Determining Linux Distribution
Thu Sep 10 16:31:19 UTC 2020
On Thu, Sep 10, 2020 at 11:09 AM Christian Mauderer <oss at c-mauderer.de>
wrote:
> On 10/09/2020 00:25, Chris Johns wrote:
> > On 10/9/20 8:15 am, Joel Sherrill wrote:
> >> On Wed, Sep 9, 2020 at 4:06 PM Karel Gardas <karel.gardas at centrum.cz
> >> <mailto:karel.gardas at centrum.cz>> wrote:
> >>     On 9/9/20 11:03 PM, Karel Gardas wrote:
> >>     > so Debian, Kali and OpenSuSE at least are not well handled by this
> >>     > script and it's quite fun since simple:
> >>     Can't judge author of the script. The post is from 2008! So I guess
> >>     /etc/os-release was not so wide spread among the Linuxes at that
> time...
> >> That looks promising and linux.py in rtems-toolkit should be easy to
> make do that.
> > The code in linux.py that calls platform.dist() should be removed
> because the
> > call has been removed from Python 3 after 3.5.
> > Chris
> You have seen that there exists a python pip package to find out the
> distribution:
> https://distro.readthedocs.io/en/latest/
I assume we don't want to assume someone will use pip to load a package
to use the RSB or rtems-tools.  Copying it into our tree gives us a package
that will periodically need to be updated.
Chris.. what do you want to do?
--joel
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200910/910507ae/attachment.html>
