[PATCH v4 4/5] validation: Add general purpose test suite
Sebastian Huber
Fri Sep 11 15:34:35 UTC 2020
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
rtems-central repository.
Update #3959.
Doxyfile | 2 +-
cpukit/doxygen/top-level-groups.h | 6 +
testsuites/validation/ts-validation-0.c | 217 ++++++++++++++++++++++++
3 files changed, 224 insertions(+), 1 deletion(-)
create mode 100644 testsuites/validation/ts-validation-0.c
diff --git a/Doxyfile b/Doxyfile
index c794938191..ffb87fe89d 100644
--- a/Doxyfile
+++ b/Doxyfile
@@ -812,7 +812,7 @@ WARN_LOGFILE =
# spaces. See also FILE_PATTERNS and EXTENSION_MAPPING
# Note: If this tag is empty the current directory is searched.
-INPUT = bsps cpukit
+INPUT = bsps cpukit testsuites/validation
# This tag can be used to specify the character encoding of the source files
# that doxygen parses. Internally doxygen uses the UTF-8 encoding. Doxygen uses
diff --git a/cpukit/doxygen/top-level-groups.h b/cpukit/doxygen/top-level-groups.h
index a177e8a715..c1a91a3482 100644
--- a/cpukit/doxygen/top-level-groups.h
+++ b/cpukit/doxygen/top-level-groups.h
@@ -42,3 +42,9 @@
* @brief RTEMS Implementation.
+ * @defgroup RTEMSTestSuites Test Suites
+ * @brief Collection of Test Suites
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
new file mode 100644
index 0000000000..3f61b70a3f
--- /dev/null
+++ b/testsuites/validation/ts-validation-0.c
@@ -0,0 +1,217 @@
+ * @file
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file was automatically generated. Do not edit it manually.
+ * Please have a look at
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * for information how to maintain and re-generate this file.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/sysinit.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestSuiteTestsuitesValidation0 spec:/testsuites/validation-0
+ * @ingroup RTEMSTestSuites
+ * @brief This general purpose validation test suite provides enough resources
+ * to run basic tests for all specified managers and functions.
+ * In SMP configurations, up to three scheduler instances using the SMP EDF
+ * scheduler are provided using up to four processors.
+#include <rtems/test-info.h>
+const char rtems_test_name[] = "Validation0";
+static char buffer[ 512 ];
+static const T_action actions[] = {
+ T_report_hash_sha256,
+ T_check_task_context,
+ T_check_rtems_barriers,
+ T_check_rtems_extensions,
+ T_check_rtems_message_queues,
+ T_check_rtems_partitions,
+ T_check_rtems_periods,
+ T_check_rtems_semaphores,
+ T_check_rtems_tasks,
+ T_check_rtems_timers
+static const T_config test_config = {
+ .name = rtems_test_name,
+ .buf = buffer,
+ .buf_size = sizeof( buffer ),
+ .putchar = rtems_put_char,
+ .verbosity = T_VERBOSE,
+ .now = T_now_clock,
+ .action_count = T_ARRAY_SIZE( actions ),
+ .actions = actions
+static void runner_task( rtems_task_argument arg )
+ int exit_code;
+ (void) arg;
+ rtems_test_begin( rtems_test_name, TEST_STATE );
+ T_register();
+ exit_code = T_main( &test_config );
+ if ( exit_code == 0 ) {
+ rtems_test_end( rtems_test_name );
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
+#define MAX_TLS_SIZE 64
+#define ATTRIBUTES RTEMS_FLOATING_POINT
+RTEMS_TASK_STORAGE_ALIGNMENT static char runner_task_storage[
+ RTEMS_TASK_STORAGE_SIZE(
+ MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE,
+ ATTRIBUTES
+static const rtems_task_config runner_task_config = {
+ .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
+ .initial_priority = 1,
+ .storage_area = runner_task_storage,
+ .storage_size = sizeof( runner_task_storage ),
+ .maximum_thread_local_storage_size = MAX_TLS_SIZE,
+ .initial_modes = RTEMS_DEFAULT_MODES,
+ .attributes = ATTRIBUTES
+static void init_runner_task(void)
+ rtems_id id;
+ rtems_status_code sc;
+ sc = rtems_task_create_from_config( &runner_task_config, &id );
+ if ( sc != RTEMS_SUCCESSFUL ) {
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
+ sc = rtems_task_start( id, runner_task, 0 );
+RTEMS_SYSINIT_ITEM(
+ init_runner_task,
+ RTEMS_SYSINIT_CLASSIC_USER_TASKS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_PROCESSORS 4
+#define CONFIGURE_MAXIMUM_BARRIERS 3
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 3
+#define CONFIGURE_MAXIMUM_PARTITIONS 3
+#define CONFIGURE_MAXIMUM_PERIODS 3
+#define CONFIGURE_MAXIMUM_SEMAPHORES 3
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_MAXIMUM_TIMERS 3
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 3
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
+#if defined(RTEMS_SMP)
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_EDF_SMP(a);
+RTEMS_SCHEDULER_EDF_SMP(b);
+RTEMS_SCHEDULER_EDF_SMP(c);
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+ RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+ RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+ RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+#endif /* RTEMS_SMP */
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
2.26.2
