[PATCH] Remove tmoverhd which existed to produce the obsolete coverhd.h
Thu Sep 10 18:29:30 UTC 2020
Closes #4040.
 bsps/m68k/mvme147/README                      |    5 +-
 bsps/m68k/mvme147s/README                     |    5 +-
 testsuites/ada/configure.ac                   |    1 -
 testsuites/ada/tmtests/Makefile.am            |    1 -
 testsuites/ada/tmtests/tmoverhd/Makefile.am   |   13 -
 testsuites/ada/tmtests/tmoverhd/README        |    5 -
 .../ada/tmtests/tmoverhd/dummy_rtems.adb      |  891 -----------
 .../ada/tmtests/tmoverhd/dummy_rtems.ads      |  445 ------
 testsuites/ada/tmtests/tmoverhd/init.c        |   34 -
 testsuites/ada/tmtests/tmoverhd/tmoverhd.adb  |   55 -
 testsuites/ada/tmtests/tmoverhd/tmtest.adb    | 1363 -----------------
 testsuites/ada/tmtests/tmoverhd/tmtest.ads    |  156 --
 testsuites/tmtests/Makefile.am                |   10 -
 testsuites/tmtests/configure.ac               |    1 -
 testsuites/tmtests/tmoverhd/dumrtems.h        |  250 ---
 testsuites/tmtests/tmoverhd/empty.c           |   45 -
 testsuites/tmtests/tmoverhd/system.h          |   54 -
 testsuites/tmtests/tmoverhd/testtask.c        | 1232 ---------------
 testsuites/tmtests/tmoverhd/tmoverhd.doc      |   82 -
 19 files changed, 2 insertions(+), 4646 deletions(-)
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/Makefile.am
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/README
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/dummy_rtems.adb
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/dummy_rtems.ads
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/init.c
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/tmoverhd.adb
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/tmtest.adb
 delete mode 100644 testsuites/ada/tmtests/tmoverhd/tmtest.ads
 delete mode 100644 testsuites/tmtests/tmoverhd/dumrtems.h
 delete mode 100644 testsuites/tmtests/tmoverhd/empty.c
 delete mode 100644 testsuites/tmtests/tmoverhd/system.h
 delete mode 100644 testsuites/tmtests/tmoverhd/testtask.c
 delete mode 100644 testsuites/tmtests/tmoverhd/tmoverhd.doc
diff --git a/bsps/m68k/mvme147/README b/bsps/m68k/mvme147/README
index 91f78e2be3..3bc7afd89d 100644
--- a/bsps/m68k/mvme147/README
+++ b/bsps/m68k/mvme147/README
@@ -66,10 +66,7 @@ Other notes:
    does not seem applicable on the VMEchip of the mvme147, so
    I don't know where to start. Suggestions are welcome.
- * All the timing tests and sp tests have been run except tmoverhd.
-   The test hangs during the pause (where the task should be suspended
-   until a return). Maybe the rtems_initialize_executive is no more
-   reentrant with this bsp.
+ * All the timing tests and sp tests have been run.
 Future work:
diff --git a/bsps/m68k/mvme147s/README b/bsps/m68k/mvme147s/README
index c191872f42..77022980f0 100644
--- a/bsps/m68k/mvme147s/README
+++ b/bsps/m68k/mvme147s/README
@@ -81,8 +81,5 @@ To be done:
 Other notes:
diff --git a/testsuites/ada/configure.ac b/testsuites/ada/configure.ac
index 4ec8532ada..2c9937131e 100644
--- a/testsuites/ada/configure.ac
+++ b/testsuites/ada/configure.ac
@@ -110,7 +110,6 @@ tmtests/tm25/Makefile
 tmtests/tm28/Makefile
 tmtests/tm29/Makefile
 tmtests/tmck/Makefile
-tmtests/tmoverhd/Makefile
 AC_CONFIG_FILES([
diff --git a/testsuites/ada/tmtests/Makefile.am b/testsuites/ada/tmtests/Makefile.am
index ed9de68373..b4d96c150b 100644
--- a/testsuites/ada/tmtests/Makefile.am
+++ b/testsuites/ada/tmtests/Makefile.am
@@ -27,6 +27,5 @@ _SUBDIRS += tm25
 _SUBDIRS += tm28
 _SUBDIRS += tm29
 _SUBDIRS += tmck
-_SUBDIRS += tmoverhd
 include $(top_srcdir)/../automake/subdirs.am
diff --git a/testsuites/ada/tmtests/tmoverhd/Makefile.am b/testsuites/ada/tmtests/tmoverhd/Makefile.am
deleted file mode 100644
index 75e9719426..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/ada.am
-noinst_PROGRAMS = ada_tmoverhd
-ada_tmoverhd_SOURCES = tmoverhd.adb config.h tmtest.adb tmtest.ads \
-    dummy_rtems.adb dummy_rtems.ads
-ada_tmoverhd_SOURCES += init.c
-ada_tmoverhd$(EXEEXT): tmoverhd.adb init.$(OBJEXT)
-	$(GNATCOMPILE) -margs -a $< -o $@
diff --git a/testsuites/ada/tmtests/tmoverhd/README b/testsuites/ada/tmtests/tmoverhd/README
index 4e66647830..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/README
+++ /dev/null
@@ -1,5 +0,0 @@
-This test is of marginal usefulness in testing the bindings.  It
-shows how much overhead is required to call the Ada binding
-routine but does not give any indication of how much overhead the
-binding itself adds.  This information can be inferred by subtracting
-the C times from Ada times on the same target processor.
diff --git a/testsuites/ada/tmtests/tmoverhd/dummy_rtems.adb b/testsuites/ada/tmtests/tmoverhd/dummy_rtems.adb
index 62986dc465..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/dummy_rtems.adb
+++ /dev/null
@@ -1,891 +0,0 @@
---  DUMMY_RTEMS / SPECIFICATION
---  DESCRIPTION:
---  This package contains implementation of stub routines
---  which are used to time the invocation overhead incurred
---  with an Ada application program invokes each RTEMS directive.
---  DEPENDENCIES:
---  COPYRIGHT (c) 1989-2009.
---  On-Line Applications Research Corporation (OAR).
---  The license and distribution terms for this file may in
---  the file LICENSE in this distribution or at
---  http://www.rtems.org/license/LICENSE.
-package body DUMMY_RTEMS is
--- Task Manager
-   procedure TASK_CREATE (
-      NAME             : in     RTEMS.NAME;
-      INITIAL_PRIORITY : in     RTEMS.TASKS.PRIORITY;
-      STACK_SIZE       : in     RTEMS.UNSIGNED32;
-      INITIAL_MODES    : in     RTEMS.MODE;
-      ATTRIBUTE_SET    : in     RTEMS.ATTRIBUTE;
-      ID               :    out RTEMS.ID;
-      RESULT           :    out RTEMS.STATUS_CODES
-   ) is
-      pragma Unreferenced(NAME);
-      pragma Unreferenced(INITIAL_PRIORITY);
-      pragma Unreferenced(STACK_SIZE);
-      pragma Unreferenced(INITIAL_MODES);
-      pragma Unreferenced(ATTRIBUTE_SET);
-   begin
-      ID := 0;
-      RESULT := RTEMS.SUCCESSFUL;
-   end TASK_CREATE;
-   procedure TASK_IDENT (
-      NODE   : in     RTEMS.UNSIGNED32;
-   ) is
-      pragma Unreferenced(NODE);
-   begin
-      ID := 0;
-   end TASK_IDENT;
-   procedure TASK_START (
-      ID          : in     RTEMS.ID;
-      ENTRY_POINT : in     RTEMS.TASKS.ENTRY_POINT;
-      ARGUMENT    : in     RTEMS.UNSIGNED32;
-   ) is
-      pragma Unreferenced(ID);
-      pragma Unreferenced(ENTRY_POINT);
-      pragma Unreferenced(ARGUMENT);
-   begin
-   end TASK_START;
-   procedure TASK_RESTART (
-      ID       : in     RTEMS.ID;
-   ) is
-   begin
-   end TASK_RESTART;
-   procedure TASK_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end TASK_DELETE;
-   procedure TASK_SUSPEND (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end TASK_SUSPEND;
-   procedure TASK_RESUME (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end TASK_RESUME;
-   procedure TASK_SET_PRIORITY (
-      ID           : in     RTEMS.ID;
-      NEW_PRIORITY : in     RTEMS.TASKS.PRIORITY;
-      OLD_PRIORITY :    out RTEMS.TASKS.PRIORITY;
-   ) is
-      pragma Unreferenced(NEW_PRIORITY);
-   begin
-      OLD_PRIORITY := 0;
-   end TASK_SET_PRIORITY;
-   procedure TASK_MODE (
-      MODE_SET          : in     RTEMS.MODE;
-      MASK              : in     RTEMS.MODE;
-      PREVIOUS_MODE_SET :    out RTEMS.MODE;
-   ) is
-      pragma Unreferenced(MODE_SET);
-      pragma Unreferenced(MASK);
-   begin
-      PREVIOUS_MODE_SET := 0;
-   end TASK_MODE;
-   procedure TASK_WAKE_WHEN (
-      TIME_BUFFER : in     RTEMS.TIME_OF_DAY;
-   ) is
-      pragma Unreferenced(TIME_BUFFER);
-   begin
-   end TASK_WAKE_WHEN;
-   procedure TASK_WAKE_AFTER (
-      TICKS  : in     RTEMS.INTERVAL;
-   ) is
-      pragma Unreferenced(TICKS);
-   begin
-   end TASK_WAKE_AFTER;
--- Interrupt Manager
---   procedure INTERRUPT_CATCH (
---      NEW_ISR_HANDLER : in     RTEMS.ADDRESS;
---      VECTOR          : in     RTEMS.VECTOR_NUMBER;
---      OLD_ISR_HANDLER :    out RTEMS.ADDRESS;
---      RESULT          :    out RTEMS.STATUS_CODES
---   ) is
---   begin
---      OLD_ISR_HANDLER := RTEMS.Null_Address;
---      RESULT := RTEMS.SUCCESSFUL;
---   end INTERRUPT_CATCH;
--- Clock Manager
-   procedure CLOCK_GET_TOD (
-      TIME_BUFFER :    out RTEMS.TIME_OF_DAY;
-   ) is
-   begin
-   end CLOCK_GET_TOD;
-   procedure CLOCK_SET (
-   ) is
-   begin
-   end CLOCK_SET;
-   procedure CLOCK_TICK (
-   ) is
-   begin
-   end CLOCK_TICK;
--- Timer Manager
-   procedure TIMER_CREATE (
-   ) is
-   begin
-      ID := 0;
-   end TIMER_CREATE;
-   procedure TIMER_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end TIMER_DELETE;
-   procedure TIMER_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end TIMER_IDENT;
-   procedure TIMER_FIRE_AFTER (
-      ID        : in     RTEMS.ID;
-      ROUTINE   : in     RTEMS.TIMER.SERVICE_ROUTINE;
-      USER_DATA : in     RTEMS.ADDRESS;
-   ) is
-      pragma Unreferenced(ROUTINE);
-      pragma Unreferenced(USER_DATA);
-   begin
-   end TIMER_FIRE_AFTER;
-   procedure TIMER_FIRE_WHEN (
-      ID        : in     RTEMS.ID;
-      WALL_TIME : in     RTEMS.TIME_OF_DAY;
-   ) is
-      pragma Unreferenced(WALL_TIME);
-   begin
-   end TIMER_FIRE_WHEN;
-   procedure TIMER_RESET (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end TIMER_RESET;
-   procedure TIMER_CANCEL (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end TIMER_CANCEL;
--- Semaphore Manager
-   procedure SEMAPHORE_CREATE (
-      COUNT            : in     RTEMS.UNSIGNED32;
-      PRIORITY_CEILING : in     RTEMS.TASKS.PRIORITY;
-   ) is
-      pragma Unreferenced(COUNT);
-      pragma Unreferenced(PRIORITY_CEILING);
-   begin
-      ID := 0;
-   end SEMAPHORE_CREATE;
-   procedure SEMAPHORE_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end SEMAPHORE_DELETE;
-   procedure SEMAPHORE_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end SEMAPHORE_IDENT;
-   procedure SEMAPHORE_OBTAIN (
-      ID         : in     RTEMS.ID;
-      OPTION_SET : in     RTEMS.OPTION;
-      TIMEOUT    : in     RTEMS.INTERVAL;
-   ) is
-      pragma Unreferenced(OPTION_SET);
-      pragma Unreferenced(TIMEOUT);
-   begin
-   end SEMAPHORE_OBTAIN;
-   procedure SEMAPHORE_RELEASE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end SEMAPHORE_RELEASE;
--- Message Queue Manager
-   procedure MESSAGE_QUEUE_CREATE (
-      Name             : in     RTEMS.Name;
-      Count            : in     RTEMS.Unsigned32;
-      Max_Message_Size : in     RTEMS.Unsigned32;
-      Attribute_Set    : in     RTEMS.Attribute;
-      Result           :    out RTEMS.Status_Codes
-   ) is
-      pragma Unreferenced(Name);
-      pragma Unreferenced(Count);
-      pragma Unreferenced(Max_Message_Size);
-      pragma Unreferenced(Attribute_Set);
-   begin
-      ID := 0;
-   end MESSAGE_QUEUE_CREATE;
-   procedure MESSAGE_QUEUE_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end MESSAGE_QUEUE_IDENT;
-   procedure MESSAGE_QUEUE_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end MESSAGE_QUEUE_DELETE;
-   procedure MESSAGE_QUEUE_SEND (
-      ID     : in     RTEMS.ID;
-      BUFFER : in     RTEMS.ADDRESS;
-      Size   : in     RTEMS.Unsigned32;
-   ) is
-      pragma Unreferenced(BUFFER);
-      pragma Unreferenced(Size);
-   begin
-   end MESSAGE_QUEUE_SEND;
-   procedure MESSAGE_QUEUE_URGENT (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end MESSAGE_QUEUE_URGENT;
-   procedure MESSAGE_QUEUE_BROADCAST (
-      ID     : in     RTEMS.ID;
-      COUNT  :    out RTEMS.UNSIGNED32;
-   ) is
-   begin
-      COUNT := 0;
-   end MESSAGE_QUEUE_BROADCAST;
-   procedure MESSAGE_QUEUE_RECEIVE (
-      ID         : in     RTEMS.ID;
-      Size       :    out RTEMS.Unsigned32;
-   ) is
-   begin
-      Size := 0;
-   end MESSAGE_QUEUE_RECEIVE;
-   procedure MESSAGE_QUEUE_FLUSH (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-      COUNT := 0;
-   end MESSAGE_QUEUE_FLUSH;
--- Event Manager
-   procedure EVENT_SEND (
-      ID       : in     RTEMS.ID;
-      EVENT_IN : in     RTEMS.EVENT_SET;
-   ) is
-      pragma Unreferenced(EVENT_IN);
-   begin
-   end EVENT_SEND;
-   procedure EVENT_RECEIVE (
-      EVENT_OUT  :    out RTEMS.EVENT_SET;
-   ) is
-   begin
-      EVENT_OUT := 0;
-   end EVENT_RECEIVE;
--- Signal Manager
-   procedure SIGNAL_CATCH (
-      ASR_HANDLER : in     RTEMS.ASR_HANDLER;
-   ) is
-      pragma Unreferenced(ASR_HANDLER);
-   begin
-   end SIGNAL_CATCH;
-   procedure SIGNAL_SEND (
-      ID         : in     RTEMS.ID;
-      SIGNAL_SET : in     RTEMS.SIGNAL_SET;
-   ) is
-      pragma Unreferenced(SIGNAL_SET);
-   begin
-   end SIGNAL_SEND;
--- Partition Manager
-   procedure PARTITION_CREATE (
-      STARTING_ADDRESS : in     RTEMS.ADDRESS;
-      LENGTH           : in     RTEMS.UNSIGNED32;
-      BUFFER_SIZE      : in     RTEMS.UNSIGNED32;
-   ) is
-      pragma Unreferenced(STARTING_ADDRESS);
-      pragma Unreferenced(LENGTH);
-      pragma Unreferenced(BUFFER_SIZE);
-   begin
-      ID := 0;
-   end PARTITION_CREATE;
-   procedure PARTITION_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end PARTITION_IDENT;
-   procedure PARTITION_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end PARTITION_DELETE;
-   procedure PARTITION_GET_BUFFER (
-      ID     : in     RTEMS.ID;
-      BUFFER :    out RTEMS.ADDRESS;
-   ) is
-   begin
-      BUFFER := RTEMS.Null_Address;
-   end PARTITION_GET_BUFFER;
-   procedure PARTITION_RETURN_BUFFER (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end PARTITION_RETURN_BUFFER;
--- Region Manager
-   procedure REGION_CREATE (
-      PAGE_SIZE        : in     RTEMS.UNSIGNED32;
-   ) is
-      pragma Unreferenced(PAGE_SIZE);
-   begin
-      ID := 0;
-   end REGION_CREATE;
-   procedure REGION_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end REGION_IDENT;
-   procedure REGION_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end REGION_DELETE;
-   procedure REGION_GET_SEGMENT (
-      ID         : in     RTEMS.ID;
-      SIZE       : in     RTEMS.UNSIGNED32;
-      SEGMENT    :    out RTEMS.ADDRESS;
-   ) is
-      pragma Unreferenced(SIZE);
-   begin
-      SEGMENT := RTEMS.Null_Address;
-   end REGION_GET_SEGMENT;
-   procedure REGION_RETURN_SEGMENT (
-      ID      : in     RTEMS.ID;
-      SEGMENT : in     RTEMS.ADDRESS;
-   ) is
-      pragma Unreferenced(SEGMENT);
-   begin
-   end REGION_RETURN_SEGMENT;
--- Dual Ported Memory Manager
-   procedure PORT_CREATE (
-      INTERNAL_START : in     RTEMS.ADDRESS;
-      EXTERNAL_START : in     RTEMS.ADDRESS;
-   ) is
-      pragma Unreferenced(INTERNAL_START);
-      pragma Unreferenced(EXTERNAL_START);
-   begin
-      ID := 0;
-   end PORT_CREATE;
-   procedure PORT_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end PORT_IDENT;
-   procedure PORT_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end PORT_DELETE;
-   procedure PORT_EXTERNAL_TO_INTERNAL (
-      ID       : in     RTEMS.ID;
-      EXTERNAL : in     RTEMS.ADDRESS;
-      INTERNAL :    out RTEMS.ADDRESS;
-   ) is
-      pragma Unreferenced(EXTERNAL);
-   begin
-      INTERNAL := RTEMS.Null_Address;
-   end PORT_EXTERNAL_TO_INTERNAL;
-   procedure PORT_INTERNAL_TO_EXTERNAL (
-      ID       : in     RTEMS.ID;
-      INTERNAL : in     RTEMS.ADDRESS;
-      EXTERNAL :    out RTEMS.ADDRESS;
-   ) is
-      pragma Unreferenced(INTERNAL);
-   begin
-      EXTERNAL := RTEMS.Null_Address;
-   end PORT_INTERNAL_TO_EXTERNAL;
--- Fatal Error Manager
-   procedure FATAL_ERROR_OCCURRED (
-      THE_ERROR : in     RTEMS.UNSIGNED32
-   ) is
-      pragma Unreferenced(THE_ERROR);
-   begin
-      NULL;
-   end FATAL_ERROR_OCCURRED;
--- Rate Monotonic Manager
-   procedure RATE_MONOTONIC_CREATE (
-   ) is
-   begin
-      ID := 0;
-   end RATE_MONOTONIC_CREATE;
-   procedure RATE_MONOTONIC_IDENT (
-   ) is
-   begin
-      ID := 0;
-   end RATE_MONOTONIC_IDENT;
-   procedure RATE_MONOTONIC_DELETE (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end RATE_MONOTONIC_DELETE;
-   procedure RATE_MONOTONIC_CANCEL (
-      ID     : in     RTEMS.ID;
-   ) is
-   begin
-   end RATE_MONOTONIC_CANCEL;
-   procedure RATE_MONOTONIC_PERIOD (
-      ID      : in     RTEMS.ID;
-      LENGTH  : in     RTEMS.INTERVAL;
-   ) is
-   begin
-   end RATE_MONOTONIC_PERIOD;
--- Multiprocessing Manager
-   procedure MULTIPROCESSING_ANNOUNCE
-   is
-   begin
-      NULL;
-   end MULTIPROCESSING_ANNOUNCE;
-end DUMMY_RTEMS;
diff --git a/testsuites/ada/tmtests/tmoverhd/dummy_rtems.ads b/testsuites/ada/tmtests/tmoverhd/dummy_rtems.ads
index ea4f129893..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/dummy_rtems.ads
+++ /dev/null
@@ -1,445 +0,0 @@
---  DESCRIPTION:
---  This package contains specifications for stub routines
---  DEPENDENCIES:
---  COPYRIGHT (c) 1989-2007.
-with RTEMS;
-with RTEMS.CLOCK;
-with RTEMS.TASKS;
-with RTEMS.TIMER;
-package DUMMY_RTEMS is
--- Task Manager
-      ID          : in     RTEMS.ID;
-      ID       : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID           : in     RTEMS.ID;
--- Clock Manager
--- Timer Manager
-      ID     : in     RTEMS.ID;
-      ID        : in     RTEMS.ID;
-      ID        : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID         : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID         : in     RTEMS.ID;
-      SIZE       :    out RTEMS.UNSIGNED32;
-      ID     : in     RTEMS.ID;
--- Event Manager
-      ID       : in     RTEMS.ID;
--- Signal Manager
-      ID         : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
--- Region Manager
-      ID     : in     RTEMS.ID;
-      ID         : in     RTEMS.ID;
-      ID      : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID       : in     RTEMS.ID;
-      ID       : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID     : in     RTEMS.ID;
-      ID      : in     RTEMS.ID;
-   procedure MULTIPROCESSING_ANNOUNCE;
-end DUMMY_RTEMS;
diff --git a/testsuites/ada/tmtests/tmoverhd/init.c b/testsuites/ada/tmtests/tmoverhd/init.c
index 37b6c28faa..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/init.c
+++ /dev/null
@@ -1,34 +0,0 @@
-/*  config.h
- *  This include file defines the Configuration Table for this test.
- *  COPYRIGHT (c) 1989-1997.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-/* configuration information */
-#define CONFIGURE_TMTEST
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS              2
-#define ADA_TEST_NAME "ADA TMOVERHD"
-#define CONFIGURE_MAXIMUM_SEMAPHORES         1
-#define CONFIGURE_TICKS_PER_TIMESLICE        0
-#define CONFIGURE_POSIX_INIT_THREAD_TABLE
-#define CONFIGURE_MAXIMUM_POSIX_THREADS              10
-#define CONFIGURE_MAXIMUM_POSIX_KEYS                 10
-#include "../../support/initimpl.h"
-/* end of include file */
diff --git a/testsuites/ada/tmtests/tmoverhd/tmoverhd.adb b/testsuites/ada/tmtests/tmoverhd/tmoverhd.adb
index bfe6de4f88..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/tmoverhd.adb
+++ /dev/null
@@ -1,55 +0,0 @@
---  MAIN / BODY
---  DESCRIPTION:
---  This is the entry point for Test TMOVERHD of the Timing Test Suite.
---  DEPENDENCIES:
---  COPYRIGHT (c) 1989-1997.
-with RTEMS;
-with RTEMS.TASKS;
-with TMTEST;
-with TEST_SUPPORT;
-procedure TMOVERHD is
-  INIT_ID : RTEMS.ID;
-  STATUS  : RTEMS.STATUS_CODES;
-begin
-   RTEMS.TASKS.CREATE(
-      RTEMS.BUILD_NAME(  'I', 'N', 'I', 'T' ),
-      1,
-      RTEMS.MINIMUM_STACK_SIZE,
-      RTEMS.NO_PREEMPT,
-      RTEMS.DEFAULT_ATTRIBUTES,
-      INIT_ID,
-      STATUS
-   TEST_SUPPORT.DIRECTIVE_FAILED( STATUS, "TASK_CREATE OF INIT" );
-   RTEMS.TASKS.START(
-      INIT_ID,
-      TMTEST.INIT'ACCESS,
-      0,
-      STATUS
-   TEST_SUPPORT.DIRECTIVE_FAILED( STATUS, "TASK_START OF INIT" );
-   loop
-      delay 120.0;
-   end loop;
-end TMOVERHD;
diff --git a/testsuites/ada/tmtests/tmoverhd/tmtest.adb b/testsuites/ada/tmtests/tmoverhd/tmtest.adb
index d271ed220c..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/tmtest.adb
+++ /dev/null
@@ -1,1363 +0,0 @@
---  TMTEST / BODY
---  DESCRIPTION:
---  This package is the implementation of Calling Overhead Test of the RTEMS
---  Timing Test Suite.
---  DEPENDENCIES:
-with DUMMY_RTEMS;
-with TEST_SUPPORT;
-with TEXT_IO;
-with TIME_TEST_SUPPORT;
-with TIMER_DRIVER;
-package body TMTEST is
---PAGE
---  INIT
-   procedure INIT (
-      ARGUMENT : in     RTEMS.TASKS.ARGUMENT
-   ) is
-   begin
-      TEXT_IO.NEW_LINE( 2 );
-      TEST_SUPPORT.ADA_TEST_BEGIN;
-      TIMER_DRIVER.SET_FIND_AVERAGE_OVERHEAD( TRUE );
-      TMTEST.TASK_NAME( 1 ) := RTEMS.BUILD_NAME(  'T', 'A', '1', ' ' );
-         TMTEST.TASK_NAME( 1 ),
-         254,
-         2048,
-         RTEMS.DEFAULT_MODES,
-         TMTEST.TASK_ID( 1 ),
-         STATUS
-      TEST_SUPPORT.DIRECTIVE_FAILED( STATUS, "TASK_CREATE OF TA1" );
-         TMTEST.TASK_1'ACCESS,
-         0,
-         STATUS
-      TEST_SUPPORT.DIRECTIVE_FAILED( STATUS, "TASK_START OF TA1" );
-      RTEMS.TASKS.DELETE( RTEMS.SELF, STATUS );
-      TEST_SUPPORT.DIRECTIVE_FAILED( STATUS, "TASK_DELETE OF SELF" );
-   end INIT;
---PAGE
---  TIMER_HANDLER
-   procedure TIMER_HANDLER (
-      IGNORED_ID      : in     RTEMS.ID;
-      IGNORED_ADDRESS : in     RTEMS.ADDRESS
-   ) is
-   begin
-      NULL;
-   end TIMER_HANDLER;
---PAGE
---  ISR_HANDLER
---   procedure ISR_HANDLER (
---   ) is
---   begin
---      NULL;
---   end ISR_HANDLER;
---PAGE
---  ASR_HANDLER
-   procedure ASR_HANDLER (
-      SIGNALS : in     RTEMS.SIGNAL_SET
-   ) is
-   begin
-      NULL;
-   end ASR_HANDLER;
---PAGE
---  TASK_1
-   procedure TASK_1 (
-   ) is
-      NAME           : RTEMS.NAME;
-      OVERHEAD       : RTEMS.UNSIGNED32;
-      ID             : RTEMS.ID;
-      IN_PRIORITY    : RTEMS.TASKS.PRIORITY;
-      OUT_PRIORITY   : RTEMS.TASKS.PRIORITY;
-      IN_MODE        : RTEMS.MODE;
-      MASK           : RTEMS.MODE;
-      OUT_MODE       : RTEMS.MODE;
-      TIME           : RTEMS.TIME_OF_DAY;
-      TIMEOUT        : RTEMS.INTERVAL;
-      SIGNALS        : RTEMS.SIGNAL_SET;
-      ADDRESS_1      : RTEMS.ADDRESS;
-      EVENTS         : RTEMS.SIGNAL_SET;
-      BUFFER         : TMTEST.BUFFER;
-      BUFFER_POINTER : RTEMS.ADDRESS;
-      MESSAGE_SIZE   : RTEMS.UNSIGNED32;
-      COUNT          : RTEMS.UNSIGNED32;
-      ERROR          : RTEMS.UNSIGNED32;
-   begin
-      NAME := RTEMS.BUILD_NAME(  'N', 'A', 'M', 'E' );
-      BUFFER_POINTER := BUFFER'ADDRESS;
-      OVERHEAD := 0;
-      IN_PRIORITY := 0;
-      IN_MODE := 0;
-      MASK := 0;
-      SIGNALS := 0;
-      EVENTS := 0;
-      ERROR := 0;
--- TASK_CREATE
-      TIMER_DRIVER.INITIALIZE;
-         for INDEX in 1 .. TIME_TEST_SUPPORT.OPERATION_COUNT
-         loop
-            DUMMY_RTEMS.TASK_CREATE(
-               NAME,
-               IN_PRIORITY,
-               2048,
-               ID,
-               STATUS
-         end loop;
-      TMTEST.END_TIME := TIMER_DRIVER.READ_TIMER;
-      TIME_TEST_SUPPORT.PUT_TIME(
-         "TASK_CREATE",
-         TMTEST.END_TIME,
-         TIME_TEST_SUPPORT.OPERATION_COUNT,
-         OVERHEAD,
-         0
--- TASK_IDENT
-         loop
-            DUMMY_RTEMS.TASK_IDENT(
-               NAME,
-               RTEMS.SEARCH_ALL_NODES,
-               ID,
-               STATUS
-         end loop;
-         "TASK_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_START
-         loop
-            DUMMY_RTEMS.TASK_START( ID, TMTEST.TASK_1'ACCESS, 0, STATUS );
-         end loop;
-         "TASK_START",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_RESTART
-         loop
-            DUMMY_RTEMS.TASK_RESTART( ID, 0, STATUS );
-         end loop;
-         "TASK_RESTART",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_DELETE
-         loop
-            DUMMY_RTEMS.TASK_DELETE( ID, STATUS );
-         end loop;
-         "TASK_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_SUSPEND
-         loop
-            DUMMY_RTEMS.TASK_SUSPEND( ID, STATUS );
-         end loop;
-         "TASK_SUSPEND",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_RESUME
-         loop
-            DUMMY_RTEMS.TASK_RESUME( ID, STATUS );
-         end loop;
-         "TASK_RESUME",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_SET_PRIORITY
-         loop
-            DUMMY_RTEMS.TASK_SET_PRIORITY(
-               ID,
-               IN_PRIORITY,
-               OUT_PRIORITY,
-               STATUS
-         end loop;
-         "TASK_SET_PRIORITY",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_MODE
-         loop
-            DUMMY_RTEMS.TASK_MODE(
-               IN_MODE,
-               MASK,
-               OUT_MODE,
-               STATUS
-         end loop;
-         "TASK_MODE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_WAKE_WHEN
-      TIME.YEAR    := 2000;
-      TIME.MONTH   := 12;
-      TIME.DAY     := 25;
-      TIME.HOUR    := 6;
-      TIME.MINUTE  := 1;
-      TIME.SECOND  := 2;
-      TIME.TICKS   := 0;
-         loop
-            DUMMY_RTEMS.TASK_WAKE_WHEN( TIME, STATUS );
-         end loop;
-         "TASK_WAKE_WHEN",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TASK_WAKE_AFTER
-      TIMEOUT := 1;
-         loop
-            DUMMY_RTEMS.TASK_WAKE_AFTER( TIMEOUT, STATUS );
-         end loop;
-         "TASK_WAKE_AFTER",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- INTERRUPT_CATCH
---      TIMER_DRIVER.INITIALIZE;
---         for INDEX in 1 .. TIME_TEST_SUPPORT.OPERATION_COUNT
---         loop
---            DUMMY_RTEMS.INTERRUPT_CATCH(
---               TMTEST.ISR_HANDLER'ADDRESS,
---               RTEMS.VECTOR_NUMBER'FIRST,
---               ADDRESS_1,
---               STATUS
---         end loop;
---      TMTEST.END_TIME := TIMER_DRIVER.READ_TIMER;
---      TIME_TEST_SUPPORT.PUT_TIME(
---         "INTERRUPT_CATCH",
---         TMTEST.END_TIME,
---         TIME_TEST_SUPPORT.OPERATION_COUNT,
---         OVERHEAD,
---         0
--- CLOCK_GET_TOD
-         loop
-            DUMMY_RTEMS.CLOCK_GET_TOD( TIME, STATUS );
-         end loop;
-         "CLOCK_GET",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- CLOCK_SET
-         loop
-            DUMMY_RTEMS.CLOCK_SET( TIME, STATUS );
-         end loop;
-         "CLOCK_SET",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- CLOCK_TICK
-         loop
-            DUMMY_RTEMS.CLOCK_TICK( STATUS );
-         end loop;
-         "CLOCK_TICK",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
-TEST_SUPPORT.PAUSE;
--- TIMER_CREATE
-         loop
-            DUMMY_RTEMS.TIMER_CREATE( NAME, ID, STATUS );
-         end loop;
-         "TIMER_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TIMER_DELETE
-         loop
-            DUMMY_RTEMS.TIMER_DELETE( ID, STATUS );
-         end loop;
-         "TIMER_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TIMER_IDENT
-         loop
-            DUMMY_RTEMS.TIMER_IDENT(
-               NAME,
-               ID,
-               STATUS
-         end loop;
-         "TIMER_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TIMER_FIRE_AFTER
-         loop
-            DUMMY_RTEMS.TIMER_FIRE_AFTER(
-               ID,
-               TIMEOUT,
-               TMTEST.TIMER_HANDLER'ACCESS,
-               RTEMS.NULL_ADDRESS,
-               STATUS
-         end loop;
-         "TIMER_FIRE_AFTER",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TIMER_FIRE_WHEN
-         loop
-            DUMMY_RTEMS.TIMER_FIRE_WHEN(
-               ID,
-               TIME,
-               STATUS
-         end loop;
-         "TIMER_FIRE_WHEN",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TIMER_RESET
-         loop
-            DUMMY_RTEMS.TIMER_RESET( ID, STATUS );
-         end loop;
-         "TIMER_RESET",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- TIMER_CANCEL
-         loop
-            DUMMY_RTEMS.TIMER_CANCEL( ID, STATUS );
-         end loop;
-         "TIMER_CANCEL",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SEMAPHORE_CREATE
-         loop
-            DUMMY_RTEMS.SEMAPHORE_CREATE(
-               NAME,
-               128,
-               RTEMS.TASKS.NO_PRIORITY,
-               ID,
-               STATUS
-         end loop;
-         "SEMAPHORE_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SEMAPHORE_DELETE
-         loop
-            DUMMY_RTEMS.SEMAPHORE_DELETE( ID, STATUS );
-         end loop;
-         "SEMAPHORE_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SEMAPHORE_IDENT
-         loop
-            DUMMY_RTEMS.SEMAPHORE_IDENT(
-               NAME,
-               ID,
-               STATUS
-         end loop;
-         "SEMAPHORE_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SEMAPHORE_OBTAIN
-         loop
-            DUMMY_RTEMS.SEMAPHORE_OBTAIN(
-               ID,
-               RTEMS.DEFAULT_OPTIONS,
-               TIMEOUT,
-               STATUS
-         end loop;
-         "SEMAPHORE_OBTAIN",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SEMAPHORE_RELEASE
-         loop
-            DUMMY_RTEMS.SEMAPHORE_RELEASE( ID, STATUS );
-         end loop;
-         "SEMAPHORE_RELEASE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_CREATE
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_CREATE(
-               NAME,
-               128,
-               16,
-               ID,
-               STATUS
-         end loop;
-         "MESSAGE_QUEUE_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_IDENT
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_IDENT(
-               NAME,
-               ID,
-               STATUS
-         end loop;
-         "MESSAGE_QUEUE_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_DELETE
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_DELETE( ID, STATUS );
-         end loop;
-         "MESSAGE_QUEUE_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_SEND
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_SEND( ID, BUFFER_POINTER, 16, STATUS );
-         end loop;
-         "MESSAGE_QUEUE_SEND",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_URGENT
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_URGENT( ID, BUFFER_POINTER, 16, STATUS );
-         end loop;
-         "MESSAGE_QUEUE_URGENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_BROADCAST
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_BROADCAST(
-               ID,
-               BUFFER_POINTER,
-               16,
-               COUNT,
-               STATUS
-         end loop;
-         "MESSAGE_QUEUE_BROADCAST",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_RECEIVE
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_RECEIVE(
-               ID,
-               BUFFER_POINTER,
-               TIMEOUT,
-               MESSAGE_SIZE,
-               STATUS
-         end loop;
-         "MESSAGE_QUEUE_RECEIVE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MESSAGE_QUEUE_FLUSH
-         loop
-            DUMMY_RTEMS.MESSAGE_QUEUE_FLUSH( ID, COUNT, STATUS );
-         end loop;
-         "MESSAGE_QUEUE_FLUSH",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- EVENT_SEND
-         loop
-            DUMMY_RTEMS.EVENT_SEND( ID, EVENTS, STATUS );
-         end loop;
-         "EVENT_SEND",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- EVENT_RECEIVE
-         loop
-            DUMMY_RTEMS.EVENT_RECEIVE(
-               RTEMS.EVENT_16,
-               EVENTS,
-               TIMEOUT,
-               STATUS
-         end loop;
-         "EVENT_RECEIVE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SIGNAL_CATCH
-         loop
-            DUMMY_RTEMS.SIGNAL_CATCH(
-               TMTEST.ASR_HANDLER'ACCESS,
-               STATUS
-         end loop;
-         "SIGNAL_CATCH",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- SIGNAL_SEND
-         loop
-            DUMMY_RTEMS.SIGNAL_SEND( ID, SIGNALS, STATUS );
-         end loop;
-         "SIGNAL_SEND",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PARTITION_CREATE
-         loop
-            DUMMY_RTEMS.PARTITION_CREATE(
-               NAME,
-               TMTEST.MEMORY_AREA'ADDRESS,
-               2048,
-               128,
-               ID,
-               STATUS
-         end loop;
-         "PARTITION_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PARTITION_IDENT
-         loop
-            DUMMY_RTEMS.PARTITION_IDENT(
-               NAME,
-               ID,
-               STATUS
-         end loop;
-         "PARTITION_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PARTITION_DELETE
-         loop
-            DUMMY_RTEMS.PARTITION_DELETE( ID, STATUS );
-         end loop;
-         "PARTITION_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PARTITION_GET_BUFFER
-         loop
-            DUMMY_RTEMS.PARTITION_GET_BUFFER( ID, ADDRESS_1, STATUS );
-         end loop;
-         "PARTITION_GET_BUFFER",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PARTITION_RETURN_BUFFER
-         loop
-            DUMMY_RTEMS.PARTITION_RETURN_BUFFER( ID, ADDRESS_1, STATUS );
-         end loop;
-         "PARTITION_RETURN_BUFFER",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- REGION_CREATE
-         loop
-            DUMMY_RTEMS.REGION_CREATE(
-               NAME,
-               2048,
-               128,
-               ID,
-               STATUS
-         end loop;
-         "REGION_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- REGION_IDENT
-         loop
-            DUMMY_RTEMS.REGION_IDENT(
-               NAME,
-               ID,
-               STATUS
-         end loop;
-         "REGION_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- REGION_DELETE
-         loop
-            DUMMY_RTEMS.REGION_DELETE( ID, STATUS );
-         end loop;
-         "REGION_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- REGION_GET_SEGMENT
-         loop
-            DUMMY_RTEMS.REGION_GET_SEGMENT(
-               ID,
-               243,
-               TIMEOUT,
-               ADDRESS_1,
-               STATUS
-         end loop;
-         "REGION_GET_SEGMENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- REGION_RETURN_SEGMENT
-         loop
-            DUMMY_RTEMS.REGION_RETURN_SEGMENT( ID, ADDRESS_1, STATUS );
-         end loop;
-         "REGION_RETURN_SEGMENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PORT_CREATE
-         loop
-            DUMMY_RTEMS.PORT_CREATE(
-               NAME,
-               TMTEST.INTERNAL_PORT_AREA'ADDRESS,
-               TMTEST.EXTERNAL_PORT_AREA'ADDRESS,
-               TMTEST.INTERNAL_PORT_AREA'LENGTH,
-               ID,
-               STATUS
-         end loop;
-         "PORT_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PORT_IDENT
-         loop
-            DUMMY_RTEMS.PORT_IDENT( NAME, ID, STATUS );
-         end loop;
-         "PORT_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PORT_DELETE
-         loop
-            DUMMY_RTEMS.PORT_DELETE( ID, STATUS );
-         end loop;
-         "PORT_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PORT_EXTERNAL_TO_INTERNAL
-         loop
-            DUMMY_RTEMS.PORT_EXTERNAL_TO_INTERNAL(
-               ID,
-               TMTEST.EXTERNAL_PORT_AREA( 7 )'ADDRESS,
-               ADDRESS_1,
-               STATUS
-         end loop;
-         "PORT_EXTERNAL_TO_INTERNAL",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- PORT_INTERNAL_TO_EXTERNAL
-         loop
-            DUMMY_RTEMS.PORT_INTERNAL_TO_EXTERNAL(
-               ID,
-               TMTEST.INTERNAL_PORT_AREA( 7 )'ADDRESS,
-               ADDRESS_1,
-               STATUS
-         end loop;
-         "PORT_INTERNAL_TO_EXTERNAL",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- FATAL_ERROR_OCCURRED
-         loop
-            DUMMY_RTEMS.FATAL_ERROR_OCCURRED( ERROR );
-         end loop;
-         "FATAL_ERROR_OCCURRED",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- RATE_MONOTONIC_CREATE
-         loop
-            DUMMY_RTEMS.RATE_MONOTONIC_CREATE( NAME, ID, STATUS );
-         end loop;
-         "RATE_MONOTONIC_CREATE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- RATE_MONOTONIC_IDENT
-         loop
-            DUMMY_RTEMS.RATE_MONOTONIC_IDENT(
-               NAME,
-               ID,
-               STATUS
-         end loop;
-         "RATE_MONOTONIC_IDENT",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- RATE_MONOTONIC_DELETE
-         loop
-            DUMMY_RTEMS.RATE_MONOTONIC_DELETE( ID, STATUS );
-         end loop;
-         "RATE_MONOTONIC_DELETE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- RATE_MONOTONIC_CANCEL
-         loop
-            DUMMY_RTEMS.RATE_MONOTONIC_CANCEL( ID, STATUS );
-         end loop;
-         "RATE_MONOTONIC_CANCEL",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- RATE_MONOTONIC_PERIOD
-         loop
-            DUMMY_RTEMS.RATE_MONOTONIC_PERIOD( ID, TIMEOUT, STATUS );
-         end loop;
-         "RATE_MONOTONIC_PERIOD",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
--- MULTIPROCESSING_ANNOUNCE
-         loop
-            DUMMY_RTEMS.MULTIPROCESSING_ANNOUNCE;
-         end loop;
-         "MULTIPROCESSING_ANNOUNCE",
-         TMTEST.END_TIME,
-         OVERHEAD,
-         0
-      TEST_SUPPORT.ADA_TEST_END;
-      RTEMS.SHUTDOWN_EXECUTIVE( 0 );
-   end TASK_1;
-end TMTEST;
diff --git a/testsuites/ada/tmtests/tmoverhd/tmtest.ads b/testsuites/ada/tmtests/tmoverhd/tmtest.ads
index 48944077de..0000000000
--- a/testsuites/ada/tmtests/tmoverhd/tmtest.ads
+++ /dev/null
@@ -1,156 +0,0 @@
---  TMTEST / SPECIFICATION
---  DESCRIPTION:
---  This package is the specification for Calling Overhead Test of the RTEMS
---  DEPENDENCIES:
-with RTEMS;
-with RTEMS.TASKS;
-with SYSTEM;
-with System.Storage_Elements;
-package TMTEST is
---  Buffer Record similar to that used by RTEMS 3.2.1.  Using this
---  avoids changes to the test.
-   type BUFFER is
-      record
-         FIELD1 : RTEMS.UNSIGNED32;   -- TEMPORARY UNTIL VARIABLE LENGTH
-         FIELD2 : RTEMS.UNSIGNED32;
-         FIELD3 : RTEMS.UNSIGNED32;
-         FIELD4 : RTEMS.UNSIGNED32;
-      end record;
---  These arrays contain the IDs and NAMEs of all RTEMS tasks created
---  by this test.
-   TASK_ID   : array ( RTEMS.UNSIGNED32 range 1 .. 3 ) of RTEMS.ID;
-   TASK_NAME : array ( RTEMS.UNSIGNED32 range 1 .. 3 ) of RTEMS.NAME;
---  The following variable is set to the execution time returned
---  by the timer.
-   END_TIME  : RTEMS.UNSIGNED32;
---  The following area defines a memory area to be used as the
---  internal address space of the port.
-   INTERNAL_PORT_AREA_ADDRESS : constant System.Address :=
-      System.Storage_Elements.To_Address(16#00001000#);
-   INTERNAL_PORT_AREA : array ( RTEMS.UNSIGNED32 range 0 .. 255 )
-      of RTEMS.UNSIGNED8;
-   for INTERNAL_PORT_AREA'Address use INTERNAL_PORT_AREA_ADDRESS;
---  external address space of the port.
-   EXTERNAL_PORT_AREA_ADDRESS : constant System.Address :=
-      System.Storage_Elements.To_Address(16#00002000#);
-   EXTERNAL_PORT_AREA : array ( RTEMS.UNSIGNED32 range 0 .. 255 )
-   for EXTERNAL_PORT_AREA'Address use EXTERNAL_PORT_AREA_ADDRESS;
---  memory space for a partition and later for a region.
-   MEMORY_AREA : array ( RTEMS.UNSIGNED32 range 0 .. 255 ) of RTEMS.UNSIGNED8;
-   for MEMORY_AREA'ALIGNMENT use RTEMS.STRUCTURE_ALIGNMENT;
---  INIT
---  DESCRIPTION:
---  This RTEMS task initializes the application.
-   procedure INIT (
-   pragma Convention (C, INIT);
---  TIMER_HANDLER
---  DESCRIPTION:
---  This subprogram is a timer service routine.
-   pragma Convention (C, TIMER_HANDLER);
---  ISR_HANDLER
---  DESCRIPTION:
---  This subprogram is an interrupt service routine.
---  ASR_HANDLER
---  DESCRIPTION:
---  This subprogram is an asynchronous signal routine.
-   pragma Convention (C, ASR_HANDLER);
---  TASK_1
---  DESCRIPTION:
---  This RTEMS task is responsible for measuring and
---  reporting the calling overhead for all RTEMS
---  directives.
-   pragma Convention (C, TASK_1);
-end TMTEST;
diff --git a/testsuites/tmtests/Makefile.am b/testsuites/tmtests/Makefile.am
index 70b67fa6dd..096f3ad346 100644
--- a/testsuites/tmtests/Makefile.am
+++ b/testsuites/tmtests/Makefile.am
@@ -374,16 +374,6 @@ tmonetoone_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tmonetoone) \
 	$(support_includes)
 endif
-if TEST_tmoverhd
-tm_tests += tmoverhd
-tm_docs += tmoverhd/tmoverhd.doc
-tmoverhd_SOURCES = tmoverhd/testtask.c tmoverhd/empty.c \
-	tmoverhd/system.h tmoverhd/dumrtems.h include/timesys.h \
-	../support/src/tmtests_empty_function.c
-tmoverhd_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tmoverhd) \
-	$(support_includes) -I$(top_srcdir)/include
-endif
 if TEST_tmtimer01
 tm_tests += tmtimer01
 tm_screens += tmtimer01/tmtimer01.scn
diff --git a/testsuites/tmtests/configure.ac b/testsuites/tmtests/configure.ac
index c696965c2f..ea821b9a00 100644
--- a/testsuites/tmtests/configure.ac
+++ b/testsuites/tmtests/configure.ac
@@ -64,7 +64,6 @@ RTEMS_TEST_CHECK([tmck])
 RTEMS_TEST_CHECK([tmcontext01])
 RTEMS_TEST_CHECK([tmfine01])
 RTEMS_TEST_CHECK([tmonetoone])
-RTEMS_TEST_CHECK([tmoverhd])
 RTEMS_TEST_CHECK([tmtimer01])
 AC_CONFIG_FILES([Makefile])
diff --git a/testsuites/tmtests/tmoverhd/dumrtems.h b/testsuites/tmtests/tmoverhd/dumrtems.h
index 4beae9e39f..0000000000
--- a/testsuites/tmtests/tmoverhd/dumrtems.h
+++ /dev/null
@@ -1,250 +0,0 @@
-/*  dumrtems.h
- *  This include file contains phony macros to map
- *  executive calls to Empty_directive().
- *  COPYRIGHT (c) 1989-1999.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
-#ifndef __DUMRTEMS_h
-#define __DUMRTEMS_h
-/* RTEMS call redefinition macros */
-#undef rtems_signal_catch
-#undef rtems_signal_send
-#undef rtems_io_close
-#undef rtems_io_control
-#undef rtems_io_initialize
-#undef rtems_io_open
-#undef rtems_io_read
-#undef rtems_io_write
-#undef rtems_port_internal_to_external
-#undef rtems_port_external_to_internal
-#undef rtems_port_create
-#undef rtems_port_delete
-#undef rtems_port_ident
-#undef rtems_event_receive
-#undef rtems_event_send
-#undef rtems_initialize_data_structures
-#undef rtems_shutdown_executive
-#undef rtems_interrupt_catch
-#undef rtems_partition_create
-#undef rtems_partition_delete
-#undef rtems_partition_get_buffer
-#undef rtems_partition_ident
-#undef rtems_partition_return_buffer
-#undef rtems_message_queue_broadcast
-#undef rtems_message_queue_create
-#undef rtems_message_queue_delete
-#undef rtems_message_queue_flush
-#undef rtems_message_queue_ident
-#undef rtems_message_queue_receive
-#undef rtems_message_queue_send
-#undef rtems_message_queue_urgent
-#undef rtems_region_create
-#undef rtems_region_delete
-#undef rtems_region_get_segment
-#undef rtems_region_ident
-#undef rtems_region_return_segment
-#undef rtems_semaphore_create
-#undef rtems_semaphore_delete
-#undef rtems_semaphore_ident
-#undef rtems_semaphore_obtain
-#undef rtems_semaphore_release
-#undef rtems_task_create
-#undef rtems_task_delete
-#undef rtems_task_ident
-#undef rtems_task_mode
-#undef rtems_task_restart
-#undef rtems_task_resume
-#undef rtems_task_set_priority
-#undef rtems_task_start
-#undef rtems_task_suspend
-#undef rtems_clock_get
-#undef rtems_clock_set
-#undef rtems_clock_tick
-#undef rtems_task_wake_after
-#undef rtems_task_wake_when
-#undef rtems_fatal_error_occurred
-#undef rtems_rate_monotonic_create
-#undef rtems_rate_monotonic_ident
-#undef rtems_rate_monotonic_delete
-#undef rtems_rate_monotonic_cancel
-#undef rtems_rate_monotonic_period
-#undef rtems_multiprocessing_announce
-#undef rtems_timer_create
-#undef rtems_timer_ident
-#undef rtems_timer_delete
-#undef rtems_timer_cancel
-#undef rtems_timer_fire_after
-#undef rtems_timer_fire_when
-#undef rtems_timer_reset
-#define     rtems_signal_catch( asraddr, mode ) \
-           Empty_directive()
-#define     rtems_signal_send( tid, signal ) \
-           Empty_directive()
-#define     rtems_io_close( major, minor, argp, rval ) \
-           Empty_directive()
-#define     rtems_io_control( major, minor, argp, rval ) \
-           Empty_directive()
-#define     rtems_io_initialize( major, minor, argp, rval ) \
-           Empty_directive()
-#define     rtems_io_open( major, minor, argp, rval ) \
-           Empty_directive()
-#define     rtems_io_read( major, minor, argp, rval ) \
-           Empty_directive()
-#define     rtems_io_write( major, minor, argp, rval ) \
-           Empty_directive()
-#define     rtems_port_internal_to_external( dpid, internal, external ) \
-           Empty_directive()
-#define     rtems_port_external_to_internal( dpid, external, internal ) \
-           Empty_directive()
-#define     rtems_port_create( name, intaddr, extaddr, length, dpid ) \
-           Empty_directive()
-#define     rtems_port_delete( dpid ) \
-           Empty_directive()
-#define     rtems_port_ident( name, dpid ) \
-           Empty_directive()
-#define     rtems_event_receive( eventin, options, timeout, eventout ) \
-           Empty_directive()
-#define     rtems_event_send( tid, event ) \
-           Empty_directive()
-#define     rtems_initialize_executive( conftbl, cputbl ) \
-           Empty_directive()
-#define     rtems_shutdown_executive( the_error ) \
-           Empty_directive()
-#define     rtems_interrupt_catch( israddr, vector, oldisr ) \
-           Empty_directive()
-#define     rtems_partition_create( name, paddr, length, bsize, attr, ptid ) \
-           Empty_directive()
-#define     rtems_partition_delete( ptid ) \
-           Empty_directive()
-#define     rtems_partition_get_buffer( ptid, bufaddr ) \
-           Empty_directive()
-#define     rtems_partition_ident( name, node, ptid ) \
-           Empty_directive()
-#define     rtems_partition_return_buffer( ptid, bufaddr ) \
-           Empty_directive()
-#define     rtems_message_queue_broadcast( qid, buffer, count ) \
-           Empty_directive()
-#define     rtems_message_queue_create( name, count, attr, qid ) \
-           Empty_directive()
-#define     rtems_message_queue_delete( qid ) \
-           Empty_directive()
-#define     rtems_message_queue_flush( qid, count ) \
-           Empty_directive()
-#define     rtems_message_queue_ident( name, node, qid ) \
-           Empty_directive()
-#define     rtems_message_queue_receive( qid, buffer, options, timeout ) \
-           Empty_directive()
-#define     rtems_message_queue_send( qid, buffer ) \
-           Empty_directive()
-#define     rtems_message_queue_urgent( qid, buffer ) \
-           Empty_directive()
-#define     rtems_region_create( name, paddr, length, pagesize, attr, rnid ) \
-           Empty_directive()
-#define     rtems_region_delete( rnid ) \
-           Empty_directive()
-#define     rtems_region_get_segment( rnid, size, options, timeout, segaddr ) \
-           Empty_directive()
-#define     rtems_region_ident( name, rnid ) \
-           Empty_directive()
-#define     rtems_region_return_segment( rnid, segaddr ) \
-           Empty_directive()
-#define     rtems_semaphore_create( name, count, attr, priceil, smid ) \
-           Empty_directive()
-#define     rtems_semaphore_delete( smid ) \
-           Empty_directive()
-#define     rtems_semaphore_ident( name, node, smid ) \
-           Empty_directive()
-#define     rtems_semaphore_obtain( smid, options, timeout ) \
-           Empty_directive()
-#define     rtems_semaphore_release( smid ) \
-           Empty_directive()
-#define     rtems_task_create( name, priority, stack_size, mode, attr, tid ) \
-           Empty_directive()
-#define     rtems_task_delete( tid ) \
-           Empty_directive()
-#define     rtems_task_ident( name, node, tid ) \
-           Empty_directive()
-#define     rtems_task_mode( mode, mask, pmode ) \
-           Empty_directive()
-#define     rtems_task_restart( tid, arg ) \
-           Empty_directive()
-#define     rtems_task_resume( tid ) \
-           Empty_directive()
-#define     rtems_task_set_priority( tid, priority, ppriority ) \
-           Empty_directive()
-#define     rtems_task_start( tid, saddr, arg ) \
-           Empty_directive()
-#define     rtems_task_suspend( tid ) \
-           Empty_directive()
-#define     rtems_clock_get_tod( tod ) \
-           Empty_directive()
-#define     rtems_clock_set( time ) \
-           Empty_directive()
-#define     rtems_clock_tick() \
-           Empty_directive()
-#define     rtems_task_wake_after( ticks ) \
-           Empty_directive()
-#define     rtems_task_wake_when( time ) \
-           Empty_directive()
-#define     rtems_fatal_error_occurred( errcode ) \
-           Empty_directive()
-#define     rtems_rate_monotonic_create( name, id ) \
-           Empty_directive()
-#define     rtems_rate_monotonic_ident( name, id ) \
-           Empty_directive()
-#define     rtems_rate_monotonic_delete( id ) \
-           Empty_directive()
-#define     rtems_rate_monotonic_cancel( id ) \
-           Empty_directive()
-#define     rtems_rate_monotonic_period( id, period ) \
-           Empty_directive()
-#define     rtems_multiprocessing_announce() \
-           Empty_directive()
-#define     rtems_timer_create( name, tmid ) \
-           Empty_directive()
-#define     rtems_timer_delete( tmid ) \
-           Empty_directive()
-#define     rtems_timer_cancel( tmid ) \
-           Empty_directive()
-#define     rtems_timer_ident( name, tmid ) \
-           Empty_directive()
-#define     rtems_timer_fire_after( tmid, ticks, routine, user_data ) \
-           Empty_directive()
-#define     rtems_timer_fire_when( tmid, time, routine, user_data ) \
-           Empty_directive()
-#define     rtems_timer_reset( tmid ) \
-           Empty_directive()
-#if defined(__GNUC__)
-#define RTEMS_GCC_NOWARN_UNUSED	RTEMS_UNUSED
-#else
-#endif
-#endif
diff --git a/testsuites/tmtests/tmoverhd/empty.c b/testsuites/tmtests/tmoverhd/empty.c
index 97477c1298..0000000000
--- a/testsuites/tmtests/tmoverhd/empty.c
+++ /dev/null
@@ -1,45 +0,0 @@
- *  COPYRIGHT (c) 1989-2013.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "system.h"
-rtems_timer_service_routine Timer_handler(
-  rtems_id argument
-rtems_asr Isr_handler(
-  rtems_signal_set signals
-rtems_asr Asr_handler(
-rtems_task task_func(void)
-void null_func(void)
-rtems_status_code Empty_directive(void)
-  return( RTEMS_SUCCESSFUL );
diff --git a/testsuites/tmtests/tmoverhd/system.h b/testsuites/tmtests/tmoverhd/system.h
index afe0fe3d10..0000000000
--- a/testsuites/tmtests/tmoverhd/system.h
+++ /dev/null
@@ -1,54 +0,0 @@
-/*  system.h
- *  This include file is used by all tests in the Time Suite.
-#include <tmacros.h>
-/* functions */
-rtems_task Init(
-  rtems_task_argument argument
-  rtems_id argument
-extern rtems_task task_func(void);
-extern void null_func(void);
-extern rtems_status_code Empty_directive(void);
-#include <timesys.h>
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
diff --git a/testsuites/tmtests/tmoverhd/testtask.c b/testsuites/tmtests/tmoverhd/testtask.c
index 2461759f9f..0000000000
--- a/testsuites/tmtests/tmoverhd/testtask.c
+++ /dev/null
@@ -1,1232 +0,0 @@
-#if !defined(OPERATION_COUNT)
-#define OPERATION_COUNT 100
-#endif
-#endif
-#include <rtems/btimer.h>
-#define CONFIGURE_INIT
-const char rtems_test_name[] = "OVERHEAD";
-uint8_t   Memory_area[ 2048 ];
-uint8_t   Internal_port_area[ 256 ];
-uint8_t   External_port_area[ 256 ];
-rtems_task Task_1(
-rtems_task Init(
-{ rtems_id id;
-  rtems_status_code status;
-  benchmark_timer_disable_subtracting_average_overhead( TRUE );
-  Print_Warning();
-  TEST_BEGIN();
-  status = rtems_task_create(
-    rtems_build_name( 'T', 'A', '1', ' ' ),
-    RTEMS_MAXIMUM_PRIORITY - 1,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    &id
-  directive_failed( status, "rtems_task_create of TA1" );
-  status = rtems_task_start( id, Task_1, 0 );
-  directive_failed( status, "rtems_task_start of TA1" );
-  rtems_task_exit();
-/* comment out the following include to verify type are correct */
-#include "dumrtems.h"
-rtems_task Task_1(
-  rtems_name                 name RTEMS_GCC_NOWARN_UNUSED;
-  uint32_t                   index RTEMS_GCC_NOWARN_UNUSED;
-  rtems_id                   id RTEMS_GCC_NOWARN_UNUSED;
-  rtems_task_priority        in_priority RTEMS_GCC_NOWARN_UNUSED;
-  rtems_task_priority        out_priority RTEMS_GCC_NOWARN_UNUSED;
-  rtems_mode                 in_mode RTEMS_GCC_NOWARN_UNUSED;
-  rtems_mode                 mask RTEMS_GCC_NOWARN_UNUSED;
-  rtems_mode                 out_mode RTEMS_GCC_NOWARN_UNUSED;
-  rtems_time_of_day          time RTEMS_GCC_NOWARN_UNUSED;
-  rtems_interval             timeout RTEMS_GCC_NOWARN_UNUSED;
-  rtems_signal_set           signals RTEMS_GCC_NOWARN_UNUSED;
-  void                      *address_1 RTEMS_GCC_NOWARN_UNUSED;
-  rtems_event_set            events RTEMS_GCC_NOWARN_UNUSED;
-  long                       buffer[ 4 ] RTEMS_GCC_NOWARN_UNUSED;
-  uint32_t                   count RTEMS_GCC_NOWARN_UNUSED;
-  rtems_device_major_number  major RTEMS_GCC_NOWARN_UNUSED;
-  rtems_device_minor_number  minor RTEMS_GCC_NOWARN_UNUSED;
-  uint32_t                   io_result RTEMS_GCC_NOWARN_UNUSED;
-  uint32_t                   error RTEMS_GCC_NOWARN_UNUSED;
-  rtems_time_of_day          tod RTEMS_GCC_NOWARN_UNUSED;
-  name        = rtems_build_name( 'N', 'A', 'M', 'E' );
-  in_priority = 250;
-  in_mode     = RTEMS_NO_PREEMPT;
-  mask        = RTEMS_PREEMPT_MASK;
-  timeout     = 100;
-  signals     = RTEMS_SIGNAL_1 | RTEMS_SIGNAL_3;
-  major       = 10;
-  minor       = 0;
-  error       = 100;
-/* rtems_shutdown_executive */
-  benchmark_timer_initialize();
-    for ( index=1 ; index <= OPERATION_COUNT ; index++ )
-      (void) rtems_shutdown_executive( error );
-  end_time = benchmark_timer_read();
-  put_time(
-    "overhead: rtems_shutdown_executive",
-    end_time,
-    OPERATION_COUNT,
-    overhead,
-    0
-/* rtems_task_create */
-         for ( index = 1 ; index <= OPERATION_COUNT ; index ++ )
-            (void) rtems_task_create(
-               name,
-               in_priority,
-               &id
-      put_time(
-         "overhead: rtems_task_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_ident */
-            (void) rtems_task_ident( name, RTEMS_SEARCH_ALL_NODES, id );
-      put_time(
-         "overhead: rtems_task_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_start */
-            (void) rtems_task_start( id, Task_1, 0 );
-      put_time(
-         "overhead: rtems_task_start",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_restart */
-            (void) rtems_task_restart( id, 0 );
-      put_time(
-         "overhead: rtems_task_restart",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_delete */
-            (void) rtems_task_delete( id );
-      put_time(
-         "overhead: rtems_task_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_suspend */
-            (void) rtems_task_suspend( id );
-      put_time(
-         "overhead: rtems_task_suspend",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_resume */
-            (void) rtems_task_resume( id );
-      put_time(
-         "overhead: rtems_task_resume",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_set_priority */
-            (void) rtems_task_set_priority( id, in_priority, &out_priority );
-      put_time(
-         "overhead: rtems_task_set_priority",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_mode */
-            (void) rtems_task_mode( in_mode, mask, &out_mode );
-      put_time(
-         "overhead: rtems_task_mode",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_wake_when */
-            (void) rtems_task_wake_when( time );
-      put_time(
-         "overhead: rtems_task_wake_when",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_task_wake_after */
-            (void) rtems_task_wake_after( timeout );
-      put_time(
-         "overhead: rtems_task_wake_after",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_interrupt_catch */
-            (void) rtems_interrupt_catch( Isr_handler, 5, address_1 );
-      put_time(
-         "overhead: rtems_interrupt_catch",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_clock_get_tod */
-            (void) rtems_clock_get_tod( &tod );
-      put_time(
-         "overhead: rtems_clock_get_tod",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_clock_set */
-            (void) rtems_clock_set( time );
-      put_time(
-         "overhead: rtems_clock_set",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_clock_tick */
-           (void) rtems_clock_tick();
-      put_time(
-         "overhead: rtems_clock_tick",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_create */
-            (void) rtems_timer_create( name, &id );
-      put_time(
-         "overhead: rtems_timer_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_delete */
-            (void) rtems_timer_delete( id );
-      put_time(
-         "overhead: rtems_timer_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_ident */
-            (void) rtems_timer_ident( name, id );
-      put_time(
-         "overhead: rtems_timer_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_fire_after */
-            (void) rtems_timer_fire_after(
-               id,
-               timeout,
-               Timer_handler,
-               NULL
-      put_time(
-         "overhead: rtems_timer_fire_after",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_fire_when */
-            (void) rtems_timer_fire_when(
-               id,
-               time,
-               Timer_handler,
-               NULL
-      put_time(
-         "overhead: rtems_timer_fire_when",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_reset */
-            (void) rtems_timer_reset( id );
-      put_time(
-         "overhead: rtems_timer_reset",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_timer_cancel */
-            (void) rtems_timer_cancel( id );
-      put_time(
-         "overhead: rtems_timer_cancel",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_semaphore_create */
-            (void) rtems_semaphore_create(
-               name,
-               128,
-               RTEMS_NO_PRIORITY,
-               &id
-      put_time(
-         "overhead: rtems_semaphore_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_semaphore_delete */
-            (void) rtems_semaphore_delete( id );
-      put_time(
-         "overhead: rtems_semaphore_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_semaphore_ident */
-            (void) rtems_semaphore_ident( name, RTEMS_SEARCH_ALL_NODES, id );
-      put_time(
-         "overhead: rtems_semaphore_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_semaphore_obtain */
-            (void) rtems_semaphore_obtain( id, RTEMS_DEFAULT_OPTIONS, timeout );
-      put_time(
-         "overhead: rtems_semaphore_obtain",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_semaphore_release */
-            (void) rtems_semaphore_release( id );
-      put_time(
-         "overhead: rtems_semaphore_release",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_create */
-            (void) rtems_message_queue_create(
-               name,
-               128,
-               &id
-      put_time(
-         "overhead: rtems_message_queue_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_ident */
-            (void) rtems_message_queue_ident(
-              name,
-              RTEMS_SEARCH_ALL_NODES,
-              id
-      put_time(
-         "overhead: rtems_message_queue_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_delete */
-            (void) rtems_message_queue_delete( id );
-      put_time(
-         "overhead: rtems_message_queue_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_send */
-            (void) rtems_message_queue_send( id, (long (*)[4])buffer );
-      put_time(
-         "overhead: rtems_message_queue_send",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_urgent */
-            (void) rtems_message_queue_urgent( id, (long (*)[4])buffer );
-      put_time(
-         "overhead: rtems_message_queue_urgent",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_broadcast */
-            (void) rtems_message_queue_broadcast(
-               id,
-               (long (*)[4])buffer,
-               &count
-      put_time(
-         "overhead: rtems_message_queue_broadcast",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_receive */
-            (void) rtems_message_queue_receive(
-               id,
-               RTEMS_DEFAULT_OPTIONS,
-               timeout
-      put_time(
-         "overhead: rtems_message_queue_receive",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_message_queue_flush */
-            (void) rtems_message_queue_flush( id, &count );
-      put_time(
-         "overhead: rtems_message_queue_flush",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_event_send */
-            (void) rtems_event_send( id, events );
-      put_time(
-         "overhead: rtems_event_send",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_event_receive */
-            (void) rtems_event_receive(
-               RTEMS_EVENT_16,
-               timeout,
-               &events
-      put_time(
-         "overhead: rtems_event_receive",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_signal_catch */
-            (void) rtems_signal_catch( Asr_handler, RTEMS_DEFAULT_MODES );
-      put_time(
-         "overhead: rtems_signal_catch",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_signal_send */
-            (void) rtems_signal_send( id, signals );
-      put_time(
-         "overhead: rtems_signal_send",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_partition_create */
-            (void) rtems_partition_create(
-               name,
-               Memory_area,
-               2048,
-               128,
-               &id
-      put_time(
-         "overhead: rtems_partition_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_partition_ident */
-            (void) rtems_partition_ident( name, RTEMS_SEARCH_ALL_NODES, id );
-      put_time(
-         "overhead: rtems_partition_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_partition_delete */
-            (void) rtems_partition_delete( id );
-      put_time(
-         "overhead: rtems_partition_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_partition_get_buffer */
-            (void) rtems_partition_get_buffer( id, address_1 );
-      put_time(
-         "overhead: rtems_partition_get_buffer",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_partition_return_buffer */
-            (void) rtems_partition_return_buffer( id, address_1 );
-      put_time(
-         "overhead: rtems_partition_return_buffer",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_region_create */
-            (void) rtems_region_create(
-               name,
-               Memory_area,
-               2048,
-               128,
-               &id
-      put_time(
-         "overhead: rtems_region_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_region_ident */
-            (void) rtems_region_ident( name, id );
-      put_time(
-         "overhead: rtems_region_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_region_delete */
-            (void) rtems_region_delete( id );
-      put_time(
-         "overhead: rtems_region_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_region_get_segment */
-            (void) rtems_region_get_segment(
-               id,
-               243,
-               timeout,
-               &address_1
-      put_time(
-         "overhead: rtems_region_get_segment",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_region_return_segment */
-            (void) rtems_region_return_segment( id, address_1 );
-      put_time(
-         "overhead: rtems_region_return_segment",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_port_create */
-            (void) rtems_port_create(
-               name,
-               Internal_port_area,
-               External_port_area,
-               0xff,
-               &id
-      put_time(
-         "overhead: rtems_port_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_port_ident */
-            (void) rtems_port_ident( name, id );
-      put_time(
-         "overhead: rtems_port_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_port_delete */
-            (void) rtems_port_delete( id );
-      put_time(
-         "overhead: rtems_port_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_port_external_to_internal */
-            (void) rtems_port_external_to_internal(
-               id,
-               &External_port_area[ 7 ],
-               address_1
-      put_time(
-         "overhead: rtems_port_external_to_internal",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_port_internal_to_external */
-            (void) rtems_port_internal_to_external(
-               id,
-               &Internal_port_area[ 7 ],
-               address_1
-      put_time(
-         "overhead: rtems_port_internal_to_external",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_io_initialize */
-            (void) rtems_io_initialize(
-               major,
-               minor,
-               address_1,
-               &io_result
-      put_time(
-         "overhead: rtems_io_initialize",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_io_open */
-            (void) rtems_io_open(
-               major,
-               minor,
-               address_1,
-               &io_result
-      put_time(
-         "overhead: rtems_io_open",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_io_close */
-            (void) rtems_io_close(
-               major,
-               minor,
-               address_1,
-               &io_result
-      put_time(
-         "overhead: rtems_io_close",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_io_read */
-            (void) rtems_io_read(
-               major,
-               minor,
-               address_1,
-               &io_result
-      put_time(
-         "overhead: rtems_io_read",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_io_write */
-            (void) rtems_io_write(
-               major,
-               minor,
-               address_1,
-               &io_result
-      put_time(
-         "overhead: rtems_io_write",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_io_control */
-            (void) rtems_io_control(
-               major,
-               minor,
-               address_1,
-               &io_result
-      put_time(
-         "overhead: rtems_io_control",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_fatal_error_occurred */
-            (void) rtems_fatal_error_occurred( error );
-      put_time(
-         "overhead: rtems_fatal_error_occurred",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_rate_monotonic_create */
-            (void) rtems_rate_monotonic_create( name, &id );
-      put_time(
-         "overhead: rtems_rate_monotonic_create",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_rate_monotonic_ident */
-            (void) rtems_rate_monotonic_ident( name, id );
-      put_time(
-         "overhead: rtems_rate_monotonic_ident",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_rate_monotonic_delete */
-            (void) rtems_rate_monotonic_delete( id );
-      put_time(
-         "overhead: rtems_rate_monotonic_delete",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_rate_monotonic_cancel */
-            (void) rtems_rate_monotonic_cancel( id );
-      put_time(
-         "overhead: rtems_rate_monotonic_cancel",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_rate_monotonic_period */
-            (void) rtems_rate_monotonic_period( id, timeout );
-      put_time(
-         "overhead: rtems_rate_monotonic_period",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-/* rtems_multiprocessing_announce */
-            (void) rtems_multiprocessing_announce();
-      put_time(
-         "overhead: rtems_multiprocessing_announce",
-         end_time,
-         OPERATION_COUNT,
-         overhead,
-         0
-  TEST_END();
-  rtems_test_exit( 0 );
diff --git a/testsuites/tmtests/tmoverhd/tmoverhd.doc b/testsuites/tmtests/tmoverhd/tmoverhd.doc
index 8c1d97ed28..0000000000
--- a/testsuites/tmtests/tmoverhd/tmoverhd.doc
+++ /dev/null
@@ -1,82 +0,0 @@
-#  COPYRIGHT (c) 1989-1999.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
-directives:
-+ rtems shutdown executive
-+ rtems task create
-+ rtems task ident
-+ rtems task start
-+ rtems task restart
-+ rtems task delete
-+ rtems task suspend
-+ rtems task resume
-+ rtems task set priority
-+ rtems task mode
-+ rtems task wake when
-+ rtems task wake after
-+ rtems interrupt catch
-+ rtems clock get
-+ rtems clock set
-+ rtems clock tick
-+ rtems timer create
-+ rtems timer delete
-+ rtems timer ident
-+ rtems timer fire after
-+ rtems timer fire when
-+ rtems timer reset
-+ rtems timer cancel
-+ rtems semaphore create
-+ rtems semaphore delete
-+ rtems semaphore ident
-+ rtems semaphore obtain
-+ rtems semaphore release
-+ rtems message queue create
-+ rtems message queue ident
-+ rtems message queue delete
-+ rtems message queue send
-+ rtems message queue urgent
-+ rtems message queue broadcast
-+ rtems message queue receive
-+ rtems message queue flush
-+ rtems event send
-+ rtems event receive
-+ rtems signal catch
-+ rtems signal send
-+ rtems partition create
-+ rtems partition ident
-+ rtems partition delete
-+ rtems partition get buffer
-+ rtems partition return buffer
-+ rtems region create
-+ rtems region ident
-+ rtems region delete
-+ rtems region get segment
-+ rtems region return segment
-+ rtems port create
-+ rtems port ident
-+ rtems port delete
-+ rtems port external to internal
-+ rtems port internal to external
-+ rtems io initialize
-+ rtems io open
-+ rtems io close
-+ rtems io read
-+ rtems io write
-+ rtems io control
-+ rtems fatal error occurred
-+ rtems rate monotonic create
-+ rtems rate monotonic ident
-+ rtems rate monotonic delete
-+ rtems rate monotonic cancel
-+ rtems rate monotonic period
-+ rtems multiprocessing announce
-concepts:
-+ Test the overhead of various classic RTEMS directives.
2.24.3
