pc386 BSP/master branch build failure with smp enabled.
Gedare Bloom
gedare at rtems.org
Sat Sep 12 15:13:46 UTC 2020
On Sat, Sep 12, 2020 at 8:25 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Sep 12, 2020 at 6:39 AM Karel Gardas <karel.gardas at centrum.cz> wrote:
> > On 9/12/20 9:28 AM, Karel Gardas wrote:
> > > On 9/12/20 6:59 AM, Gedare Bloom wrote:
> > >> On Fri, Sep 11, 2020 at 11:53 AM Karel Gardas <karel.gardas at centrum.cz> wrote:
> > >>> On 9/11/20 6:16 PM, Gedare Bloom wrote:
> > >>>> Looks to be coming through
> > >>>> cpukit/score/cpu/i386/include/rtems/asm.h:157 movb
> > >>>> imps_apic_cpu_map(\REG),\REG /* CPU ID in REG */
> > >>>> The assembler is right to complain. movb has to target one of the
> > >>>> 1-byte mnemonics, so this should be %al for the LSB of %eax. One needs
> > >>>> to check through this logic carefully, but I think the right thing to
> > >>>> do here is:
> > >>>> movzbl imps_apic_cpu_map(\REG),\REG
> > >>>> That should do the trick. Can you test it locally?
> > >>> Sure! Builds fine and testsuite testing reveals:
> > >> Great. I opened #4076 to apply this fix on 5 branch.
> > > Wait a minute. I've thought 5 branch is perfectly fine. What's broken is
> > > master. Well, 5.1rc2 and 5.1 release were fine for SMP on pc386 so I
> > > expected 5 branch be too. -- Anyway, I'll test that for sure.
> > I've tested 5 branch and it compiles and works fine with SMP so the fix
> > is needed only on master branch.
> oh ok thank you! I'll move that ticket over, and push a fix but may
> wait until after the build system change goes in.
nvm, I got to it today. test master when you can please :)
> > Karel
