
> + if (slot->flags & SDHCI_USE_DMA) {
> + slot->intmask |= SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL;
> /* Unload rest of data from DMA buffer. */
> if (!slot->data_done && (slot->flags & SDHCI_USE_DMA) &&
> slot->curcmd->data != NULL) {
> if (data->flags & MMC_DATA_READ) {
> left = data->len - slot->offset;
> +#ifdef __rtems__
> + if (left > 0) {
> bus_dmamap_sync(slot->dmatag, slot->dmamap,
> BUS_DMASYNC_POSTREAD);
> memcpy((u_char*)data->data + slot->offset, slot->dmamem,
> ulmin(left, slot->sdma_bbufsz));
> +#ifdef __rtems__
> } else
> BUS_DMASYNC_POSTWRITE);
> @@ -2201,8 +2231,15 @@ sdhci_data_irq(struct sdhci_slot *slot, uint32_t intmask)
> /* ... and reload it again. */
> +#ifdef __rtems__
> + slot->offset += ulmin(left, sdma_bbufsz);
> +#else /* __rtems__ */
> slot->offset += sdma_bbufsz;
> +#ifdef __rtems__
> + if (left > 0) {
> BUS_DMASYNC_PREREAD);
> @@ -2222,6 +2259,9 @@ sdhci_data_irq(struct sdhci_slot *slot, uint32_t intmask)
> /* Restart DMA. */
> +#ifdef __rtems__
> /* We have got all data. */
> if (intmask & SDHCI_INT_DATA_END) {
> 2.26.2
> devel mailing list
> devel at rtems.org
