[PATCH] CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Thu Sep 10 15:23:04 UTC 2020
Hello Joel,
this configuration option is a by product of the discussions related to
the proposed rtems_task_create_from_config() directive. I addresses an
issue with thread-local storage in dynamically linked objects. Since I
work currently in the same code area, it is easier if I try to implement
it instead of Chris.
​https://lists.rtems.org/pipermail/devel/2020-September/061867.html
On 10/09/2020 16:40, Joel Sherrill wrote:
> How is the user/system integrator supposed to figure out the size of
> the TLS? It is not known until the application is linked and thus
> varies based on the total set of code linked.
One way to figure out the TLS size is to link the executable and look at
the _TLS_Size symbol. We could also add an API function to get the size.
> As far as I can tell, this makes this type of task creation unsuitable
> for use in libraries where the end system is unknown.
Yes, the rtems_task_create_from_config() is unsuitable for general
purpose libraries.
> It is at least fragile in tightly controlled applications and subject
> to someone guessing a number larger than required which wastes memory
> and goes against the intent of the statically allocated thread resources.
I talked with Chris today and we suggest to add this member to the task
configuration:
+   * @brief This member defines the maximum thread-local storage size
supported
+   *   by the task storage area.
+   * If the value is less than the actual thread-local storage size,
then the
+   * task creation by rtems_task_create_from_config() fails.
+   * If the value is less than the task storage area size, then the
task creation by
+   * rtems_task_create_from_config() fails.
+  size_t maximum_thread_local_storage_size;
So, if the task configuration doesn't match with the actual TLS size,
then you get run-time errors during task creation.
I work currently on a v4 of the rtems_task_create_from_config() patch.
> If there is a practical and portable way to know this number, it needs
> to be explained quite well in the documentation and always used in any
> tests or examples.
The TLS size is only relevant if you use rtems_task_create_from_config()
or dynamically linked objects with thread-local storage. There is no
need to spread this stuff all over the place.
