New Build System Status
Chris Johns
chrisj at rtems.org
Sat Sep 12 00:08:20 UTC 2020
On 12/9/20 5:35 am, Joel Sherrill wrote:
> On Fri, Sep 11, 2020 at 2:00 PM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Fri, Sep 11, 2020 at 12:03 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 11/09/2020 17:46, Gedare Bloom wrote:
> > > I have nothing pending. I think we should switch early next week, sort
> > > out any bugs during the week?
> > This sounds good. I can do some final tests builds over the week end and
> > then push it on Monday morning.
> Super. I will plan to spend time on Monday to try to walk through it
> and see how it goes. I haven't bothered to try yet, so it will be a
> good test of the documentation ;)
> Hopefully I can +1 that.
> I have someone converting my big cron runner to Python based on the
> rtems-tools framework. Switching past autoconf on master will make his
> life easier. Basically just autoconf on 5 or waf on master.
Should I remove the autotools build set from the default tool builds once the
merge is done?
