New coding style for new files?
Joel Sherrill
joel at rtems.org
Thu Sep 10 15:32:16 UTC 2020
On Thu, Sep 10, 2020 at 10:24 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Sep 7, 2020 at 12:06 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > I think we waste too much time to address coding style issues on newly
> > contributed code, for example GSoC. I don't know a source code
> > formatting tool which supports the RTEMS coding style and I think it is
> > not worth the time to write and maintain such a tool specifically for
> > RTEMS. Why don't we simply allow an alternative coding style which has a
> > good code formatter for new source files? I don't propose to reformat
> > the existing files.
> > I would simply pick up one of the standard styles supported by
> > clang-format and declare it as an acceptable coding style for RTEMS.
I am not willing to blanket accept another project's coding style.
I am willing to accept a configuration for a tool that is close to our
style and
make compromises on specific points.
I also think when doing this we should consider things that we do that
we have since learned safety standards don't like such as single statement
if's without braces. I think we should have braces now.
This is best viewed as an opportunity to improve but comes with changes
since I don't think any of us wants to add a few more configuration options
to any formatter. Although if we get close, I can see adding those as open
projects if someone is interested.
> > Then students can pipe their code through it before they send it for
> > review. This helps to concentrate on the important things to review and
> > not the white space.
> This will work best in combination with a patch management/review
> system that can run the style checker and report which style it
> passes.
> For me, I definitely spend too much time pointing out style problems.
> Often I just do that before I will even think through the logic. But
> that is wasting a lot of time. I would be happy to see a path toward
> style-proved submissions.
> I know we discussed this topic a few times before. I think there was
> even a couple of close style matches found or suggested. I'm open to
> the discussion.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200910/d69864f9/attachment.html>
